My tele has no picture just black screen - Televison & Video
    Genius:
  • 1,156 Answers
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Good luck in solving the problem....
Posted on May 18, 2011
Tele has sound but no picture
Time to replace your lamp on your tv.
Mar 20, 2015 | Hitachi 62VS69A
My picture has gone to half it a grundig tele
What is the exact model number to your Grundig?
Sep 25, 2012 | Televison & Video
When the tele is on the screen has lines through it (black and white) and flashes in between the blue screen and the picture display.
OK so you are saying that you can hear the TV even when the TV flashes to a blue screen right can you hear a diff noise that it has never made before
Dec 24, 2010 | Toshiba Televison & Video
Hi. I have an ALBA LCD32880HDF television which I purchased in August 2009 so just outside warrenty. I have been on holiday for a week and had switched the television off at the wall and returned home...
hi all the black screen solution for me was this (this is assuming you have alba brand tvs and have the black screen BUT can still hear the sound) i after much fekkin around with it eventually found the solution in it (its the bloody backlight brightness in the settings you need to turn it from high TO LOW) ....... now this can be a bit tricky because usually when you have the black screen problem if u unplug the tv for a few hours and plug it back in you only get or should get probably like 30-1min of picture time before the picture goes black so u have to be reallllly fast with the menu button to get into settings before the picture dies (i learned the sequence for my alba lcd32880hdf) it was the following (for this part use the remotes arrows the one with the ok button usually in the centre of them) turn the tv on then click menu then press the up key 2 times then press ok then use the right arrow/button twice (although u cant see what ur doing ur navigating the menu hehe) then press the down arrow/button seven times before finally pressing the left arrow/button (once) <-- (now this bit may need to be done twice if you can remember setting ur backlight to max use it twice it will put it on minimum if in doubt only press it the once remember to totally power the tv off before repeating the steps to reset menus default posistions) remember thats the solution i found for my tv stands to reason (since i did infact buy another tv same brand different model which got the same problem) that this could be a solution for all alba tv users try it worked for me 2 times if ur not sure of the menu look up you tv models menu navigation online to find out the buttons you press gl hopefully it works for you too
Oct 24, 2010 | Televison & Video
I have a black vertical line on my lg plasma screen
Reboot the tele system, look for an updated software driver download on the LG web site, try different sources like VCR, DVD, Blu Ray to see if vertical line is there.  If still there, then your tele is fu.k.d in which you should contact LG or replacement or repair.  If you recently purchased this thing, then take it back to the shop and demand an exchange or refund for selling you this rubbish.  Cheers.
Nov 01, 2009 | Televison & Video
Help- I have a TV/VCR combo. the screen has a
take the remote and go into the menu and turn off the tele captioning or closed captioning and that shoud clear that up for you
Oct 28, 2009 | Televison & Video
Cant find buttons on back of tele
Usually Sony LCD TV has control buttons on top or at lower side of TV.
Let me know your TV model number to find out exact location of buttons.
Thanks.
Oct 18, 2009 | Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
All pictures are blurred and when looking at screen its blurred
Your camera's Focus mode may be set on Macro Selectable in which case the Auto Focus Range will be "wide: 0.07–0.7 m, tele: 0.4–0.7 m (macro AF)" as quoted in the specifications from www.kodak.com web page for the EasyShare M1033. While this setting is great for a close-up of a flower, anything more than a meter (about one yard) away will be blurred unless you reset your Auto Focus mode back to "normal AF" or "landscape mode"
Jan 07, 2009 | Kodak EasyShare M1033 - black Digital...
Connecting my laptop to my samsung tele
Most common problem is the VGA cable. Make sure you have the 15 pin VGA Monitor cable.
1. Switch off the TV & Notebook
2. Connect the VGA cable to the TV and Notebook.
3. Switch on the Notebook. Set the resolution to 800 x 600 Pixels (Go to Control Panel - Adjust Screen Resolution). Then go to Advanced settings and set 'Screen Refresh rate' as 60 hz in the Monitor tab,
4. Switch on the TV. Go to Source button from the TV remote and select PC as input source. Alternatively, you can go to 'Menu' and select 'PC' as input source. If the connection is made properly, PC option will NOT be GREY anymore.
5. Press Fn + F5, F6, F7 (depending on which Notebook brand you have)
Jul 08, 2008 | Samsung LN-S4051D 40 in. LCD Television
No picture
change ur backlight inverter
May 01, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
