Question about Uniden Cordless Phone
Would like to know how to set the time and date on my UNIDEN 2.4GHZ CORDLESS PHONE model TRU 3485 ?
  • 13 Answers
SOURCE: Uniden cordless phone....mod. # TRU 9280-2
The delete button is the one with the circle with a slash through it.  I checked the user manual online, and it should be the bottom right button out the 8 round buttons on the base (just to the right of the next button, right under "find hs").  Hope this helps!
Posted on Dec 25, 2007
SOURCE: How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Posted on Feb 05, 2009
SOURCE: retrieve messages from uniden 8885-2
As soon as your message starts, enter 0 and your pin (w/in 2 seconds). Then follow prompts. More specifics, see your telephone manual - you can go to www.retrevo.com/support/uniden-tru8885-2
See pg 64-65 and if you need to set pin, pg 25. Be blessed.
Posted on Feb 12, 2009
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
consultel1
  • 860 Answers
SOURCE: I have a uniden cordless phone model tru9480-3
With the phone in standby, press and hold [dnd] on the base. You will hear a confirmation tone and the [dnd] LED will go out.
Posted on Sep 20, 2009
Testimonial: "Thanks IT Worked"
Need to know what type battery for Uniden PowerMax 5.8GHz Digital Answering System Cordless Phone Model #: TRU 9480 793E 0206W. Phone was given to me and has no booklet. Thanks!
From the manual: To order headsets, additional handsets, replacement batteries, or other accessories, visit our website at www.uniden.com or call 1-800-554-3988, Monday through Friday, 8 AM to 5 PM, CST.
Another source for the battery is
http://www.batteriesplus.com/product/34648-RAYM182-High-Capacity-Battery/549-0/5275-Cordless-Phone-Batteries/130291-Uniden/TRU9480.aspx
You can download a copy of the manual at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/TRU9480om.pdf
Jun 20, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
Where is some documentation for a uniden powermax 2.4? I've lost my manual and cannot find voicemail setup or re-setting the time for this phone. thanks
You can download the TRU4485 manual at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/TRU4485om.pdf
If you have a different model, select it from the list beginning at
http://www.uniden.com/scat/cordlessphones_mnl
Jun 03, 2011 | Uniden TRU4485 Remanufactured Dual Handset...
Manual?
You can get that manual at http://manualfox.com
Just send them a request.
Jun 30, 2009 | Uniden TRU 3485 Cordless Phone (TRU3485)
Cannot find manuel ( just bought the phone) & I want to record a
It looks as though you might have a TRU model. You can find the model # under the bottom of the main base above the barcode next the manufacturer's date. Once you have found the model #, go to this link :
http://www.uniden.com/index/manuals_results.cfm?cat=1
Mar 18, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
UNIDEN cordless charger for india
UNIDEN DOES NOT SUPPORT SERVICE IN INDIA, TRU 9466/TRU9485 WILL ONLY WORK IN THE US AND CANADA. USING ANOTHER CHARGER COULD DAMAGE THE BASE.
Feb 16, 2009 | Uniden 2.4GHz Handset
Press 1 for English
Do you possibly have the phone set on Pulse dialing when your phone company only supports Tone (or vice-versa)? Hit Menu, select Global Setup, then Dial Mode, and see which is selected. Try the other and see if that fixes it.
Sep 30, 2007 | Uniden TRU9480 Cordless Telephone
Uniden TRU 448-2
Here's the link; http://www.amazon.com/Uniden-TRU-448-2-Cordless-Digital-Answering/dp/B000063KDW under "product details". Hope this helps :)
Sep 10, 2007 | Uniden TRU 448-2 Cordless Phone
Uniden Cordless Phone Logo
50 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
