1m =??mm - Office Equipment & Supplies
    Scholar:
  • 37 Answers
Hi Tim
1 meter = 1000 millimeters.
Posted on May 18, 2011
A list of abbreviations
The standard financial abbreviation for million is MM, e.g. $300 MM.
Most people will write $1M There is no standard abbreviation for million
Nov 05, 2013 | Computers & Internet
DoubleDown was giving away 1m chipsto loyal players. I did the word gifts on the page where you buy chips and it gave me the 1m chips. I started playing and all of a sudden they took the 1m chips away and...
Zynga Poker sent you an email regarding possible unauthorized access to your Facebook and Zynga Poker account. This email was sent to a**a@yahoo.com. We recommend changing your Facebook password immediately.
Please verify your account by carefully following the instructions in the email. Click here to resend email.
Message Code: CA1
Aug 11, 2013 | Evermoremedia DoubleDown Casino
B+q ndb-1m-25 stopped heating up, was working, now it lights up but no heating up what could this be
b+q ndb-1m-25
Looks like the formula for rocket fuel. Solid propellant.
A) What is it?
B) What does it belong to?
C) Are you aware you're in the Laptop PC category?
D) What time is it?........................(Just wanted to see if you were following along, lol!)
Post back in a Comment.
Regards,
joecoolvette
Apr 02, 2013 | Computers & Internet
Intel Cpu Pentium Dual-Core E2180 2.0Ghz Fsb800Mhz 1M Lga775 Tray Logo Problem with the Intel Cpu Pentium Dual-Core E2180 2.0Ghz Fsb800Mhz 1M Lga775 Tray I have no audio driver for my pc
every other detail...but...motherboard...assuming it has onboard sound.. google drivers for the make and model of your motherboard soundcard should be there somewhere.
Apr 19, 2011 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
I need to know if the specifications for the Perfomance Teknique ICBM-5712DX RMS total wattage is for both coils or per coil. The RMS total wattage rating is 500 watt
The 500W RMS total wattage is for both coils combined. If you want to get REALLY specific, all of the industry-specific specifications are as follows.
  • 12" Dual 4 Ohm Peformance Subwoofer
  • Power Handling:
    • Peak: 1000 watts
    • RMS: 500 watts
  • Impedance: Dual 4 ohm
  • Reinforced aluminum curvilinear cone woofer
  • Oversized butyl rubber surround
  • 5 spoke Die-cast aluminum basket
  • 2" Flat ultra excursion spider
  • Industrial Chromed Hex bolt retained T-Yoke
  • DC resistance (Re): 3.2 ohms each coil
  • Frequency range: 20 Hz-1.1 kHz
  • Fs:30 Hz
  • QTS:.526
  • QES:.614
  • QMS:7.698
  • VAS:56L
  • SD:.0491M
  • SPL: 89.58 dB 1W/1m
  • Xmax:16mm
  • Mounting Depth: 160 MM
  • Mounting Hole Dia.:282 MM
  • Mar 01, 2011 | Performance Teknique ICBM-5712DX 12in Car...
    Will this amp push 2 2000 watt subs?
    hope this helps.
    caution
    About Power supply wires (MRP-M1000 only)
    • 21mm2 is the minimum power and ground cable size
    that should be used to connect this amplifier. The
    length of these cables should not exceed 1m to assure
    safe operation.
    • If the length of the power and ground cables exceed
    1m, or if you connect more than one amplifier, a distribution
    block should be used with 33mm2 or 53mm2
    power and ground cables depending on the length
    necessary. Ensure that you install a correctly-rated
    in-line fuse on the power cable near the battery positive
    post.
    RMS Continuous Power (at 14.4 V, 20 - 200Hz)
    • Per channel into 4 ohms (?1% THD+N)
    MRP-M1000 ......................................... 600 W x 1
    MRP-M500 ........................................... 300 W x 1
    • Per channel into 2 ohms (?1% THD+N)
    MRP-M1000 ....................................... 1000 W x 1
    MRP-M500 ........................................... 500 W x 1
    Total MAX Power
    MRP-M1000 ............................................. 1900 W
    MRP-M500 ............................................... 1100 W
    S/N Ratio
    • IHF A Weighted, Reference: rated power into
    4 ohms .................................................... 100 dBA
    Input Impedance
    • RCA IN .................................................. 20k ohms
    • SP IN .................................................... 40k ohms
    Frequency Response (200Hz/ -3dB) ....... 20 - 200 Hz
    Crossover Frequency .......... 50 - 200 Hz (-24dB/oct.)
