Question about Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop
I have a vga monitor that has been tested and works.When i plug it to my Presario SR1103wm the monitor has a black screen and the power light is orange.
    Sergeant:
  • 158 Answers
Try this- plug the monitor to the laptop, press simultaneously Fn+F5 or Fn+F6, that activates the external video exit port.
Posted on May 18, 2011
    Genius:
  • Compaq Master
  • 1,479 Answers
It's not receiving a signal from the pc indicating graphics failure. if it's built in to the motherboard you should be able to buy a graphics card to fit, it your graphics card is a plug-in then it might have failed and need replacing. you could also check the bios to make sure that it is set for you graphics configuration.
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
The compaq will not boot up
try loading your OS cd but it will wipe out all the files on your drive. if this wont still work, then it might be prob with the hard drive itself. replace hard drive.
Mar 31, 2010 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
I've got an F755US that is not turning on. There is a blue light blinking on the right side where the ac power plugs in. I've searched the 'Net and have tried a number of the options regarding powering...
you forgot to say the SCREEN IS DEAD and BLACK on no text ever shows up there, nor do BIOS screens work (even with HDD removed)
mine has 3billion transistors , any of which bad can kill it dead.
we dont guess we do tests.
called diagnostic testing, or go broke guessing. see?
leave the battery out for now, batteries can and do short often.
next is the power pack 19vdc, good, 10v bad we test that using a magic tool called a voltmeter ($20 in stores, DMM)
i have 100 solutions (i pass) or just 3.
1: bad power pack; battery out.
2: bad mobo (we can tests here all day ,wana? asK)
3 : dead screen, does the external jack vga work to external monitors?
is this a PC 2008 with the horrid solder ball problems.????
gee the service guide on line is time stamped, 2007
i call solder balls.
http://pcdied.com/black-screen.html#solderball_hell
Guess 2, the CCFL is dead.
but the external VGA works. !
in the link above see all words on CCFL. (back light and the easy test there) see the flash light trick?>
Jul 20, 2017 | HP Compaq Presario F755US Laptop
LCD Monitor stays on 4 bit resolutionm
Its your VGA card that's having issues with the LCD display. Try reinstalling the VGA drivers see if it works.
Jan 22, 2009 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
My monitor will not turn on
Hi you didnt say whether you tried changing the plug fuse,try that,if it still doesnt work then the power cut you had might have been a power spike in which case the monitor would be destroyed.Try testing the fuse in the plug first ..ok.
Dec 29, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Blank screen and no lights on keyboard and mouse
*check the power cables
*check the power outlet
*check smps is fine
*check power switches are properly connected
*check in bios hdd is enabled
*open the case wheather the connections are properly connected
Jun 27, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Black screen when i turn on computer.
Do a power drain :- Disconnect every cord from the back of computer tower while the pc is oiff and then press and hold down the power supply button in front of the tower..
have u tried updating the bios any time before?
Secondly,is it possible to go to the safe mode or the screen goes blank even before that?
Blank screen
When you say "When I turn on the computer the monitor acts like it is getting no power", do you mean the light on monitor doesn't come on or it does and it states it has "No Signal"? If it says no signal then it is receiving power just no signal from computer. What kind of connection is it? Digital(white) or analog(blue)? Is the keyboard wireless or is it PS/2?
If the keyboard isn't wireless and you're plugging the monitor in correctly I would say it's a power supply issue. Try changing the outlet you're using and/or bypass the surge protector to plug directly into wall.
Jun 24, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Screen doesn't work properly. Can just see windows loading if hold screen to light. Computer Compaq Presario V2157Ap or V2000 both nos on back of comp
1st test,- connect an outside [test] monitor to the back .There is a VGA plug somewhere back there. If the screen come in good, the problem could be your Laptop monitor screen.
If the connected test monitor acts the same, visually, the problem is in your Laptop.
2nd.test- goto BIOS setup and press F=function that set your laptop to DEFAULT, reboot and see.....
3RD. test- [POWER OFF!!] switch ram chips around from one socket to the other ,, reboot or power on
4th:replace memory chips with KNOWN good ones
If u still have problems, goto technician for help
May 06, 2008 | Computers & Internet
Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop Logo
56 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
