Question about Bissell 16N5 Upright Vacuum
How to take apart the brush window - Bissell 16N5 Upright Vacuum
How do I remove brush bar housing to clean it?
You can't take it apart. Clean it and remove the debris from around the brush bar after removing the bottom plate. You can't remove the brush bar from the housing.
Nov 23, 2014 | Dyson DC28 Animal
Tip
What to do when your vacuum brush stops spinning
Household vacuums come in all shapes and varieties, but many of them are similar on the inside. There is often a brush running across the length of the vacuum's nozzle, and it spins as the vacuum runs to help **** up debris. But sometimes the brush will stop running, and you'll notice a severe decline in your vacuum's performance.
Usually when the brush stops spinning, it's because something inside the vacuum is binding it up. Dirt can get lodged inside, and hair can get wrapped around a shaft. If there is too much pressure, the drive belt can even snap.
You can usually see and clean the brush just by turning the vacuum upside down, but to get to the other internal parts you have to take the vacuum apart. On canister vacuums, this is usually pretty easy because it's just the nozzle that needs to come apart. Full-size vacuums can be taken apart as well, but the process can sometimes be more involved.
If you can get the nozzle or the vacuum's base apart and get to the parts inside, you should see the brush (which is part of a long shaft), a drive belt, and some sort of mechanism that drives the brush, which is commonly a paddle or a motor.
Hair can get caught up in any of these components and cause them to not be able to spin, as can dirt and other debris. If you clean all of the components out and put the vacuum back together, it should work just fine. The brush, over time, may become frayed or damaged, and the drive belt sometimes will snap, but otherwise a good cleaning will usually make your vacuum run as good as new.
on Jun 01, 2010 | Vacuums
Brush on riccar vacuum how to change clutch on brush
The clutch is part of. The rush roll. Remove the brush roll and take the clip off the end to take the brush roll apart.
Feb 16, 2013 | Riccar 8955 Upright Vacuum
Bissell Healthy Home Vacuum brush stopped working. The hose attachment works fine, just the brush on bottom. Without taking it completely apart, it shows no sign of blockage. Any suggestions? Or, will I...
You will have to remove the bottom plate to get at the brush. The drive belt either slipped off or broke, this will have to be replaced.
Nov 08, 2009 | Vacuums
Can't figure how to reassemble brush so it won't
there is a clip (sort of "U" shaped) that goes on the side this should take care of your problem.
Apr 16, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
May 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vav & Spin Scrub #F5899-100
Sorry it is not belt driven. There is a turbine that drives the brush. You have to remove the top cover to get to it. But if the motor smells hot, then you may have a problem with it also.
Apr 18, 2008 | Hoover F7431-900 SteamVac Vacuum
Spin brush not working anymore.
Is the shaft still on the brush block, if it broke off, then replace the block. if it is ok, then the turbine(#13) is most likely the problem. It is what drives the brushs. You may be able to take the turbine apart and clean it, if that doesn't work the replace it.
Mar 15, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Cleaning brush assembly on steamvac
Yes this does come apart. The clear plastic pieces clip into the black plastic piece, flat tip screw driver inserted into the gap can release the clips and allow for cleaning.
Nov 10, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Bissell 16N5 Upright Vacuum Logo
101 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
