Question about Maytag 24 in. MDB5651A Built-in Dishwasher
Dishwasher will fill up with water but wont clean dishes.
  • 4,323 Answers
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps... Please post back if you need more information.
Daniel
Posted on May 19, 2011
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
Dishwasher does not clean dishes completely model # kudso3ftss3
Hi
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Mar 24, 2011 | KitchenAid Dishwashers
Dishes don't get clean and are never dry.
Hi
Feb 20, 2011 | Whirlpool GU1200XTLS Stainless Steel...
Dishes aren't cleaning. Filling with water, rinsing then draining, refilling with water -- hot, soap released. When dishes come out, barely clean. Used to work like a charm... Thoughts?
Hi
Feb 16, 2011 | Miele 23 in. Novotronic G841 Built-In...
Spots are left on the dishes after washing. Dishes don't look clean
Hi
Daniel
Nov 26, 2010 | Kenmore Washing Machines
It' no longer cleaning my dishes
hello,
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
thanks.
Oct 23, 2010 | Dishwashers
Our dishwasher was cleaning just great...then the next washing...no clean dishes. We thought we forgot to run it, so reran, and the same thing...dirty dishes. Any ideas?
Hi
Daniel
Oct 03, 2010 | Amana Dishwashers
Hi, My whirlpool dish washer does not clean the dishes. Robin
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it’s kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Daniel
Aug 07, 2010 | Whirlpool Dishwashers
Does not cleans dishes
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 11, 2009 | GE Dishwashers
Maytag 24 in. MDB5651A Built-in Dishwasher Logo
127 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
