Question about Omega Sewing Machines
I have a Model 600 Omega and I can't seem to get
SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
Posted on Jan 24, 2008
Trifect7
  • 57 Answers
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Posted on Mar 08, 2008
  • 19 Answers
SOURCE: Needle/Bobbin issues with Bernina Deco 600
Jim!
Perfect phrasing of the question, you have all the lingo/parts down pat!
First make sure your new needle is straight, then check to make sure it lines up in the center of the hole in the stitch plate.
There is basically a 1/2 sheet of papers (we use the fine waxy sticker backing paper as our guages don't fit well .1mm! ) distance between the hook and the needle.
Rotate your hook so that it is aligned with the needle in the center position, there should be 2mm between the top of the needle eye and the bottom edge of the hook.
Posted on Jan 03, 2009
  • 16 Answers
SOURCE: Breaking needles
It depends on how thick and strong your needle is- try getting a stronger or thicker needle and see if it works. Or it could just be the machine, something might be broken inside
Posted on Jan 17, 2009
  • 9 Answers
SOURCE: Kenmore sewing machine 385.1960180, problem with needle centering
That sounds like it's definitely an internal adjustment. The machine will need to be opened up and the left/right adjustment taken care of. Is this machine one that you can open the top easily, or is it the type that has the front and rear shell?
Posted on Feb 21, 2009
How do I adjust the needle position for straight sewing?
The stitch Width selection regulates straight-stitch or zig-zag width. Needle position does not determine straight or zig-zag. Needle position just determines whether the needle's home position is center, left, or right. Needle position can be used with straight or zig-zag stitching.
Jul 03, 2016 | Sewing Machines
Viking 1+ Horizontal movement quit working after needle hit something
it sounds like you knocked the machine out of time & it will have to be taken to a
sewing machine shop to be retimed
Apr 26, 2012 | Sewing Machines
Needle/hook timing is off
1. Remove bobbin case 2. Unthread machine 3. Replace needle making sure it is all the way up in needle shaft and tighten screw 4. Set for straight stitch sewing 5. Position needle bar at Center 6.Roll up a towel and gently lay machine back on it. 7. Remove shuttle race ring 8. Turn handwheel SLOWLY toward you until needle reaches it's highest point and travels just 1/16" 9. Point of hook should be directly BEHIND the needle OR At LEAST 1/16" or tad above that measurement. 10. As hook passes needle, it should be slightly ABOVE the eye of the needle If timing seems good at this junction, you can carefully wipe the hook with alcohol on a clean, lint-free cloth (old T-shirt makes good rag) MAKE SURE YOU ARE CAREFUL BECAUSE HOOK POINT EXTREMELY SHARP! ALWAYS SET POWER SWITCH TO OFF POSITION/UNPLUG -- Never panic or toss machine across floor because you can probably determine that it's just a matter of rethreading or a minor adjustment. Hope this helps! Jimmy
Mar 30, 2012 | Sewing Machines
My needle is out of line. it is to the left of center on the straight stitch mode and will not connect with the bobbin thread and will not sew.
Hello
You bent the needle guide that holds the needle. I rather doubt if you'll be able to repair this yourself.get your machine to a repair shop fast
Aug 01, 2011 | Brother Sewing Machines
I cannot ser a straight stitch with the needle in center position. The manual does not state how to adjust needle position (left, center, or right). Because the needle is in the left position and the...
Some machines are not designed to sew the straight stitch with the needle in the center position. Some are left or right position to do that and it is simply the way they were designed. Linda at Relics
Jul 04, 2011 | Husqvarna Huskystar 215 Sewing Machine
I have a Kenmore model 1690. The needle when it goes down does not hit the hole in the foot plate. It comes down too far to the left of the opening, making it impossible to use the machine. I have...
This machine, when you have it on straight stitch, will sew with the needle to the left. If it's hitting the pressure foot, you may have the wrong pressure foot on the machine. If it's hitting the needle plate when you have the pressure foot removed, it's possible you have set for zig zag and you have a straight stitch needle plate on the machine. I believe this machine came with 2 needle plates. One for straight stitch, and another for zig zag.
May 03, 2011 | Kenmore Sewing Machines
Pfaff 7530/ electronic problem?
Where has it been for ten years? This could have a big affect on an electronic sewing machine.
Take the machine in to a sewing machine shop for service.
Feb 22, 2010 | PfaFF Sewing Machines
Need manual for Kenmore sewing machine, model 148-600.
hi! there, since there no model you can relay on this basic set up an old mechanical sewing machine,set your upper thread as shown65a8465.jpgfollow the red loop thread from sppol to needle,then lift needle cover plate take bobbins and follow bobbins thread directionec848a5.jpgthreads inside bobbin clockwise rotation when you pull outthe insert bobbin to shuttle race casas shown
hold bobbin like this 33ea7ef.jpginsert
this to shutttle race case as shown ignore arrow
ebd49c7.jpgthen
after inseting bobbins closed needle plate cover
manually rorate hand wheel to hook up lower thread bobbin by upper thread bobbin if two thread appear on plate needle adjust tension dial to # 3 to 4 and stich dial to # 12 this for straight stich try sew manually first to observe thread under bobbins if free rotate and no accumulation of thread loop you sew w/ foot pedal or push buttin..happy sewing and have a nice day thanks
Mar 31, 2009 | Sewing Machines
Jim!
Dec 29, 2008 | Bernina Bernette Deco 600
Needle position
perhaps the needle is not in straight or is bent.
Oct 22, 2008 | Brother CS-8072 Computerized Sewing...
Sewing Machines Logo
112 people viewed this question
Top Omega Sewing Machines Experts
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Ruth summersides
Are you an Omega Sewing Machine Expert? Answer questions, earn points and help others
