Question about Health & Beauty
I have siemens streamjet hair dryer with a splice electrical cord at the very end of the handle. After removing the only screw how can I pry open to get into the connection inside to change the cord.
reddevil6
  • 1673 Answers
SOURCE: Miele S528 Cord Retractor
There are some screws not removed yet, on the top under the filter there may be one, sometimes there is a screw under the control panel. Maybe these pix's will help. Most likely you will have to replace the cord reel asm (#05240303). You can take the reel apart and re-attach the cord, but if the spring unwound, then it maybe better to replace it.
Posted on Mar 02, 2008
SOURCE: change cord on electrolux EL5020
In order to get to the cord that is disconnected you need to remove the screws that hold on the frame(the red shell). You will need to remove the "fenders" that are near the wheels. In order to remove the fenders get a flat tip screwdriver and pry up on the front part of the fender, there are three clips holding the left one on and two holding the fender near the cord. You will need to remove the left wheel (the wheel farthest from the cord). After you remove all the exterior screws and the four screws under the brissels the shell should be able to be removed. Next you will need to pull the cord all the way out and there will be a clear clip, use a flat tip screwdriver and release the clip in order to remove the clear piece that holds the power cord electrical ends. Reattach the clips of the power cord and be sure when you put the clear piece back in that the two contacts are not bending. You will need to use a screwdriver to guide the electrical clips back into place. I didn't count the screws there is a lot of them. I hope this helps you
Posted on Oct 17, 2008
frcs68
  • 1605 Answers
SOURCE: How do I remove driverside inside door panel ?
door panel is holding by dozen plastic push pins.
strat from the button. use a screw driver or putty knife. pull the panel towards you. be careful not to damage the push pins. go around the panel toward the door hinger then the otheer direction toward the lock.once you have panel seperated from the door. push up the panel to clear the glass. (it is easier if the window is all the way down). pull back the plastic (don't destory it). you need to put that back later. now can get access to the galss and what ever else you are looking for.
Posted on Apr 02, 2009
  • 32 Answers
SOURCE: Hair Dryer cord has electrical shortage
IF you take off about a inch of wire from the plug and re-wire it [somtimes with new plug also] make sure to remember the fuse and this should do the trick.
Posted on Oct 24, 2009
SOURCE: How do I pry open my Bose Wave Radio cover to
ON THE WAVE THERE IS OUTER SCREWS AND THEN UNDER THE FRONT LOWER LIP YOU NEED TO GENTLY SEPERATE THE GRILL SECTION FROM THE BASE BY INSERTING TWO FLAT BLADE SCREWDRIVERS 2 INCHES IN FROM EACH SIDE AND SLOWLY LIFT UP AND FOWARD IT WILL POP OFF RATAINER CLIPS HIDDEN ON LOWER FRAME.
Posted on Nov 05, 2009
Doorhandle
for passenger side:
1. unclip screw cover 'center flap' of inside door opener plastic cover, flap is 3/8"x 3/8" (center of plastic cover)
2. remove phillips screw now showing
3. push fabric panel (edge of door opener plastic cover-at hinged end of chrome handle) to allow uncliping of edge of plastic cover (top rt & lwr rt (for passenger side) of plastic cover)
4. open chrome inside door handle to allow plastic cover to be removed-slide plastic cover toward rear, free end of door to remove cover
5. remove switch panel-gently pry with wide non maring pry bar (cover wide blade screwdriver using cloth) do rear of sw panel 1st (don't pry front edge)
6. slide switch panel toward rear to allow removal
7. remove large phillips screw under sw panel
8. remove the 2 plastic covers near top, hinge edge -use plastic spoon handles to encourage caps to pop off. May also require small screwdriver approx 1/8" in to complete pop off
9. remove the 2 phillips screws w/ captive washers
10. remove 3 phillips/hex screws along the bottom inside of door panel
11. on outside/rear edge of panel push the 2 center pins of each in about 1/8"-this allows the clip to be pulled out w/ pin pushed in
12. remove plastic cover (REAR OF SIDE MIRROR)-pull window edge up and back.
13. lift rear of door panel (not hinge edge) up allow hinge edge to pivot around lower pin in door (hinge edge)
14. remove the 2 rt edge "L" brackets (gently pry center plastic pin out) (note the color and replace as removed)
15. slowly peel the clear plastc away from the non hinged end to expose the plastic panel with 3 phillips head screws
16. remove the 3 screws and panel for access to door handle.
17. using access area now available unlatch the rod attached to exterior door handle (unclip plastic to rotate clip up to allow rod to slide out-toward hinged edge)
18. using access area now available remove rod from ext door handle from inside door area
19. remove the 3 -10mm head bolts
20. remove the ext door handle (bottom edge out first)
reverse order to replace door handle
Mar 24, 2014 | 2003 Toyota Avalon
Where do i plug in the power adaptor, so I dont have to worry about using the choke when the bike gets cold?
