Question about Canon Selphy ES3 Thermal Photo Printer
I have a selphy es3 printer and at present have a paper jam. I have tried to remove the cartridge but it will not come out. What can I do
  • 29 Answers
SOURCE: Canon PIXMA MP160 showing paper jam, but none
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Yesterday someone replied to my problem, i tried it this morning and its fixed 1st time.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving PUSH it through! and hey presto it worked for me, everything printing fine now
Posted on Mar 02, 2008
SOURCE: "Clear paper jam" error, but there is no jam!
try open the gear mover paper is slip. i have fix the problem same.
Posted on Apr 06, 2008
SOURCE: unable to resolve 'cartridge has been changed' error message
turns out the wrong paper size was selected in the print setup. I set it to Postcard (4x6) and it began working perfectly again. Hooray.
Posted on Jun 02, 2009
  • 13433 Answers
SOURCE: Canon MP140 paper jam error with no paper jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 03, 2009
  • 13433 Answers
SOURCE: Canon MF3240 Paper Jam - No Real Jam
try this
alternative :
My ink cartridge is stuck. I tried to turn it off and on again and to push the paper leveler down but nothing helps.
My Canon Selphy CP740 start to jam ink ribbon and ink - Fixya
www.fixya.com/support/t10013530-canon_selphy_cp740_start
Jan 4, 2013 - My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. ... Question about Canon SELPHYCP740 InkJet Photo Printer .... SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7.
Selphy CP740 - Catridge Eject Solution - YouTube
? 0:46
https://www.youtube.com/watch?v=9TqHINBmbgQ
Sep 11, 2013 - Uploaded by Mahadhir Shaarani
Selphy CP740 - Catridge Eject Solution. Mahadhir Shaarani ...Replacing Ink for Canon Selphy - Duration: 6:23. Jenuine Crafts... How to Print Different Sizes with the Canon Selphy Printer - Duration: 12:08. Janet Wakeland ...
Color ink cassette stuck in canon selphy 'Canon SELPHY ...
Feb 03, 2016 | Canon Selphy Cp800 Compact Photo Printer -...
My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. Printers has a good connection to PC, start to print but after the first paper pass the...
I've just had this same problem with my Sephy 740. Nothing helped until I disassembled the printer and realizing the small gear wheel (not visualized) at position in the red circle had loosened. Remounting the gear wheel on the shaft with a tiny drop of Blue Loctite and letting dry three hours, reassembling the printer and turning it on fixed the problem.
Aug 06, 2011 | Canon SELPHY CP740 InkJet Photo Printer
How i can clean my printer selphy ES30 also how to solve an error paper jam
For Paper jam:
• Press
(BACK) to eject the paper.
If the paper is not ejected, turn the power off and turn it on again. If the printer fails to eject the paper, contact a Canon Customer Support center for assistance. Other solution here: http://canoncanada.custhelp.com/app/answers/detail/a_id/10212/~/error-messages-displayed-on-the-screen-(selphy-es30) For cleaning try local canon provider.
Dec 12, 2010 | Canon SELPHY ES30 Thermal Photo Printer
Paper jam
To fix this kind of error, remove the ink cartridge and turn the printer upside down and gently shake it.Check if anything comes out.If nothing goes, or you can't hear anything rattling around, get a piece of card stock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside.The teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
Thank you !!
Jul 14, 2010 | Canon SELPHY DS810 InkJet Photo Printer
My company has an Selphy CP740. The printer will
bring it in service centre, possible beside it dusty roller of the seizure of the paper
Dec 17, 2009 | Canon SELPHY CP750 Printer
I get paper jam notice, remove jam and restart. There is no paper jam,when I try to print only half of picture prints
Make sure there is plenty of room behind the printer, the paper is drawn in the front and sticks all the way out of the back before it starts printing, it will show a jam if it can't get all the way out of the back slot.
Aug 28, 2009 | Canon SELPHY DS810 InkJet Photo Printer
Selphy ES1 printer switches on,
remove all the connection go to control pannel printer and default ur Selphy Es1 printer
Jun 18, 2009 | Canon SELPHY ES1 Thermal Printer
Ink casette error
If you just put new cartridges in the printer, check to make sure you removed all of the protective plastic wrap that may be required to remove prior to printing.
Also, check the cartridges by removing and replacing each one. make sure there is no obstruction, or torn papers, that may cause a jam or other problems.
Also, after verifying all that. Use the printer utilities to run a test. Hopefully that should fix or clarify if there is any other problem.
Hope that helps..
~enov8
Mar 07, 2009 | Canon SELPHY CP760 PHOTO Thermal PRINTER
Canon Selphy ES3 Thermal Photo Printer Logo
74 people viewed this question
old marine
old marine
