Question about Cameras
Every picture i take of still objects turn out really blurred
    Scholar:
  • 85 Answers
How do you hold your camera? Holding it at arms length and viewing the subject through the screen will practically guarantee a blurred image with most cameras. You might get away with it with cameras equipped with Image Stabilization but not compact digitals.
Use the view finder and hold camera firmly against your face. Frame your subject, take a breath in then exhale, stop breathing momentarily and squeeze the button. (Don't forget to start breathing again!) If possible rest your camera on or against a solid object while shooting.
Posted on May 18, 2011
Pictures come out blurry if any movement
The most likely culprit is a slow shutter speed. If the subject moves while the picture is being taken, you'll see it blur. If non-moving objects show up sharp while the moving objects are blurred, then this is definitely it.
Another possibility is camera movement. Try putting the camera on a tripod or a table or other steady support, then use the self-timer to take a picture. If everything in the picture is blurry, then this is probably the reason.
The third possibility is that the camera isn't focused on the subject. Try taking a picture of the subject when it isn't moving and see what happens.
Mar 16, 2013 | Olympus Sz-12 14mp Wide-angle With 24x...
The picture has a delayed action
It's not possible to take a photo in a second, because the camera needs to get in focus the object you're taking picture of.
You have a square on your display that indicates where the focus will be.
With whatever function you use, you need to press the shutter button halfway and wait for the camera to focus on the object. When it's focused you will hear the click and the square will turn green.
Now your pictures shouldn't be blurry.
Jan 29, 2013 | Nikon Coolpix S210 Digital Camera
I have a nikon 55-200mm lens for the D40X digital camera. The pictures I take are blurred. I use the auto settings. the 18-55mm lens works fine and there are no problems with the picture clarity. Is the...
One of a few things might be happening
1. Photos being taken at high zoom (i.e. 200mm) are susceptible to camera shake, even though the lens is focusing properly. The solution here is use a tripod, zoom out, or steady yourself.
2. Photos being taken without flash when flash should really be used will result in motion blur (which is slightly different than camera shake). This is due to the camera using a longer shutter speed to let more light in, with the side effect being that objects will move while the shutter is open, blurring the picture. The solution here is to use a flash, or take pictures in better light.
3. The camera may be focusing on something other than what you intended.
3. If you are taking photos in good light with a steady hand, and the camera is choosing the correct subject to focus on, then yes, the lens could need readjusted, though this is not a very likely scenario.
If the lens is "hunting" for focus, that could be a sign that something is amiss.
A local camera shop can verify the accuracy of focus for your lens.
Mar 04, 2011 | Nikon D40x Digital Camera
I have just purchased a 46" samsung led tv @100hz
Try resetting the entire video/audio settings to default. The blur on the picture may indicate that your motherboard is going bad. Recently there was a customer who had the same problem. It was his board. When we tried the AV cables, the blur went away. We tried different HDMI cables and the blur was still there when using HDMI output. It wasn't the TV, and it wasn't the HDMI cables. It was the board going bad.
Try accessing the recovery menu 'safe mode'.
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options. Try 2-5.
Jan 22, 2011 | Sony Playstation 3 (PS3) Console
The pictures i take are blury how do i fix it
If you don't know how to use the manual focus switch it to auto focus, Check the MACRO feature, try to capture photos about 2 inch or 4 inch nearby the object, if the shots are clear and shooting in distant objects are blurred meaning you have set your camera to MACRO setting, Turn off the Macro feature
Oct 31, 2009 | Fuji FinePix S3000 Digital Camera
Fuzzy background on tv picture
This is probably a combination of 2 things. In both causes 1 and 2 below, I would suggest checking the TV with a BluRay Player with BluRay disc connected using an HDMI Cable. If you complain about this, then the TV is probably not that great. Expect a $200 jump to a better model at the least (but this depends on what you have now). Honestly, this is fairly normal and wont change much with the next TV.
CAUSE 1: Motion BLUR
Motion blur occurs when fast moving objects are displayed on LCD TVs. Basically, it takes time for the LED lights that make up the picture to turn ON and OFF, when and object shown on the TV is moving faster than the LCD TV can turn these lights ON and OFF, you see the trail left behind as the lights dim to OFF. This look like blur because you see the current image and the trail of the old images. 120HZ and 240HZ LCD TV are supposed to improve this but honestly, they are at times 300+ dollars more and not really worth it. Very little difference except in some few cases.
CAUSE 2: Digital TV
Digital signals are hit or miss. Good or BAD. If you are watching Cable, Satelite or Antenna; it is likely you are seeing some BLOCK NOISE. This block noise is caused by missing information or Noise in the video signal. This will cause the picture to Pixilate (you see blocks and things start looking blurry too). This happens with poor signals. This also happens with the HD channels when they have more information than bandwidth (more data than that have space to send it...image shoving an elephant into a VolksWagon Beetle)
May 27, 2009 | Televison & Video
LCD screen is extremely blurred
It is probably not the LCD itself, but an element that is protecting the LCD is bent out of shape.
Jan 16, 2009 | Vivitar ViviCam 5386 Digital Camera
Multiple shot
If the Camera is capable of Multishots then the manual will tell you how. Taking pictures of fast moving object depends on what sort of result you require. If you wish to 'stop' the object with a blurred background then with the camera of P setting simply pan [swing] with the object as it moves and press the shutter when in centre- So with lets say a fast car come from right moving to left[the the other way] point far right ans move with the car as it comes to your centre click but keep moving your swing. But there is no substitute for practice and experiment
May 07, 2007 | Olympus SP-500 UZ Digital Camera
Cameras Logo
66 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
