Question about Vtech CS5121 Cordless Phone
HOW TO USE "PROG" KEY TO PUT IN A NUMBER AND HOW
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vtech Master
  • 102,366 Answers
You can download a copy of the manual from the manufacturer's web site at
http://vt.vtp-media.com/ecp/documents/product_Product/55/UserManual/106/CS5121_Manual.pdf
Page 15 contains instructions on storing a number in the directory, while page 19 contains instructions on dialing it.
Posted on Sep 08, 2011
How can i drill a hole into my keepsafe wall safe to open it?
Keep the drill motor in the toolbox, you'll likely just ruin the safe.
Go here instead: https://www.sentrysafe.com/CustomerCare/Lost_Your_Combination
There are 3 possible ways to unlock and access
the safe:
1. Factory code
(Found on the first page of the factory guide) You can
always open the safe by entering the pre-set 5-digit
factory code. This code cannot be deleted.
2. User code
If you prefer to employ your own code, you can
program the safe to open using a 5-digit user code
of your choice.
3. User pin
If you wish to give someone else temporary access
to the safe, you can program a 5-digit user pin that
can later be erased.
Programming the user code
NOTE: One (1) user code is allowed.
To add:
1. Press the Prog key , then enter the 5-digit
factory code.
2. Enter the 5-digit user code of your choice.
To delete:
1. Press the Prog key.
2. Enter the 5-digit factory code twice.
Programming user pin
NOTE: One (1) user pin is allowed.
To add:
1. Press the Prog key 2 times.
2. Enter your 5-digit user code.
3. Enter the 5-digit user pin of your choice.
To delete:
3. Enter 0, 0, 0, 0, 0.
NOTE: If your safe does not appear to be working,
please check batteries before calling Sentry
Customer Care.
Jul 26, 2014 | Sentry KeepSafe Combination Fire Safe 12...
Why does vtech not have a speed dial? my son is
Programming Speed Dial Numbers
The handset must be OFF.
1. Press PROG. The IN USE LED will blink to indicate that you are in the programming mode.
2. Press the number of the memory location you wish to store the number in (0-9).
3. Using the dial pad, dial the number you want to store. The number can be up to 16 digits long. The number can be entered manually or by using REDIAL.
4. Press MEM to store the phone number
to the key you selected.
The phone now exits PROG mode and emits a tone.
Speed Number Dialing
1. Press PHONE to get a dial tone.
2. Press MEM and the memory location number key (0-9). For example, to dial the number you assigned to key '8', you would press PHONE, MEM, 8
May 27, 2011 | Vtech 9009111 Cordless Phone
How do I reset ringer to "on" if it is set on "off"
Hello
Press "Prog" on the handset.
Press the arrow button beneath the phone's display until you reach "Ringer," then press "Select."
Press the arrow button until you reach "Ringer On," then press "OK." The phone should beep to confirm your selection.
Method Two
Press the down arrow key until you reach "Ringer Vol," then press "Select."
Press the up arrow key until to increase the ringer volume you want then press "Select."
Apr 11, 2011 | Vtech 5.8 Ghz Handset Cordless Phone...
Radio Shack Pro-82 Scanner
when on the scanning part push the scan part again and push the prog buton that is under the lower arrow key and push it again so it will go to a different (blank channel) . you will know when it you are able to prog when the word prog will be on the bottom of the screen then go to cityfreq.com to find the codes for your area and put them in and then press enter. after you do that press the prog button again and it will move to the next number to program a different on when you get the desired amount of frequencies in your scanner just push scan and it will run through the entered codes.. Or if thats not the problem then on top should be a bank of numbers and andd you have to push the number of what bank you want it to run through at that time.
Jan 25, 2009 | Radio Shack Pro-82 Scanner
Need to know how to program a radio shack pro-94 handheld scanner
press the "prog" key followed by the "Trunk" key then the number "1" key.
Press the "down arrow" key until you see the initials Ed on the screen
Press the "E" key.
Enter the frequencies (including the decimals)
you must press the E key and the Prog key after each frequency, after you finish entering your frequencies, press the scan key.
If you need to clear your scanner, turn it off, press and hold down the number 2 and number 9 keys, while holding them down turn the scanner back on, "clear" should start flashing on the screen, once "clear" stops flashing you can enter the frequencies.
Jan 03, 2009 | Radio Shack Pro-94 Scanner
Programming new numbers into kx t7630
If it's going to be an extension press PROG dial 1 and the ext number and ENTER
If you're trying to put an outside number on it, press PROG dial 2 then 9 + number and ENTER
Carl
Nov 27, 2008 | Panasonic KX-T7630 Corded Phone
Need to be able to re install norton 360 after use of restoration disc
if you brought it online you should have gotten a product key, and serial number. if you google "norton 360 redownload" it should take you a norton page or symantec page. enter "redownload norton 360" in search box and it should go right to it. now just enter product key and serial number and you should be good to go. ihave restored my computer a number of times and this is how i get my norton 360 back without paying again. hope i helped
Oct 24, 2007 | Microsoft Office Outlook 2003 for PC
Vtech CS5121 Cordless Phone Logo
71 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