Instructions
    • 1 Fotolia.com"> install-motorcycle-cigarette-lighter-1.1-800x800.jpg If the battery is installed under the seat, loosen and remove the hex bolts holding the seat in place, and remove the seat from the motorcycle. If the battery is mounted under a side battery cover, pry the battery cover from the motorcycle to expose the battery.
    • 2 Strip one-half inch of insulation from one end of the black wire and one end of the red wire. Place a ring terminal over the stripped ends of the black and red wires, and crimp the terminals to the respective wires.
    • 3 Place the positive wire from the weatherproof socket into one of the holes in the first splice connector. Place the free end of the red wire into the splice connector, and crimp the connector to make the electrical connection.
    • 4 Place the negative wire from the weatherproof socket into one of the holes in the second splice connector. Place the free end of the black wire into the splice connector, and crimp the connector to make the electrical connection.
    • 5 Loosen and remove the retaining nut on the positive battery terminal. Place the ring terminal attached to the red wire over the terminal screw, and replace and tighten the positive battery terminal retaining nut. Loosen and remove the retaining nut on the negative battery terminal. Place the ring terminal attached to the black wire over the terminal screw, and replace and tighten the negative battery terminal retaining nut.
    • 6 Route the power outlet to a point on the frame below the rider, and attach the outlet to the motorcycle frame using a cable tie. Use the remaining cable ties to attach the excess wire length to the frame of the motorcycle. Reinstall the battery cover or the seat when finished.
Instructions
Instructions
rate these after reading
Jan 16, 2013 | Motorcycles
Puppy chewed the cord. It is an internal cord and does not plug into the back of the tv. Can I replace it myself? Directions or diagram? Where is the best place to get the replacement cord?
Any polarized power cord will work----cautions: the cord where it connects inside will have either a white stripe on one side or a rough surface---that is the neutral side---replacement must be soldered to correct points---you get it backwards and set will work but shock hazard will exist-------if you have enough cord left you can do a splice repair-----I cut them back and offset so not next to each other(the two sides of the cord----get some heat shrink tubing--slide it over each side and down a ways---solder the two ends for each side back together (you will lose a little of the cord) and once soldered slide the shrink tubing down over the soldered parts and heat it with a hair dryer and it will shrink air tight over the solder connection's---you do not want the splices side by side to prevent any possible short----for extra protection once done use some black electrical tape and tape the whole area.
Either replace entire cord or splice repair it. Examine cord end to end for any bare wire showing---if chewed in more than one spot replace entire cord.
Nov 08, 2012 | Philips 32PFL3505D 32 in LCD TV
How do I replace the power cord on an electrolux 8502A vacuum cleaner?
1 Unplug the vacuum and remove all accessories such as extensions and brushes. Open the vacuum's outer casing to get at the end of the power cord. Exactly how you will do this depends on the model of vacuum. Generally it simply involves the removal of two to three Phillips-head screws.
2 Follow the power cord to the two connections at the vacuum's motor. Unfasten any clips or holding bracket and disconnect the cord from the motor. Sometimes this can be accomplished by unscrewing two connection screws, other times the cord is soldered directly to the motor. If this is the case use wire cutters and cut the cord about 4 inches from the motor to give room for splicing on a new cord.
3 Insert the new power cord into the vacuum. Follow the exact same path as the old one. If there were any brackets or clips that held the old cord in place inside the vacuum or out use them on the new cord.
4 Tie a knot in the cord on the inside of the vacuum casing so that it will not accidentally be pulled out of the motor once it is in use.
5 Connect the new cord to the motor in the same fashion as the old one. With wire strippers take off about 1 inch of insulation from the new cord to expose the two wires. Either wrap them around the connection posts and re-screw, or twist the new cord wires around the 4-inch remnants of the old cord and seal all exposed wire and connections with electrical tape.
6 Replace the vacuum's casing in reverse order from how you removed it. Plug in the vacuum to test.
Sep 11, 2011 | Vacuums
No electrical continuity on one lead in hose. Cause is probably in the wiper assy. How do I disassemble hose ends to check electrical connections without breaking or cutting into plastic parts?
We have here the user manual. The page 8-9 you will see the instruction for replace the power nozzle which shows how to desmandle the vacuum and you will find the power cord connetion point. A big advice use your camera to take picture every step you make and especialy before remove the wires since in any case you will forget anything when you will try to assemble it back they will bevery helpfull.
