Question about Dishwashers
How do I replace the control module on a Bosch dishwasher, model SHE4AM12UC-01?
    Sergeant:
    Champion:
  • 257 Answers
You remove the screws on the inside of the door, this separates the panel. from there there may be a few screws and wire harnesses to unsnap, where you see locking tabs just depress with a flat head screw driver. Its all pretty easy from there. Good luck
Posted on May 18, 2011
Bosch dishwasher says E:01 and won't start. Any ideas?
the pump controller or pump switch over is defective, basically your power module is faulty and unable to power the pump, you will need to replace the power module
Jan 19, 2017 | Bosch Dishwashers
Our dishes dont come out clean...we have cleaned the arms, the drain, etc. etc..
most dishwashers have a screen in the water inlet line this can become plugged and cause low water presure
Jan 30, 2011 | Bosch SHE4AM12UC Dishwasher
My Bosch dishwasher SHE4AM12UC will start a cycle and then 5 min. later say they are clean. I have tried resetting, changing cycles and it does it everytime. it is only a couple years old.
This is due to either a problem with your power board, or your drain pump. Check the drain pump impeller to see if there is any debris causing the impeller not to spin freely. You will need to call a service technician to replace the power board located on the right hand side of the machine base. Also check to see if there is a removable plastic peice in the sump by the drain pump. to do this, removie the sump screen (mesh screen in the floor of your dishwasher) by unscrewing it and pulling it up. This plastic peice (called a lid/cover) fits in the bottom by the drain pump. If this has come loose, then it simply place it back in place and it should fix your problem.
the problem you are describing is either related to the drain pump, or Power board. Perform the simple steps described above, or call a repair technician to come and diagnose it for you. If you are handy, you may be able to replace the board yourself.
Dec 07, 2010 | Bosch SHE4AM12UC Dishwasher
Dishwasher won't run
yes the water going to the machine and the water valve has to be ohmed out with a meter
Feb 28, 2010 | Bosch SHE4AM12UC Dishwasher
My bosch dishwasher control panel displays 0H on the time delay. When I start it the OH go to 2H. It then starts running and does not stop. The cycle minutes don't display. It's model number SHU5302UC...
check to see if your unit has a recall on it because if it does you will get a free control module from bosch.
your problem is the control module. thermador .com is the site to lookup. gaggenau,bosch,thermador they are the same ccompany. let me know if this helps by sending a 4 thumbs up post
Feb 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
My bosch dishwasher model shu33a keeps running.At first the sanitized light would not light now it just keeps running and when i open the door its not real hot like before..the washer is only 3 years old.
change the control module. check to see if there is a recall on this module. bosch will tell you if it is.give them model # and serial #. by the way if the modell is arecall you will get a free fix. let me know if this info helps,
Feb 23, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
Replacing Control Module
Sergio,
Did you get your problem resolved. By now I think you have found the two screws on the sides of the inter part of the door. Did replacing the module fix your problem. I have the same problem.
Mike
Jun 28, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Machine runs for 4 hrs and 2H shows
Problem machine ,replace the control electric
May 21, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwashers Logo
91 people viewed this question
Top Dishwashers Experts
Owen Barnes
