Question about Health & Beauty
EI Need a electric motor for a electric wheelchair ramp .The motor is on a conversion 1996 dodge grand caravan built by VMI coversions. Please help me locate where I can buy a new one or a rebuilt one. erish4@sc.rr.com
    President:
  • 1,961 Answers
Try this link:
http://www.racepages.com/parts/starter/dodge/grand_caravan.html
If not from the list, try to be more specific with the electric motor.
Posted on May 18, 2011
Can a 2000 Dodge Grand Caravan be Towed with a Tow Dolly ?
As long as the front wheels are off the ground.
Aug 30, 2016 | 2000 Dodge Caravan
Installing handicapped ramp in 2000 dodge grand caravan need schematics
Can you take the van to a local family owned shop near by that could hook them up for you reasonably? Google the manufacture and contact them or take it too a dodge garage? The wiring from the motor should be very basic, like 1-3 wires and not costly or time consuming to hook back up. What brand lift do you have? The more info you give us, the more help we can be!
Nov 14, 2011 | 2000 Dodge Caravan
The front a/c blower does not work, all fuses are good. please help
J, I am sending you some info to read but it appears that the most likely cause is the blower motor relay. Give the following notes a read and if you need some more help give me a buzz... Best of Luck..
1996 Chrysler Town & Country 3.3L, Vin R 1996 Dodge Grand Caravan ES 3.8L, Vin L 1996 Chrysler Town & Country LX 3.3L, Vin R 1996 Dodge Grand Caravan LE 3.8L, Vin L 1996 Dodge Caravan LE 3.8L, Vin L 1996 Dodge Grand Caravan SE 3.3L, GAS, Vin R, Eng Cfg V6 1996 Dodge Caravan Sport 3.3L 1996 Plymouth Grand Voyager SE 3.3L, GAS, Vin R, Eng Cfg V6 1996 Dodge Grand Caravan ES 3.3L, Vin R 1996 Plymouth Voyager Rallye 3.3L Customer Concern: Front blower does not work; no power to it. Fuse is OK. Tests/Procedures: 1. At the blower motor, there is a Dark Blue wire. This wire should have battery voltage whenever the key is in the "on" position. Power for the blower motor comes from the blower relay.
2. Access the front blower relay, it is located on the driver's side under the dash, near the junction block. There will be four wires going to it. The Dark Green wire should have battery voltage all the time. The Dark Blue wire is going to the motor. The Black/Orange wire should have battery voltage with the key in the "on" position. The Black wire should be grounded at all times. On this circuit, the relay is energized whenever the key is in the "on" position. Potential Causes: Front Blower Relay
Front Blower Relay Wiring
Heater Ventilation Air Conditioner (HVAC) Control Head
Tech Tips: The front blower relay is located under the dash, on the driver's side. It may be necessary to remove the junction block (fuse and relay box) in order to see it. Diagnostic Codes: None
Aug 28, 2011 | 1996 Chrysler Town & Country
1996 dodge grand caravan 3.3 will turn over but will not crank seems to be no fire to the plugs
It is hard to say with the info posted, it could be related to a number of issues. If you have verified that there is no spark to the spark plugs, it could be the CPS (crankshaft position sensor)
Feb 23, 2011 | 1996 Dodge Grand Caravan
Cam shaft sensor
You always need to check the wiring system when you get a code and not just throw parts at it,I'm sorry this happened to you.
Dec 23, 2009 | 1996 Dodge Grand Caravan
My van passenger power door will not open or shut and it has a VMI northstar conv ramp
check your passenger side frount door to be unlocked all so by hand unlock the slide door then try it if somethings in the track and the door motor hits it it can make it quit working so clean your lower ttrack the if it opeans slow or you have to help opean it then its possable its a door motor cluch assy. these are known to gobad so all so on the B piller there is contackts clean them all elese fails get a hold of me
Jun 30, 2009 | 2004 Dodge Grand Caravan
96 dodge grand caravan help me please
Check MAP sensor. If PCM gets wrong data from MAP sensor it should offset ignition timing and/or make fuel mixture too lean or too rich.
Nov 05, 2008 | 1996 Dodge Grand Caravan
Health & Beauty Logo
20 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
