Question about Brother MFC-9840CDW Laser Printer
I replaced the drum on my Brother 9840cdw and now it keeps saying EL Error, open front cover and close. I have done this repeatedly but EL Error won't reset
  • Brother Master
  • 19,396 Answers
Hi.
EL, which wants to represent E6 is not a drum error code. EL (E6) means NVRAM error on main PCB.
If the error does not go away disconnecting power, then the main PCB (controller board) must be replaced.
Several forums cannot understand EL is E6 and point in the wrong direction. The full list of error codes is reported in service manual at pages 22-23. Service manual has been uploaded below:
A full service manual: mfc9840cdwservice man.
Regards.
Ginko
Posted on May 18, 2011
I get a message to replace toner, i replaced and still get the messag
You may want to try the following steps:
  • Step 1 - First turn on your printer: Brother MFC 9840CDW.
  • Step 2 - Push the button on the front of the printer to open the cartridge cover or the front panel of the printer where you can access the toner cartridges. However, do not remove the toner cartridges (Brother TN-115).
  • Step 3 - Push the Clear/Back button and hold still to bring up a reset menu. There are 8 different toner functions ( two Black, two Cyan , two Magenta, and two Yellow).
  • Step 4 - For each of the eight functions in turn, push the O.K. button and then push it again to indicate 'Reset'. After a few seconds, it will say 'Accepted' and will then display a message that the cover is open.
  • Step 5 - Repeat the steps 3 and 4 for each of the other eight toner functions as needed.
  • Step 6 - Once your finished, close the front cover of your printer so the status bar will be reset to normal with no error message.
  • Also, you may want to clean the corona wires for each toner. Clean the corona wire inside the drum unit by gently sliding the green tab from left to right and right to left several times.
Nov 29, 2013 | Brother MFC-9840CDW Laser Printer
How do you turn off the drum alert after installing a new drum on the MFC-9840CDW Brother Laser printer?
Hi,I think this guys can have more helpful information about your problem.See this link:http://www.quikshiptoner.com/catalog/brother-mfc-9840cdw-toner-color-set.html#resett_drum_manualview More Info button to see how to install the Drum unit. Pay attentionthat after replacing a Drum unit in Brother MFC-9840CDW you have to reset thecounter. See steps 9, 10 and 11 for doing so.9) Close thefront cover, plug the power cable back in and turn on the printer.10) Press the Menu button,and then enter the number 84 to access the Reset Menu.11) Press the scroll keys until Drum is displayed and press OK.
I hope this can be helpful for you.
Jan 15, 2011 | Brother MFC-9840CDW Laser Printer
Drum error wont go away
This should be an easy one. Your Brother doesn't know it has a new drum until you tell it like this:
  1. Open the front, where the drum is.
  2. Touch the CLEAR button.
  3. The display will ask if you replaced the drum. I believe you touch 1 for "yes."
  4. Close the front door.
Nov 10, 2010 | Brother MFC-9840CDW Laser Printer
Drum error message
To reset MFC-7840W drum count use the following steps.
1. open the front cover (leave open).
2. Press clear/back.
3. Then confirm the new drum install by pressing 1.
4. The display will indicate accepted.
5. Then close the front cover.
This should be done each time the drum unit is replaced.
Jun 18, 2010 | Brother MFC 7840W Printer
My brother MFC9840cdw has an error message that says, "drum error, slide the green tab on each of the colored drum units. Refer to the users guide". I have tried sliding the green sliders several times. I...
The guy that replied solved the problem. He rocks and I can't believe that brother does have a large posting on this issue. Sham on them:
ben2913 did the job "This is NOT the solution to this error code. The code is telling you that the Corona wire must be cleaned. Remove all 4 color drums. Look down into the tray that you removed them from and you will see 4 green tabs. Open the plastic cover that protects the corona wire and move the green tab back and forth several times. After you have done this with all 4, reinstall the drums, close the machine front and everything will work fine again."
Feb 25, 2010 | Brother MFC-9840CDW Laser Printer
Have a brother mfc7440n and it keeps displaying "drum ending soon". have replaced the drum, but keep getting same display
You need to reset the drum counter.I'm not sure that working with your model but try it.
Try opening the front door cover and keep open. Then pressing clear, it should say replace drum, press 1 for yes, it should then say accepted, close cover and turn off.
Oct 08, 2009 | Brother Office Equipment & Supplies
Replaced Drum still says "Replace Drum Soon". How do I reset on a Brother 7420?
Reinstall the new drum unit, keeping the front cover open. Press OPTIONS. Press 1 when the display shows REPLACE DRUM? 1.YES 2.NO ACCEPTED. Close the front cover.
May 28, 2009 | Brother MFC 7420 All-In-One Laser Printer
How do I reset the Change Drum Soon on the display?
All you should have to do is: -replace the old drum with the new replacement. -with the front door open press the Clear/Back button -press the number 1 button and when ?accepted? appears on the LCD close the front cover. That should do it. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 28, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-9840CDW Laser Printer Logo
662 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
