Question about Philips Televison & Video
When first turned on, power cut off then on several times until "warmed up". Tv about three years old and this just started. Tried unplugging and resetting it.
  • 4,234 Answers
This is not usually an indication of a setting problem, rather a connection problem. While relatively rare, poor solder connections inside the set can cause this behavior. If you have experience with soldering, carefully open up the unit and look for connections that appear crystally or have rings and resolder them. This may resolve the issue. If not, then please update this with details about what is found.
Thanks,
Dan
Posted on May 18, 2011
Testimonial: "Don't dare take the tv apart but at least I now know if it continues or worsens, I may need to take it to a tv repair man. Thank you so much!"
Power-On Problem on a 46" Sceptre Flat Panel
The high voltage spike damaged electronic components inside your tv. Transistors and microchips are very sensitive to high voltage spikes even if they last for a fraction of a second. It can probably be repaired by a tv repair person but if the tv is several years old, it would be better to just buy a new tv. The cost for a new tv is much lower now than it was just a few years ago.
Feb 13, 2014 | Sceptre Televison & Video
LCT TV picture blurry with black smudges until it warms up
No easy way short of monitoring with a scope and or voltmeter, based on age of set I would first "look" at all the filter caps in the main power supply--bad ones when they get hot can regain some function:
Dec 09, 2012 | Televison & Video
I have a 50" Vizio plasma tv that is about 5 years old. Recently when I turn it on it cuts off or blinks. I have to turn it off and back on several times in order to get the picture to come on. I am s
Yes it's. Just bring it 2the nearst electronic shop for repair. T power my be spoile or some insect get inside n make it burn. It's ever happen 2 my tv also.
Dec 04, 2012 | Vizio P50HDTV20A 50 in. Plasma HDTV
I HAVE A 50' PHILIPS MODEL 50PFP5332D/37 FLAT SCREEN TV. I BLEW A BREAKER ON THE TV PLUG IN WITH A PORTABLE HEATER. TURNED BREAKER ON TV CAME ON WORKED FINE. TURNED OFF. 1HR. LATER A RED BLINKING LIGHT WAS...
HI:
This is a plasma unit and philips plasma's are nortorious for bad power supplys, your problem may very well be the power suppy in the television, it is possible you blew a low B+ fuse on the power supply. There is also a issue with the Y-sustain board failing in this model, If you open the back and looking at the unit from the rear the y board is on the left side of the unit and the PS is in the center. disconnect the Y-sustain power plug from the power supply and turn on the unit if the unit stays on with no red light then the y board is bad. it does the same then replace the Power Supply.
Mar 10, 2011 | Philips 50PFP5332D 50 in. Plasma...
Panasonic PT-61LCX65 turned off while I was watching TV. Won't come back on. "Lamp" light blinks once every 5 seconds. Tried turning it on several times per the manual instructions--no change....
Tv projection lamp life are over. Wow 6 years with the original lamp,what u want it last for ever.Replaced the tv projection lamp,will solved the problems.
Feb 25, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
Starts, idles and runs but quits after a few seconds of cutting
Check the air cleaner and muffler for plugging. One screw adjusts the idle stop (idle speed) position and the H and L jet screws set fuel mixture for high speed and idle speed mixture respectively. Turn both jet screws CW to stops (lightly) then back each out CCW 1-1/2 turns. This is a basic setting and should allow the engine to start and run. Start the engine and allow to warm up. Pull the throttle full on and adjust H CW until the engine starts to speed up, but 4-strokes. Correct adjustment is when the engine 4--strokes running free, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW until the engine idles fairly well, but allows the engine to 'follow the throttle'. Adjust the idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
May 17, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Timer light continues flashing; won't turn on/off
Could be an open internal fuse or power supply failure
Jun 25, 2017 | Mitsubishi WD-65731 65" HDTV
My Samsung 60 inch DLP TV turns its self off several times an hour. Eventually is stays on. What's the problem?
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.Have a bless one!
Apr 20, 2010 | Samsung Televison & Video
Sony KDF-E42A10 rear projection TV. Won't turn on.
Start by changing the lamp. If you got 5 years out of the old one, count your blessings, most folks only get three. The lamp is designed to be replaced by the consumer. Ebay will carry a replacement for you or you can get it directly from rivervalleyelectronics.net. They've got good prices. The lamp door is on the back. Its really easy, give it a shot.
Sep 07, 2009 | Sony KDF-E42A10 42 in. LCD Television
Panasonic PT-53TW53G
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Aug 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Televison & Video Logo
155 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
