Question about Samsung SM30P-White Wireless Optical Mouse with Patented 5 Button Wheel Key, Presenter and Laser Poi...
No driver fo rSamsung wireless presenter mouse SM30P driver
Mouse problem
Update and install the newest hardware drivers from the Microsoft site. This should correct your problem. Yes, I know it will work Plug & Play, it just doesn't work properly. The other issue is batteries... use the most expensive batteries you can afford and never rechargeables as the voltage is less 1.25 V vs. 1.5 V.
Aug 27, 2012 | Microsoft Wireless Notebook Presenter...
Is not working
looks like it is not compatible with Macbook ..check out the user guide or the box of the mouse has to written over there if it is compatible
Nov 19, 2011 | Samsung SM30P-White Wireless Optical Mouse...
Have puchased. a acer wireless optical mouse how do I change over from the present mouse pad?
Theres nothing you need to do much, just plug in the wireless transmitter drive into the usb port, then download driver if one is required. Press the link button, usually a small button located under the wireless mouse.. then you should be good to go. You can disable the mouse pad, usually there is a button or a fn key to disable the mouse pad.
Jan 31, 2011 | Computers & Internet
Put wireless mouse on a pavilion dv6 3031tx lap top and it worked fine then the other day lap top batters went flat and now mouse will not move pointer yes it still installed and working correctly have...
Please uninstall the whole driver package and also clean the registry fo the software via START--RUN--REGEDIT- and re-install the same. It would work FINE
Sep 01, 2010 | Microsoft Wireless Mobile Mouse 3000
Can the targus bluetooth presenter for mac be used on a windows system?
Sorry it can't be used on win because there are no drivers for it.
Jun 13, 2010 | Targus Bluetooth Presenter for Mac
How to turn on wireless on Lenovo T61 laptop?
I checked the manufacturer's web-site:
http://www-307.ibm.com/pc/support/site.wss/product.do?brandind=10&familyind=374625&machineind=0&operatingsystemind=49979&template=%2Fproductselection%2Flandingpages%2FdownloadsDriversLandingPage.vm&validate=true
but did not find any device-driver for the wireless-adapter for your Operating System.
This might imply that the wireless-adapter is fully supported by the Operating System, i.e., no additional device-driver is needed.
Open the "Network Connections" window, and display all the currently-defined network-adapters -- the wireless adapter should be present. Select it, and right-mouse click on its icon, and choose "enable".
Apr 29, 2010 | Lenovo (40Y7026) Wireless Adapter
Wireless mouse quit working. Replaced batteries as
Just Bought new one ! Present one outlived warrenty period. Problem unlikely to be both in mouse and adaptor, so have a spare for the good one. Thanks
Dec 31, 2009 | Logitech Cordless Mouse
My Dell wireless keyboard has stopped working. The optical mouse is still working, but the keystrokes are not being transmitted from the keyboard. I have already replaced the batteries and checked the...
Underneath the keyboard is a little 're-set' button. When you push this it re-synchs with the wireless antenna. Make sure you hold it down long enough fo rthe keyboard to synch, usually about 5 - 7 seconds.
Dec 19, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Targus Multimedia Wireless Presenter
Reload the drivers for this keyboard. Make sure that the drivers are for the OS (operating system) that you have.
Mar 27, 2008 | Computers & Internet
Samsung SM30P-White Wireless Optical Mouse with Patented 5 Button Wheel Key, Presenter and Laser Poi...  Logo
216 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
