Question about Canon PIXMA iP90 InkJet Printer
Waste ink tank needs replacing
I am an HP tech Can I do this for a customer and where can I get the
parts?
Tim Harris
888-215-3102
PrimeSource
  • 34 Answers
You could order them from an authorized Canon Delaer, it's a part, not a supply item.
Posted on Nov 11, 2008
  •  Pam Obrien
    Pam Obrien Nov 11, 2008
    No seriously Tim if you want to purchase the waste ink absorbers email me and I'll give you my phone #. Not too sure if we have them in stock, but I can check it out if you still need them. Thanks, P
I have a Photosmart 3310 that has been playing up (leaks ink) and occasionally shows an error code Oxb 80e 15be. If I turn the machine on/off it does work again (albeit smudge/streak on underside of paper...
how old is you printer? did you clean you printer occationally? why i ask that? bec. the more you change your ink cartridge of the printer, the more the ink will stocked in the waste tank of the printer. you try to clean the waste tank of the printer, how? unscrew it... if you can't do it yourself, try to find a friend or printer tech. to clean the waste tank for you,,
Jun 24, 2011 | HP Photosmart 3310 Printer
Tip
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
on Apr 02, 2010 | Office Equipment & Supplies
I am getting a message that states that the waste ink tank for my HP H470 printer is almost full and that the printer will quit working when full. How do I change or empty this part and where do I find a...
You need to replace the ink service module BEFORE it gets completely full.
You can go to this web page for instructions:
Replacement of Ink Service Module
The part number is CB026-67043 for the Officejet H470 printer. You can order it from HP or check for availability from a local office supply store such as Staples or Office Max.
Here is the HP page to order:
HP H470 Ink Module
Thanks for using Fixya.
Jan 12, 2010 | HP Officejet H470 InkJet Printer
I need a Pitney Bowes DM200L postage meter repair manual
I found someone with the same problem at the following website.
http://forums.pb.com/t5/Equipment-Hardware-and-Supplies/DM100i-WASTE-INK-TANK-FULL-NEEDS-REPLACEMENT-MESSAGE/m-p/2589
Dec 21, 2009 | Office Equipment & Supplies
Parts inside your printer are coming to the end of their life
It could be the Waste Ink Pad. Call Epson tech support for the correct answer. If it is the pad go to the site below and get a Waste Ink Container. It sits outside the computer. Lood at the CISS, it will save you Tons of money.
http://www.inkproducts.com/ink-store/
Aug 04, 2009 | Epson Stylus Photo® R800 InkJet Printer
MY PRINTER IS TELLING THAT PARTS IN MY EPSON R220 NEEDS SERVICE
download .epson reset for printer,google will reset counters
Jul 05, 2009 | Epson Stylus Photo R220 InkJet Printer
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
Wont work
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
tiuy17
Jun 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
I have a PIXMA 960. changed all the cartridges, did deep clean, alignment etc and photos still coming out wrong - orange tinge to shadow areas, blue eyes washed out....
may be problem with waste ink tank....
When waste ink tank full it gives this kind of problem.replace the waste ink tank..or visit nearest canon dealers or service provider.. they solve u r problem by replacing waste ink tank.
if it helps
Rate me!
Jun 25, 2009 | Canon PIXMA MP960 All-In-One InkJet...
When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
Here are all the flashing explanations:
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
Canon PIXMA iP90 InkJet Printer Logo
78 people viewed this question
old marine
old marine
