Question about Dell 17" Monitor
Looking for information on repairing a dell monitor model #L17BNS. It simply died. I cannot find any info on that model on the internet anywhere.
  • WTF Chuck.....
    WTF Chuck..... May 18, 2011
    Does it have a service tag number on it?
  • 3 Answers
I would recommend replacing the monitor, because it is usually cheaper to than repairing one. If for some reason you need to repair this particular monitor you can look up guides on general monitor repair. Most monitors run on the same preciples with just varying shapes and sizes of parts.
Posted on May 18, 2011
Power supply circuit diagram of Dell 23.5” ST2320LF Widescreen LED Monitor
Sorry that type of info is only made available to service and repair shops.
Jan 25, 2017 | Dell Computers & Internet
HOW TO RESEAT DISPLAY CABLE THRU HINGE
The solution is dependent on the model you have. There was no mention of that so go to the information I am sending you to a dell website. Dell does allow users to find the service manual to the correct model and info... Go to the site and choose the proper model and look for the service manual, or simply add the "service tag number" from the bottom the the laptop it is the long white tag...
http://www.dell.com/support/home/us/en/19?c=us&s=dhs&cs=19&l=en
Feb 13, 2013 | Dell Inspiron Computers & Internet
Dell model no E198FPf LCD Monitor has agreen light but wont turn on
Your problem is caused by a failure of the filter capacitors in the power supply board, this is a common issue on LCD monitors. Here is a link to repair information for this model. You can repair the monitor by replacing the filter capacitors.
http://www.ccl-la.com/catalog/product_info.php?products_id=195
Jan 04, 2013 | Dell E172FP 17" LCD Flat Panel Monitor
E173fp screen black
The most common problems with these units are caused by bad capacitors in the power supply board. Here is a link to several repair guides that cover the different E173FP models. You can determine which model you have by looking at the last letter of the model name it should either be c, f, or b
http://www.ccl-la.com/blog/index.php/category/monitor-repair/dell-monitor-repair/
May 29, 2012 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FPc monitor worked fine yesterday. Today, the monitor only stays on for a split second and goes blank. The power light stays green. If we shut off the monitor using the power button and wait 10 to...
The power supply in the unit has died. This is a very common problem with this series of monitor after 2-3 years of use. If you can solder then you should be able to do the repair yourself. Check out our step by step repair guide posted on our site at: www.ccl-la.com Our guide gives parts values and location information as well as how to open the unit up. If you don't feel like doing the repair we also offer repair services, see our web site for details.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 31, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
My monitor keeps going into power save mode
Its not power saver mode, when the display goes black and the power light starts flashing that is a good indication that the power supply is about to die. The Dell E172 monitors are noted for this problem. We have step by step repair guides posted on our web site at: www.ccl-la.com Click on the monitor repair link. The Dell E172 series actually has several sub models, check your specific model, the sticker on the back will have either E172FPb, E172FPc, E172FPf. We have guides for all 3 versions posted.
Buddy
Corporate Computer
www.ccl-la.com
Dec 30, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Display dies 3 seconds aafter Power on
http://josepino.com/other_projects/?howto-repair-dell.jpc
This is one soution, many more on the net.
You got parts to fix inside the monitor. Inverter problems. The internet is full of this problem. Some say that even if you replace the bad parts, mostly 2sc5707 transistors, you must find out why they are blowing. Many have replaced the parts only to find out that in a couple hours, the parts are bad again. Solutions range from solder joints, transformers, and other transistors.
Good luck, I'm fixing one as soon as the parts arrive.
Gary
Aug 17, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Circuit diagram
i need circuit diagram of 107e61/94 model.
Feb 19, 2008 | Philips 107E61 17" CRT Monitor
Dead dell flat screen lcd model E151FPb
First find out why you need to change this transistor, if it is shorted or open then replace it , but be carefull when you substitute parts which could create havoc, to check the spec's of these to components look up the 2n7000 note the specs and see how close the 2n2222 relates to , my recommendation is to get the original.
Jan 04, 2008 | Dell E153FP 15" LCD Monitor
Dell E173FPc 17" LCD Monitor Problem:
Although similar, this monitor and the associated repair is different than the "b" version. The link above is good to follow for finding out how to open your case but the actual repair is different. If you have minor soldering skills (really the de-soldering is the hard part) and can use a phillips screw driver you can make this repair.
I contacted Tom at a link I found on the "b" site and he sent me the typical components to fail for the "c" monitor. $20 and $1.35 for shipping. The site looks to be down now so I'm not sure if this is temporary or he's stopped selling parts. He is also willing to fix the board if you send it to him. Here's what you need to do:
Replace C922 and C923 with 1000uF 35V caps
Replace c924 and C925 with 470uF 25V caps
Re-solder L201 and L202 with fresh solder.
I did all of the above and the monitor works perfectly. When you take the monitor apart make sure you note where the blue and pink wires go (you'll know what I mean when you get to that stage). The connectors are identical and it would be easy to forget which way they were installed.
Sep 16, 2007 | Dell E173FP 17" LCD Monitor
Dell 17" Monitor Logo
130 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
