Question about Toys
What does my lionel 6110 use for smoke. Smoke pellets or fluid.
    Problem Solver:
  • 13 Answers
Pellets are hard to come by, best source is ebay.....
Posted on Nov 19, 2011
  • 3,018 Answers
  • The Lionel 6110 Scout Engine came stock with a pellet smoke generator. Sometimes these get converted so the smoke puffs more out the front. But the way it came out of the box is pellets.
Regards, Tony
Posted on May 18, 2011
  • Iron
    Iron May 18, 2011
    Some of the later Scouts cam with liquid so do this test to make sure as some people convert them anyway so you may never know unless you do this check - If you look down inside the smoke stack blacked white ceramic piece with wire wrapped around it then it is using pellets currently. If you don't see that piece then it is liquid.
The smoke unit stopped working. been run only 5 minutes
??? not sure why a evolution would have a smoke unit in it , but anyways its possible that trains were shipped with only a small amount of smoke fluid in them (makes shipping less messy) a bottle of smoke fluid and a few drops of this wonderful stuff is all you should need to get your engine smoking again
Aug 27, 2015 | Lionel Canadian Pacific Es44ac Evolution...
Smoke unit doesn't smoke
First verify wire connections (use a Volt/Ohm meter if you have one). Second, verify RESISTANCE in the smoke unit coil wire. Chances are it will be "Open" and reading zero (0) resistance. Acquire new wiring through eBay or Amazon ... and re-wrap the wiring as per the number of wraps as per your Lionel Repair Manual.
Apr 06, 2014 | Lionel 8141-50 Smoke Unit
Www support toys1628 com
Check that you have added the smoke fluid (oil) to the engine and that it has not run dry. The smoke from the engine is generated by a small chamber with a heating element built in. The heating element gets hot as the loco runs and heats the smoke fluid up which in turn creates the steam/smoke. If there is no fluid the heating element can over heat and will smell as you describe. Not sure if your model has a smoke effect on/off switch, if it has switch it off if you do require the smoke effect.
Dec 27, 2013 | Northpole Lionel North Pole Steam Engine...
Lionel instructionshow to smoke unit
http://youtu.be/JZlvekT67ws
If you'll follow the link, it will take you to the Lionel Service Video for the Lionel Smoke Unit.
May 02, 2013 | Toys
Were to put smoke fluid on a lionel 8141
If you are asking about the 2-4-2 scout type, a few drops down the stack.
If you are asking about the diesel switcher, it has no smoke unit.
Feb 24, 2013 | Lionel 8141-50 Smoke Unit
No smoke tryed every thing
Follow the link to the Lionel Service Document/Manual
http://www.lionel.com/media/servicedocuments/6299711323250LEGACYMallet.pdf
This link is for the customer Service Product Video:
http://www.lionel.com/CustomerService/service-documents/video.cfm?documentID=6371
Feb 16, 2013 | Lionel 628076 Nickel Plate Usra 2662...
What is lionel smoke pellet tamper used for? Why needed?
Yes, you do just drop the pellet in...
But if there is any kind of crud built up in the
smoke stack, it may not allow the pellet
to seat on the heating element. Thus the
tamper is included to allow you to push
the pellet all the way down. If you don't
have one, a piece of wooden dowel the right
diameter can be used.
Jan 23, 2013 | Lionel Toy Trains Smoke Pellets
How can I fix smoke problem on polar express
Most Lionel engines have a small slider switch which can turn off the smoke generator. Check to see that the switch is in the ON position. Check the engine manual (available from Lionel's website) for the location of the switch.
Also, if the smoke generator is always on and no fluid had been used in the generator, it will eventually burn out. Replacement smoke generators are available from Lionel.
Jan 05, 2012 | Lionel The Polar Express Train Set
Polar Express locomotive will not smoke with smoke fluid in stack and smoke switch on.
You may have to check if there is power to the heating element. You can also check to see if there is too much fluid. You can also put the engine in neutral and tap the chimney hole a few time to kind of "prime" the smoke unit.
Mar 16, 2011 | Lionel Polar Express Train Set
Toys Logo
207 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