    Input Sensitivity (RCA IN) ............................ 0.2 - 4 V
    Dimensions
    • Width (Heat Sink/Footprint)
    MRP-M1000
    ......... 320 mm (12 - 19/32")/380 mm (14 - 61/64")
    MRP-M500
    ............... 210 mm (8 - 17/64")/270 mm (10 - 5/8")
    • Height ..................................... 60 mm (2 - 23/64")
    • Depth .................................... 242 mm (9 - 17/32")
    Weight
    MRP-M1000 ................................................ 4.2 kg
    MRP-M500 .................................................. 2.7 k
    Feb 04, 2011 | Alpine MRD-M1000 Car Audio Amplifier
    We have a plan for our 24m long driveway. in one section it shows that in 2500 long (2.5m) the gradiant ratio is to be 1:8, the next section 1500 is to be 1:6, 1960mm is 1:4,2500mm is 1:8, 1140mm is 1:40,...
    2.50m @ 1m rise : 08m run
    1.50m @ 1m rise : 06m run
    1.96m @ 1m rise : 04m run
    1.14m @ 1m rise : 40m run
    4.04m @ 1m rise : 1.85m run
    13.64m flat
    May 02, 2010 | Mathematical Technologies Inc. MTI Tristan...
    How to install 1m sub circuit board for pokemon fire red version
    Do you mean on VBA?
    You don't you press file then save it on slot 1
    Jun 04, 2009 | Nintendo DS Lite
    8 inch woofer blown need specs...OHM, Impedence and wattage
    John,
    Checkout JL Audio's 8" subs I'll leave specs at the bottom, if you want to look around for something cheaper check out this install I did on a Jaguar X-Type. The sub here is a good example of a free air application and you can look for a sub with the same features. Keep in mind however this setup is using a high power Coustic 10" sub and you only need to handle the stock amp- 25 watts. So you may not need such a beefy sub, but something close would be good. If your sub uses a small enclosure go with something like the JL listed below. Good luck and let me know if you need anything else.7a2e6d4.jpg -Dynami
    12855.jpg Reviews W1v2 Technologies Recommended Power Chart Tutorials 12856.jpg 8W1v2 DRIVER SPECIFICATIONS 8W1v2-4 8W1v2-8 buyitnow.jpg buyitnow.jpg Free Air Resonance (Fs): 34.55 Hz 36.60 Hz Electrical “Q” (Qes): 0.508 0.612 Mechanical “Q” (Qms): 6.260 6.000 Total Speaker “Q” (Qts): 0.470 0.555 Equivalent Compliance (Vas): 0.66 cu. ft. / 18.801 liters 0.63 cu. ft. / 17.87 liters One-Way, Linear Excursion (Xmax)*: 0.3 in. / 7.6 mm 0.3 in. / 7.6 mm Reference Efficiency (no): Efficiency (1W/1m)**: 83.86 dB SPL 83.58 dB SPL Effective Piston Area (Sd): 32.67 sq. in. / 0.0211 sq. m. 32.67 sq. in. / 0.0211 sq. m. DC Resistance (Re): 4.00 ohm 7.84 ohm Nominal Impedance (Znom): 4 ohm 8 ohm Thermal Power Handling (Pt): 150W 150W Driver Displacement: 0.02 cu. ft. / 0.571 liters 0.02 cu. ft. / 0.571 liters Net Weight: 6.3 lbs. / 2.9 kg 6.3 lbs. / 2.9 kg * Xmax specifications are derived via one-way voice coil overhang method with no correction factors applied.
    ** Efficiency (1W/1m) is not an accurate indicator of a subwoofer’s output capability and should not be used as a comparison to other subwoofers to determine which one is “louder”.
    acrobat.gif Click here to download the owner's manual (PDF). Click Here For Recommended Enclosure Specifications 8W1v2 DRIVER PHYSICAL SPECIFICATIONS
    12819.jpg Nominal
    Diameter
    Overall
    Diameter (A) Mounting Hole
    Diameter (B)
    Bolt Hole
    Circle (C)
    Magnet
    Diameter (D)
    Mounting
    Depth (E) 8.0 in. / 200 mm 8.54 in. / 217 mm 7.09 in. / 180 mm 7.85 in. / 199 mm 4.54 in. / 115 mm 3.85 in. / 98 mm 12864.jpg
    Apr 06, 2009 | OEM Systems Car Audio & Video
    59 people viewed this question
    jasbo
    jasbo
