Question about Home
Fluidmaster toilet fill runs when toilet tank is full
    Problem Solver:
  • 16 Answers
If there is nothing wrong with the fluidmaster, it probably needs to be adjusted, sounds like it is running down thru the overflow tube!
Posted on May 19, 2011
How do I fix a running toilet
replace the guts first,with universal ones,5 bucks at walmart,what happens is calcium builds up inside them and slowly closes the fill hole,just like your shower head,its easy to install the new "guts", Fluidmaster Universal Fill Valve 400ARP25 The Home Depot
install toilet fill unit Bing Videos
Jul 20, 2015 | Home
HOW TO SET WATER LEVEL GLACIER BAY TOILET
There should be a adjustment screw at the top of the fill valve, screw it up or down to adjust the tank level.
Sep 13, 2014 | Fluidmaster Glacier Bay Flapperless Toilet...
How to adjust fluidmaster
There should be a small black rubber tubing piece that connects to the fill valve and the other end goes in the overflow tube to refill the bowl after each flush. Make sure this tubing is installed correctly and that should solve the problem. Hope this helps.
Bob
Jul 03, 2014 | Home
Fluidmaster fil valve float sticks
Give it a slight turn to stop it from rubbing on the side
Nov 26, 2013 | Fluidmaster 400A Toilet Tank Repair Fill...
My fluidmaster 400 anti siphon for toilet will not stop filling making pump run over and over
Hi turtlerose07...
Sounds like you have one or two problems with the fluidmaster 400.
1...The float is set too high allowing the water to overflow into the overflow pipe and allowing your pump to run too much.
2...Flapper valve inside at the bottom of the tank is not sealing properly, thus allowing water to leak and causing the fluidmaster to keep trying to fill the tank with water and causing the pump to run too much.
Please take time to rate me
Aug 24, 2011 | Home
The toilet flushes but it won't fill. I can turn the water supply off and then back on, then it fills normally.When the tank is full, I can push the float down and no new water enters. when I flush,...
Hi!please kindly check your fill valve if it is working correctly.I thought the problem is in your fill valve.Kindly adjust the floater of your fill valve.
Aug 24, 2011 | Kohler Home
We replaced our 3 toilets with the Fluidmaster 400 and have had problems ever since. All the toilets are running water every 5 to 10 minutes and my water bill has doubled. What can we do?
Hello- If you replaced old ball and rod set with new fluidmasters they will most likely need to be adjusted, not all toilet tanks are of equal height. You will have to adjust water height,meaning you must keep water level below fill tube located in center of the toilet tank. Adjustment is done from bottom of the fluidmaster, they screw in and out to adjust height. You will notice threads along the bottom part of the fluid master, on the inside of the tank,they adjust up & down! Goodluck!
May 19, 2011 | Home
Toilet does not stop filling, water keeps running
Replace your toilet fill valve with a fluidmaster 400A
Click here
http://411plumb.com/how-to-replace-your-toilet-fill-valve-with-a-fluidmaster-400a
heatman101
Jan 16, 2011 | Jacuzzi Home
I have the k-4620-da toilet and when we flush a loud noise starts from inside the tank and doesn't stop until float is all the way up!
Make a note where your water level is then the tank is full. Replace the assembly that lets the water in with a Fluidmaster 400A fill valve, available at your local plumbing supply store.
Sep 27, 2010 | Kohler Home
Home Logo
345 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
