Question about DeLonghi Heating & Cooling
Where do i find the nearest gas tech nation to replace a gas valve in my heater reading other comments about this problem it seems it is same problem have to hold down the knob to keep the flame going i live in Hamilton is their some i can go to , to fix this problem
    Brigadier General:
  • 4,736 Answers
The problem more than likely is not the gas valve, it's the Thermocouple or Thermopile that has failed. Replacement of the gas valve is not necessary. The Thermocouple and the Thermopile (also called Thermo-generator or Pilot Generator) are safety features designed to stop the gas flow if the pilot light flame goes out. When you continue to hold it down, you are overriding them. But, the flame goes out when you release it. Right?
Be glad it's not the Gas Control Valve. It cost more than you want to spend. Whereas, the Thermocouple or Thermopile are comparatively inexpensive. Any qualified gas technician can replace either for you.
Hope this helped you. Please let me know. Thanks.
Posted on May 18, 2011
Pilot won't stay on Williams wall furnace 4007732, changed therocouple already
Before replacing the gas valve, make sure that the limit switch is not tripped. I have seen techs wire the limit in so that the pilot will also shut off. The limit is usually at the top of the heater or mid way down, behind the casing. As for replacing the gas valve, you can replace it with a universal combination gas valve, they have multiple brands that can match pretty close to your valve. They can run over $100.00 easily and here, you have to have a contractors license to buy one. Hope this helps! Happy Holidays!
Dec 06, 2013 | Williams Heating & Cooling
How do I light the pilot
1) Open following link to identify type of gas control and read printed 'how-to-light-water-heater' instructions for each different gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Same printed instructions should appear on side of tank by gas control valve, and inside product manual.
3) Add a comment March 2013 and describe gas control valve.
Mar 13, 2013 | Reliance & 40 Gal Mobile Home Water Heater...
Hot water heater womt light, flammable vapor sensor code
Most likely: Combustion chamber got too hot because air intake is clogged with dust, causing less air to flow upward through vent pipe ... the slowed flow of air caused combustion chamber to overheat.
What brand and model water heater?
Look at label on side of unit and add comment.
Otherwise call service tech to repair/ replace water heater and clean arrestor screen (air intake) and replace or reset parts as needed, depending on model number and brand water heater.
AO Smith, Bradford white, and Rheem are main manufacturers.
Each has slightly different repair protocol, and each gas control valve can also be different. So more information is needed.
Identify gas control valve:
Rheem TRD/ FVIR glass vial
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
How to remove combustion parts to inspect for Rheem glass vial and clean arrestor screen located under combustion chamber:
http://waterheatertimer.org/How-to-replace-thermocouple.html
Sep 30, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
My Rheem water heater is giving a ECO failure, How can I fix this?
Question posted under Rheem water heater.
Model number and gas valve are unknown. Add a comment.
Following information applies to typical tank-type gas water heater, and does not apply to tankless water heaters, boilers, indirect heaters, solar water heaters, etc or for electric water heater.
Electric water heater ECO is located on upper thermostat.
Open top cover and ECO can be reset by pushing in red reset button,
Or ECO can be replaced by replacing thermostat. Add a comment.
Open following link to see typical tank-type gas water heater ECOs:
http://waterheatertimer.org/images/Intellivent-ECO-900.jpg
http://waterheatertimer.org/images/Typical-gas-valve-500.jpg
The ECO will trip at 180-200 degrees F.
This happens when the thermostat fails, then the burner stays on, and the water will continue heating.
With most water heaters, the ECO is one-time use device and the gas control valve is replaced.
Some water heaters have resettable ECO, but the overheating problem has to be solved.
Each water heater is different.
Contact Rheem or read manual for correct procedure.
If you have intellivent gas control valve, open following links for typical service manual:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
http://waterheatertimer.org/pdf/Intellivent-service-manual.pdf
More resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 30, 2011 | Water Heaters
The pilot light is out on the water heater. It will not re light using the posting directions. this happened a while ago and I called a tech. They were able to easily fix. There is some little thing...
Better description is needed. Add a comment.
Do you have tank or tankless water heater?
What brand heater and what model shows on label?
If tank water heater, what does gas control valve look like? Is it electronic?
Open following link to help identify tank-type gas valve.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
Does pilot light start up and not stay lit, or is there no flame whatsoever?
What color is the flame?
Are you using piezo igniter or a match to light pilot?
Is there a power vent sitting on top of unit?
What happens when you get more fresh air to unit?
1) Maybe the thermocouple is bad. Or thermocouple is mis-aligned and not sitting in the flame.
2) Probably the technician should have cleaned the combustion parts.
3) Tank-type and tankless water heaters require cleaning on a yearly or semi-yearly basis. This action prevents lighting problems, and help prevent ECO events and that require replacing gas control valve.
Cleaning and general service including cleaning burner, cleaning air intake if that applies, checking for proper venting and vent obstructions, adequate air supply, backdraft, testing thermocouple etc.
4) IF you have tank-type water heater, and do not have electronic gas valve or power vented water heater, the following troubleshoot walk-thru is very good:
http://waterheatertimer.org/pdf/Pilot-outage-troubleshooting.pdf
Example photo showing parts for gas control valve.
http://waterheatertimer.org/images/IMG_9146-gas-control-thermo.jpg
Add a comment for more help
Sep 13, 2011 | Water Heaters
Model #22v30FN serial# rhu08898u6983 mfg date 20 aug 2009 waterheater won,t light (installed sept 2009)
Gas water heaters are a huge field:
More information is needed for correct do-it-yourself answer. Add a comment and include what steps you have taken and what you observed at the pilot light. Include description of gas control valve.
The combustion parts may need to be cleaned, the thermoscouple could be bad, misaligned thermocouple, the system locked out from FV flammable vapor event, or overheating caused ECO energy-cut-off to trip, or air in gas line, low gas pressure, or dirty air intake, bad venting, improper venting, bad gas control valve, negative pressure, tight house, lack of combustion air, hot attic, exposure to chemicals in air, rusted parts, etc.
Add a comment any time.
Or contact Rheem at 1-800-432-8373
Or continue reading to find correct resource:
You have Rheem 30 gallon ultra low-nox gas water heater.
Knowing the gas valve is necessary for troubleshooting.
The 40 and 50 gallon version of this water heater have electronic self-diagnostic gas valve as shown on following link.
http://www.rheem.com/product.aspx?id=F4AE5B83-899F-4AC0-B09D-22A6770BE799
Open following link to identify gas valve, then add a comment and describe which gas valve you have.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
Open following link for general do-it-yourself resources, with reading resources, service manuals, images that illustrate cleaning and different gas water heater parts
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 13, 2011 | Rheem Water Heaters
New gas bottles installed but hot water not working
You posted under Bosch tankless water heater.
The suspect is probably gas supply, gas valve, or gas related part inside tankless unit.
Before calling service technician, open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Apr 02, 2011 | Bosch & Tankless Water Heater
? Replacement part for an obsolete Williams gas valve P100172A
Hi try national energy they should be able to tell you the right valve for this , the thermopile should read between 500 and 300 mille volts
Feb 10, 2010 | Heating & Cooling
Gas stops flowing when I release the knob after lighting
you have to hold for 30 secs to minute once flame is lit if it is like more gas ignition systems
Feb 07, 2010 | Uniflame 200209 Open Flame Patio Heater
Heating & Cooling Logo
113 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