Aug 06, 2011 | Hoover S3670 Bagged Canister Vacuum
Need to remove lower front panel off a LEQ2152es0 model, can you pry it off with a screw dryer, how is it attached. I remember the service tech showing me, but now I can't remember and I need to check for...
there are 2 screws located near the floor,remove these,then it comes outward toward you and unclips,then remove the door hinge screws next with the door open and remove the door,then the upper rest of the front cover can be removed too
Aug 01, 2010 | Frigidaire GLEQ2152ES Electric Dryer
How do I remove the door panel to repair the door opening device?
Hello, my name is Ben and I can help with this. If you have electric windows use a small screwdriver and pry the switch assembly up gently. Go in under that lip and pry upward. If manual windows, there is a clip that holds the crank handle onto a shaft, the clip is shaped like a C with the open end towards the end of the crank handle. If you push in on the door panel a bit you can work a very small screwdriver or an ice pick or other long sharp tool behind the handle and pry the clip loose (CAUTION, when released the clip will try to fly off never to be seen again, so be careful with it). Now look towards the front bottom of the panel and remove that screw, then there is one in the armrest. Then pry out on that triangle shaped piece of plastic at the top of the panel, it just snaps straight out.Now you should be ready to start prying the panel off, start at the bottom and work around, it will sound like you are tearing the panel as the fasteners give way, just go slow and they will come IF you have already removed the screws. Once all the fasteners are free just lift the panel up and out.
Jun 29, 2010 | 1999 Chevrolet Silverado 1500
Upper door handle is loose. Cannot get to screw under plug (at bottom) of handle to tighten it. How do I remove the plug?
Pry gently with a very slim, very flat screwdriver. A knife will gouge it and even cut it making it hard to reattach. Sometimes a hair dryer will soften it up enough to pry out with your fingers alone. Remember that the handle will be hot to the touch though.
Mar 13, 2010 | Amana ARB2257C Bottom Freezer Refrigerator
How do you change the dryer door from a left to right opening to a right to left opening. Thid is a series 90 kenmore
Open the dryer door. There should be approximately three screws that hold the hinges on there on the right side (as you said yours currently is a left to right opening). Remove the screws that hold the door on. As you hold the dryer door removed from the dryer, turn it counter clockwise so that the handle is now on the opposite side. Lay it on the floor. Now, remove the screw hole covers from the opposite side of the dryer opening ( the left side) (these can be removed with a fingernail or a thin flat tipped screw driver to pry them out). This will expose the screw holes on the opposite (left)side of the dryer. Take the removed covers and place them in the original screw holes on the right side. Now simply reinstall the door hinges in the newly exposed screw holes on the left side. This will only work if your dryer is designed to have both types of openings. Good Luck!
Feb 27, 2010 | Kenmore 659 Electric Dryer
I want to replace the driver's side mirror and need to remove the inside door panel thanks
here is step by step instruction to remove your door panel. i am not sure if the picture are coming through so please forgive me on the images. please do not forget to rate and comment about your experience today wih fixya Front Door
  1. On vehicles without power windows, place a soft cloth under the window regulator handle and pull upwards on the cloth to release the snapring. Remove the regulator handle and plate.
89550p12.gif Using a taped prytool, carefully remove the bezel portion of the handle
89550p14.gif Remove the bezel by pulling towards the tip of the handle
89550p15.gif Remove any screw covers ...
89550p16.gif ... and extract any retaining screws from the door panel
  1. Remove the screw from the inside handle and slide the handle forward. Disconnect and remove the handle from the control link.
  2. On manual mirrors, remove the setting screw and knob. Tape the end of a thin flat-bladed tool and pry the retainer loose to remove the cover.
  3. If equipped with power windows, remove the power window switch from the and armrest.
  4. Remove the mounting screws and remove the armrest from the door panel. Remove the inside door handle bezel by pushing rearward.
89550p18.gif Carefully pry the edge of the door panel around the outer edges, then remove the door panel
89550p13.gif Once the door panel is removed, make sure to disconnect all wiring
  1. Remove the door courtesy light by pulling outward. Disconnect the electrical wiring.
  2. Remove the two screw caps and speaker cover(s). Remove six screws from the trim panel.
  3. Remove the door pocket from the panel.
  4. Tape the end of a thin bladed tool, then insert the tool between the door panel and door and pry the panel outward. Disconnect the electrical wiring after the panel is free and remove the panel from the vehicle.
To install:
  1. Connect the electrical wiring, if equipped, and install the trim panel onto the door.
  2. Secure the trim panel with the mounting screws, then install screw caps and speaker cover(s).
  3. Install the door pocket.
  4. Install the armrest and secure with the mounting screws. Install the power window switch as required.
  5. Install the door courtesy lamp. Install the inside handle bezel.
  6. Install the outside rear view mirror cover and retainer.
  7. Connect the inside handle to the control link. Install the handle, slide it rearward and install the screw.
  8. With the door window fully closed, install the window regulator and handle.
Apr 17, 2009 | 1993 Toyota Camry V6
Health & Beauty Logo
105 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
