Question about Dryers
My check filter light keeps blinking. I have cleared all obstructions. I also must reset the button under the right front to get it to heat
  • mark_vergari May 18, 2011
    Daniel,
    I will give that a try when I get home. How about having to hit the reset to get it to heat. Will your sugestion take care of both issues?
  • 4,323 Answers
Hi
If you have already cleaned the filter then leave the unit unplugged for 10 minutes after this plug it back and then press and hold the START/PAUSE button for 15 seconds. If the issue returns then it means that the thermal fuse located inside the back panel to the exhaust duct is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on May 18, 2011
  • Daniel Scott
    Daniel Scott May 18, 2011
    Yes it will...post back for further assistance
Reset casio qt 6100
To reset one of these machines, switch off using the power switch on the left hand side (under the flap). Hold down the button on the bottom right hand corner of the machine (should have a small light bulb symbol above it) and switch machine on (Ensure you keep holding the front button down). Release the button then press the "ok" box on the screen. Once the machine has restarted it will ask if you want to do "Flag Clear" or "Initiliazation". Use flag clear to reset errors. Initiliazation to reset the machine fully. Hope that helps.
Jul 08, 2014 | Casio QT-6100 Touchscreen Cash Register w/...
No heat from heater
Copy following link to help identify water heater.
http://waterheatertimer.org/How-to-fix-water-heater.html
Add a comment and describe water heater in detail. Attach video with clear description.
If unit has blinking lights, then check product manual for error codes from blinking lights.
If unit is delivering no hot water, check for cross connections
http://waterheatertimer.org/Crossover.html
Call service technician and catch up on routine maintenance, such as cleaning water filter, etc
Jun 10, 2013 | American Heat ADK-2 - Electric 8.2KW...
Dishwasher will not start lights blinking
remove drain hose off garbage disposal and see if its plugged with food debris,if it is the unit will act like this as the computer will sense this blockage and shut down until cleared of this obstruction
May 12, 2012 | Kenmore Dishwashers
Service error 5100?
This error means that there is something obstructing the printing process. Check inside your printer through the gears that you can see under the lid. There should be something obstructing the gears such as dirt or in my case popcorn. There was even some paper caught underneath the rollers that I had to jiggle around to even see. Check VERY thoroughly.
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
1. clean **** strip film
2. clean **** strip film sensor (back of head carriage)(use contact cleaner)
Also, try this reset procedure:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 01, 2009 | Office Equipment & Supplies
Lights blinking
Sounds like it's either a glitch in the software or a bad heater. Does it blink 7x? You can clear that out so it's usable again by pressing a certain key sequence. I can't tell you the exact keys since I just know the thing by heart but it should be press the heated dry key then skip one and press the next one to the right and do that 3x and it will clear out the code. If it comes up again it probably is the heater. There should be a tech sheet under the bottom panel of the unit that has that sequence on it also. After hitting that sequence all the lights will come on. wait about 10 seconds and press cancel. Then you can use the washer again. Good luck.
Apr 05, 2009 | Maytag MDB7100AWB Dishwasher
Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
Jan 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Epson Printer Problem
HI,
Press the fonts.gif load/ejectbutton. The printer ejects the jammed paper and then resumes printing.If the error is not cleared, open the printer cover and remove thejammed paper. Then reload paper in the sheet feeder and press the fonts.gif load/eject button. The printer resumes printing.
Jul 24, 2008 | Epson Office Equipment & Supplies
Brother Printer HL 1240
OK figured out the sequence to resolve this error:
power off unit
unplug power cable for 1 minute
reset the power cable
open front door
press and hold the reset button under the lights
turn the power on
printer should then be reset
Feb 21, 2008 | Brother HL 1240 Printer
"Clean light" keeps blinking; dishwasher won't start new cycle
Check to see how it's loaded. If something is obstructing either of the spray arms it will not start. I had this same problem and checked to see if there was something impeding the arms - I found there was. Reloaded the unit and it's running like a champ now!
Feb 07, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
Machine won't start and the START light keeps blinking
A flashing start button shows that the filter is dirty. Remove the filter assembly from the machine. The "tube" can be split into 2 sections fairly simply - do so, and wash each piece under the tap to clean it.
Once the assembly is cleaned properly, select the program that you desire, and press and HOLD the start button for 2 seconds. The wash cycle should begin.
Nov 05, 2007 | Zanussi 24 in. IZZI ALU Built-In...
Dryers Logo
32 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
