Question about Mitsubishi WS-55805 55" Rear Projection Television
Online repair manual for mits 55805
Can you send the link to this or send me a copy?
[email protected]
Thanks!!
  • ndns2000 Sep 16, 2008
    Could I get the info as well???
  • Anonymous Nov 13, 2008
    No raster, Main Board Switching Power Supply all V about 1/2, getting short bursts of high freq. AC from Reg. chip. but osc won't keep running. Have a CD manual but no waveforms, sketchy circuit descript. After set off for a day or two, it will come back on once, but not again if turned off. Replaced the Reg IC, no help. Could use a manual with waveforms, suggestions for next most likely component to replace. Transformr not available from Mitsu. Where to find?
  • 927 Answers
Good Day, TraderGordo;
I will E you the info.
Good Luck, big IRISH.
Posted on Aug 16, 2008
SOURCE:
Mitsubishi WS 55805 nothing but blue screen and black square in middle
A full service manual is available online---I will presume you tried to unplug it for a while and then power back to see if will reset itself.
This set has three hidden menus---one is the OPTION menu--in that menu with the Mitsubishi remote you can do a hard reset of the entire set= sets all back to factory except convergence adjustments which are stored in another area--cures all kinds of oddball issues.
I can give you a link to the manual and the page numbers for the OPTION menu.
Note: the other two hidden menus are Convergence and adjustment--do not go into adjustment menu as one wrong move and poof!
SD TECH
Apr 20, 2012 | Mitsubishi WS-55805 55" Rear Projection...
Need Power Juicer manual
Call 1.800.526.2518 or visit www.jackspowerjuicer.com Maybe they'll send you a new copy of the manual.
Jun 24, 2008 | Jack Lalanne Power Juicer 250 Watts
Mitsubishi TV WS-65713
you can get the service manual and detailed instructions on that repair by going to the following link.
http://servicemanuals.vstore.ca/
May 31, 2008 | Mitsubishi WS-65813 65" Rear Projection...
User Manual for Telemate 1209DP
the nearest manual I found is
http://www.portrobinson.net.nz/manuals/Telemate_TE1208PM.pdf
when looking for a manual for my Telemate 2000+2 set of three cordless.
Hope this helps
[email protected]
Apr 15, 2008 | Lands Phones
How to replace the door bellows seal ?
I need some one to tell me how to install the rubber seal on a bosch maxx Eurowasher front loader washing machine. Part of the seal ripped off so water leaks out. Its only 6 months old and its not covered by warranty.
Jan 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Parts and repair
go to www.ptscorp.com and send the board in
Dec 14, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Mits ws-55805 No sound no Pictuer
FIRST CHECK CONNECTOR "DR" FOR PROPER CONNECTION, BETWEEN THE DEFL MINI PCB AND THE MAIN PCB. 2. CHECK C5A09 AND C5A50 BOTH 33 UFD 50 V OFF OF IC5A01 ON PCB-DEFL MINI. 3. CHECK FOR LEAKY IC5A03 PART # 270P704010 ON PCB-DEFL MINI 4. SUSPECT THE HIGH VOLTAGE BLOCK PART # 920P016010 IF STILL NO HELP PROBLEM CAN BE INTERMITTENT (TEMPERATURE RELATED) CAUSED BY IC7D04 PART # 275P245010 ON THE DOUBLER PCB THIS WOULD BE A THIN VERTICAL LINE IN CENTER, IF GUNS WERE ON.
May 21, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Manual
Here is the link to the manual for the cr560x which appears to be very similar - couldn't find the manual online for your exact model, sorry. http://www.audiovox.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=13522&langId=-1 Hope this helps :)
Apr 11, 2007 | Jensen CR550X
Mitsubishi WS-55805 55" Rear Projection Television Logo
123 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
