Question about LaCie 500GB RUGGED USB 5400 RPM 8MB 500 GB USB 20 Hard Drive
I have the Lacie Rugged 500gb hard drive. Have been using it for around 2 years and have it partitioned so I can use it both on a Mac (mainly) and a Windows computer. Just recently I have had to resort to using the fire wire connection as the USB connection is never recognised. Just tried using it, and the drive spins up so I know its working, but my Mac can't recognise it on the desktop or the finder. I have tried using the disk utility service, but it is not recognised there either. Any help would be much appreciated.
mrrichardlbo
  • 59 Answers
SOURCE: Western Digital Reset / Set Hard Disk Size ?
hit F1 when you bootup dont let windows come on . Go in you Biso to set you new hard drive.dont forget to F10 to save changes...Good Luck
Posted on Aug 16, 2009
bob_computer
  • 3153 Answers
SOURCE: My LaCie 500GB Quadra spins and clicks. Have tried
If you can hear clicking then I am afraid there is a serious problem with the hard drive.
The noise you can hear is usually known as "the click of death" when referring to hard drives.
Make sure you use ONLY the cable that came with it or a SHORTER one.
Dont connect via a USB hub
Make sure you only user the power supply that CAME WITH IT.
Most common causes are that the drive unit was dropped or mishandled or just plain old age
There is no known cure unless the data is mission critical
In which case you could sent it to a data recovery specialist but this is usually VERY expensive.
If you are advised to place it in a freezer or anything similar then that is up to you
but my advise would be to run from the person who may give this advise.
This is very old fashioned advice and meant for very old types of drives that used to get very hot.
If it a drive that was / is from an external enclosure then you could still use the enclosure and just place a new hard drive in there.
Another way to test it it to remove it from the enclosure and connect it directly to a PC with a suitable interface eg. SATA or IDE.
Posted on Sep 11, 2009
Testimonial: "Thanks for the quick reply. "
jimmy_k8
  • 242 Answers
SOURCE: MacBook won't recognize my Lacie Rugged Hard Disk.
Is your MacBook as fast as the Lacie Rugged Hard Disk is?
Because solid state drive wasn't available on MacBook Pro at the initial time when it launched. Hard drives on all current Apple laptops are equipped with Sudden Motion Sensor technology. In fact, the Apple laptops that came with Sudden Motion Sensor are: All Intel-based Apple portables such as the MacBook, MacBook Pro, MacBook Air, PowerBook G4 computers starting with PowerBook G4 (12-inch 1.5GHz), PowerBook G4 (15-inch 1.67/1.5GHz), PowerBook G4 (17-inch 1.67GHz), and iBook G4 computers starting with iBook G4 (Mid 2005) have Sudden Motion Sensor technology. You MacBook may not have come with that technology that could be the reason you are unable to connect it.
Sorry mate... too many limitations on
Posted on Feb 24, 2010
citroenchris
  • 600 Answers
SOURCE: Lacie RUGGED 250GB not recognized by my PC
I think the migration assistant (in the utilities file in your application folder) can transfer files direct via USB.
Posted on Aug 10, 2010
  • 5 Answers
SOURCE: my del computer Vista 32
You have to convert a GPT disk to MBR by using the clean command in DiskPart. See more details here:
http://www.aurul.com/500gb_hard_drive.htm
Posted on Oct 28, 2010
ONLY 650 MB OUT OF ONE TERABYTE lacie all terrain
For anyone else that runs into this issue, you don't need the EXE.
Follow the instructions on here to get to the Storage control panel area on your computer so you can view partitions:
http://www.ehow.com/how_5022760_check-partitions-hard-drive.html
Locate your LaCie drive, and delete the small partition that shows as "Healthy". Once you delete that, you should have a large "Unallocated" space. Format that normally using either FAT32 or NTFS. Your drive will now have its full allocation (which with a 500GB drive, should be around 465GB, give or take depending on the system accessing it).
Mar 31, 2012 | LaCie Rugged All-Terrain (301017) Hard...
I have a lacie 500gb HD and i use the FW800 port and when ever i plug it into the mac i use it for a while, then it freezes up( i have 4gb of ram and plenty of hard drive space on the mac) and then i have...
Sounds like it's the HDD.. But it could also be a port on your Mac. Here are a few steps to narrow it down.
- Does your Mac lock up even if the HDD is plugged into a different port? Try them all out and test it.
- Do you have another computer laying around that you can plug the HDD into? If that other computer locks up with the HDD plugged into it, then it's the HDD.
These two steps will help you determine what the issue could be. You can also contact Lacie at their support line and they can help troubleshoot:
http://www.lacie.com/support/index.htm?rid=10036
Thanks and hope this help! please rate if it does!
Mar 29, 2011 | LaCie Rugged All-Terrain (301017) Hard...
I have Lacie Rikiki Go 500GB, when the first format I set it with Mac user. Now I want to use for both Mac/Window. Pls advise. Thanks
the easiest way to allow you to share data from the same partition between MAC and PC is to format your drive as MS-DOS (FAT 32) with Disk Utility, but you will be limited to files of 4GB or smaller.
Another way to do it is to format your drive as NTFS with Windows disk manager and to install an add on on your MAC that allows you to write to NTFS partitions (without add on, you will only be able to read NTFS partitions)
Regards,
Jan 05, 2011 | LaCie Design by F. A. Porsche 160 GB Hard...
Partitioning lacie hard disk 2.0 500 gb
Windows XP: Right-click on "My Computer" and select "Manage". From there, select "Disk Management" which lets you view the drives and do things to. More details here...
If you're on Mac OS: Here's how
Mar 20, 2009 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
LaCie 500GB external will not show up on mac desktop. Blue light on, whirrs as if working but no icon on desktop (not mounted)
Did you format the drive using Disk Utility? Open "disk utility" from the dock icon or applications/utilities folder. Click the drive name on the left side of the disk utility window. click the "partition" tab in the window, next click the "options" tab and select GUID Partition scheme, or any Mac compatible scheme, read each explanation of the schemes. Name and resize your partitions, click apply. This is how it works running Leopard, not positive if the same applies to Tiger. I hope this helps you
Dec 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie d2 Quadra drive... not showing up on PC after working on a MAC
You need to make sure the drive is formatted for the PC. The Mac will read and write to a FAT32 partition, but the PC cannot see a Mac formatted drive as you have seen.
The only problem is that there is a 32Gb limit per partition for FAT32 drives.
It's not ideal but it's the best you can do easily.
Jan 13, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 500GB RUGGED USB 5400 RPM 8MB 500 GB USB 20 Hard Drive Logo
54 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
