Question about Mitsubishi WS-55511 55" Rear Projection Television
My tv shuts off every 30 min after will reseting it makes a difference if it does where is the reset button
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
When the set shuts off on the front of the set press and hold input and menu buttons at same time for at least five seconds and let both go.
Power light will blink an error code like two blinks, two blinks, a pause and repeat it several times; error code will give some idea where problem is, 1,2 blinks is no error found.
SD TECH
Posted on May 18, 2011
Sound goes off after 15 Min
Assuming it is not hardware but soft settings...
1) Check and make sure that your TV does not have the timer set.
The Timer feature allows you to set a day and time for the TV to turn on automatically and the device and channel to display when it switches on. If the TV is already on at the requested time, the TV automatically tunes to the channel you designated in the Timer menu.
When the Timer turns on the TV, the following message is displayed: "Press a button for the TV to stay on." Press any button on the remote control within five minutes if you wish the TV to remain on.
Note: The TV clock must be set before you can use the
Timer feature (see preceding page to set the clock).
On/Off
Press down arrow / up arrow to enable or disable the Timer.
2) If not working, try SYSTEM RESET. Press SYSTEM RESET button on the front panel with pointed object (e.g. straight paperclip). TV turns off, green LED flashes for about 1 minute. When it stops flashing turn the TV on again. All settings other than Parental Lock need to be set again using the manual.
3) TV RESET. If all else fails for soft error. Your manual describes this last resort for soft type error. It could be hardware problem needing more expertise.
Manual can be viewed on a computer at
http://www.audiolabga.com/pdf/V32-V32L_Service_Manual.pdf
Aug 05, 2014 | Mitsubishi WD-62531 Projection Television
Have an Emerson MW 8115 SS. Kids have apparently locked in buttons on weight or defrost mode. If I set a time 30 sec. or 1 min. timer will count down but when I push start nothing happens. Is there a reset...
Product manual does not show reset protocol.
http://waterheatertimer.org/pdf/Emmerson-microwave-manual.pdf
There is Child-Lock feature on page 13 of manual, but display will not let you press buttons
Customer service 1-800-909-1240
Unplug microwave and see if it resets.
Press both Stop and Clear buttons simultaneously.
Try different power level by pressing Power button.
It is possible the Start button has gone bad.
Make sure clock is set.
Nov 03, 2012 | Hardware & Accessories
The reset button does nothing. After 10 seconds, no light flicker no reset nothing. How do I restore factory setting without the reset button on the dlink dap-1150?
To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process. Wait about 30 seconds to access the router. The default IP address is dlinkap. When logging in, the username is admin and leave the password box empty.
Feb 12, 2011 | D-Link Computers & Internet
TV turns on for about 2 min and then shuts off for 30 sec.
Check the standby timer. Or reset your HDTV to factory settings. Just turn on the TV. While holding down the RESET button on the remote control, press the power button on the TV. (The TV will turn itself off, then turn back on again). Release the RESET button..
Nov 06, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv will not turn on. need to locate reset button
There is no reset button unplug tv for 30 min, although toshiba says you can do it for 30 seconds. Email me back if you have more issues. I have dirt cheap parts. hill6399 at yahoo
Feb 28, 2010 | Toshiba TP55H60 55" Rear Projection...
TV worked fine two nights ago. Turned on today and no sound or picture. Blue pilot light under center of screen always on. Any ideas?
There are reset buttons on the plasma look and find your make sure after you reset your tv that u shut it off for few mins
Dec 09, 2009 | Samsung HP-T4254 42 in. Plasma Television
Yellow light flashing dodge caravan1998 reset afer 30 min rear wiper defrost ac
The blinking lights in the rear wiper rear defrost area can be reset by holding 2 buttons of the 3 on the left hand side. The top and bottom buttons. Turn the key on and hold them for about 10 sec and they should start flashing differently. Just let it do this. After they start flashing different. It will take 5 to 10 mins. Then one or more will quit flashing all together. If they don't after about 20 min reset them again it can take about 5 trys sometimes before they all go out. Good Luck
Nov 13, 2009 | 1998 Dodge Caravan
My Samsung32'' resets to default settings every 30 mins!
Hi reset the tv and put it in to home mode!!!!
Shop mod resets tv settings every 30 mins
Apr 13, 2009 | Samsung Televison & Video
PROBLEM WITH SAMSUNG DLP TV
disconnect the power and hold in the power button for 30 seconds to reset it.
Feb 20, 2008 | Samsung DLP HL-P5663W 56" TV
Tv was working fine...then shut itself off.
there is no reset button on any tvs that stop in 1980s when they no longer used tubes in chassis,s now the only tube is your picture tube. you probly have a shorted hori out put transistor.
Nov 21, 2006 | RCA F27242GY 27" TV
Mitsubishi WS-55511 55" Rear Projection Television Logo
37 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
