Question about Pitco Frialator SG14 Deep Fryer
When the pilot light button is released the flame goes out. (pitco propane fryer) - unsure of model number as data plate is worn. Does the thermopile need replacing ?
  • Pitco Frialator Expert
  • 683 Answers
Try first to clean the thermopile. If it has accumulated soot/ carbon, it will not sense enough heat from the pilot flame to generate small amount of electricity to energize the pilot valve and main valve of gas valve.
Posted on May 19, 2011
Trying to light the pilot light on deep fryer when i push button in it lights but when i let go of button pilot light goes out what am i doing wrong
If the pilot flame does not hold after releasing the button for at least 20 to 30 seconds, try to clean the thermopile and tighten all wiring connection on gas valve, thermostat and hi limit the repeat the process. The thermopile must be heated by pilot flame in order for it to generate small amount of voltage to open the pilot valve.
If this does not correct the problem, try replacing the thermopile.
May 24, 2011 | American Range AF45LP Deep Fryer
I have a pitco 35c fryer the pilot light will light but the flame is very low it goes out when i release the controll the pilot light adjustment has no effect on flame i have the right amount of fuel...
Check and clean the thermopile, it is the cylindrical piece of metal standing behind the pilot assembly.Try also to tighten its wiring connections to the gas valve and high limit.If it does not correct the problem, replace the thermopile.
Apr 06, 2011 | Pitco Frialator 35CS Deep Fryer
My fryer model SRTG LIGHT THE PILOT BUT WON'T LIGHT THE MAIN BURNER
check if the thermopile (cylindrical metal standing behind pilot assembly) receives enough heat from pilot flame. if it does, you need to replace the thermopile.
Mar 30, 2011 | Pitco Frialator SG14 Deep Fryer
Pilot light keeps going out! Will not stay Lit.
Check if the the gas pressure is sufficient (as stated on unit's nameplate). Check if the hi limit device is good. Check also if the thermopile (cylindrical metal with two wires standing behind the pilot hood) is receiving enough heat from the pilot flame. The voltage generated by thermopile should be 500millivolts in order to open pilot and main valve. If there is 500millivolt on gas valve thermopile and the pilot flame does not stay lit, you have to replace the gas valve. If the thermopile is glowing red and the voltage generated does not reach 500 millivots, you have to replace the thermopile.
Jan 18, 2011 | Pitco Frialator SG18S Deep Fryer
I have a 40c+ss pitco fryer.the pilot will go out at random times.Could be 1hr or 24 hrs after it is lit. The gas valve has been change, and the thermalpile has been replaced.
Check if your pilot flame sufficiently heats thermopile during operation and make sure also that it is free of soot or any form of dirt, thermopile generates small amount of electricity to energize pilot and main valve of the gas valve for pilot and main burner operation. This electricity passes through hi limit mechanical contacts. Hi limit on fryers act as safety device which will shut down pilot and burner flame when oil temperature reaches 450F.
If your fryer is set at 350F and over shoots up to 450F (which will trip hi limit and shut down pilot and burner flame), the thermostat is not good, but, if hi limit trips on temperature much lower than 450F, hi limit is bad.
Nov 12, 2010 | Pitco Frialator 40CNG Deep Fryer
My pitco 28lb countertop gas deepfryer conv to propane it will l
Check if the flame quality of the pilot is good. Small amount of voltage generated by thermopile used in energizing pilot main valve coil during fryer operation relies on the quality of pilot flame, also, the thermopile itself should be free of soot or any form of dirt in order for it to absorb the heat from pilot flame.
Check also the gas pressure, it should meet the gas pressure required on the nameplate.
May 24, 2010 | Pitco Frialator SG14 Deep Fryer
Pitco frialator (propane)
Better check the incoming gas pressure first, it should match the requirement as stated on the nameplate. Low gas pressure will make the pilot flame small until it could not heat up the thermopile which will shut both main burner and pilot flame.
Apr 11, 2010 | Pitco Frialator SG18S Deep Fryer
Pitco rtg 14 gas pilot goes out
Sounds to me the thermopile (thermocouple) is at fault, it's a safety device to detect if the pilot flame is alight or not. If the pilot should go out for any reason, the thermopile will detect this & shutdown the gas valve (ie the unit will cease to operate).
A new thermopile should solve your problem. It's not a task I would attempt yourself if you are in any doubt.
Mar 05, 2010 | Pitco Frialator Kitchen Appliances -...
Pitco fryer pilot out
if you changed the thermopile and still have the same problem make sure that the sensing bulb is directly over the flame. If it is and the thermopile is installed correctly the next thing would be the gas valve.
Hope this helps
Jun 19, 2008 | Pitco Frialator 35CD Deep Fryer
No Pilot Light
This device actually uses a thermopile it is part number P5047541. There are two things to check here ensure that you have had the right part installed be verifying the part number and also check that the sensing end of the thermopile is directly in the path of the flame.
May 19, 2008 | Pitco Frialator SG14 Deep Fryer
Pitco Frialator SG14 Deep Fryer Logo
262 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
