Question about Midea MDC-45AE Dehumidifier
How to replace or clean the filters also im trying to find a manual for this humidifier.
    Brigadier General:
  • 4,736 Answers
To remove and clean the filter: Turn the unit OFF & unplug it. Remove the water bucket and set it aside. Just under the front of the dehumidifier where you removed the bucket you will see a plastic handle. Pull down on it gently and filter will come out. Wash it with warm water and dry thoroughly, before reinstalling it in the dehumidifier. It is recommended that you clean the filter a minimum of once every 2 weeks.
As far as an Owners Manual is concerned. The following link will take you to it and you can download and print it for future reference.
http://shopping.netsuite.com/s.nl/c.618686/sc.10/category.44/.f
Hope this helped you. Please be kind enough to let me know. Thanks.
Posted on May 18, 2011
Testimonial: "Yes the solution reply was very helpful, thank you guys."
  • Beasty S
    Beasty S Jun 06, 2015
    Thanks so much. I had trouble finding the filter as I bought it second hand.
How do you clean the air filter?
The cleaning of Dehumidifier Air Filter is very simple, Air Filters are washable. Just remove the backside part of the device and take out the air filter. Wash it with water and fix it.
https://www.vackerglobal.com/divisions/dehumidifier-humidifier/desiccant-dehumidifier/
Feb 20, 2016 | LG Dehumidifiers
My AprilAire 600 humidifier drips water from the bottom of the unit. I changed the filter and cleaned the parts. Could it be the hose running to the condensation pump that might be the problem?
its going to drip when it is off,it has built up humidity and has nowhere to go,leave it running and let it cycle by itself or cause damage to the system
Jun 24, 2015 | Aprilaire 600m Whole-house Humidifier With...
I have the Kenmore 14 gallon whole house humdifier. The humidity level only goes up to 30 even though I have it set to 45. I changed the filters,cleaned the unit and tried unplugging but it did not make a...
My suggestion is to get an additional humidifier and run both. It sounds like it is at capacity. This was a cold winter and the additional heating put a large demand on the humidifiers.
Feb 27, 2014 | Kenmore 14 Gallon Humidifier
I have a sunbeam 1387 warm mist humidifier. I need to know how to clean scale from the filter. It looks like it can be taken apart. Can it?
Actually, Carol, it shouldn't be necessary to take the unit apart. Mix a 50/50 solution of White Distilled Vinegar and Bottled Distilled Water (enough to fill the tank). Pour the solution in and allow it to sit overnight. Then empty the solution and fill the tank with Bottled Distilled Water. Turn the unit ON and allow it to run for 1 hour. Then empty any remaining Distilled Water. Doing all the aforementioned, should have not only cleaned the filter, but also the unit itself. If you use Bottled Distilled Water in the future, rater than tap water, the filter and the plumbing of the unit will stay clean longer and will require less maintenance.
Hope this helped you. Please let me know. Thanks.
Jun 26, 2011 | Sunbeam Warm Mist Humidifier Dehumidifier
Do these humidifiers have a filter that needs cleaning?
Yes, they do. The filter is located behind the louvers on the front. To remove it for cleaning, grasp the Filter Handle on the right side of the unit, on the same level as the louvers and pull it out. Clean the filter with a vacuum cleaner or luke warm water and a mild detergent. Thoroughly dry the filter before reinserting it.
If you have misplaced your Owner's Manual, I have included a link to it, that you can download and print for future reference. http://www.haieramerica.com/en/asset/product/4ba7175e54 Read over it and follow the suggested Routine Maintenance Guide.
Jun 02, 2011 | Haier 45-Pint Dehumidifier
No water is collecting on 2 year old lg humidifier
If when you turn your dehumidifier on the compressor runs then you should get moisture. Dehumidifiers work on the same principal as refrigeration. There is a bad control switch or the compressor start relay or capacitor is defective. If compressor runs and there is no effect then that is another problem. The filter should come out the front where the air goes in front and the filter should be washed by hand in warm degrease detergent water, dry and replace. If the disposable type filter I will help you contact LG.Thanks, Sea Breeze
Jun 17, 2009 | LG LHD45EL Dehumidifier
How to clean it
check the manual, it will be described there. if you don´t have one, ask here: http://manualfox.com/link/sunbeam.htm
May 19, 2009 | Sunbeam Warm Mist Humidifier Dehumidifier
Midea MDC-45AE Dehumidifier Logo
373 people viewed this question
Top Midea Dehumidifiers Experts
J.D. Browning
J.D. Browning
jasbo
jasbo
 Russ Hill
Russ Hill
Are you a Midea Dehumidifier Expert? Answer questions, earn points and help others
