Question about Refrigerators
I have a side by side whirlpool E22DQ frig. Found thick greenish black mold growing around the ice dispenser. How can I get the small trim cover piece off so i can field-strip around the dispenser? What do you recommend I use to kill the mold and not harm the plastic?
    Sergeant:
    Champion:
  • 257 Answers
I would use warm water and vinegar. There are 2 small slots under the trim at the bottom, If you insert a small rigid pin in the slot on either side this will unlock the trim. Just pull toward you.
Posted on May 18, 2011
Mold growing around ice dispenser area. Cant figure out how to get to the mold .
Pull ice maker out and clean it. Then make sure you have a fresh water filter on water supply. Mold in the freezer is uncommon if its truly freezing inside. You have dirty water coming in.
Oct 13, 2013 | GALAXY Microsystems 25.4 cu. ft....
How do I remove the ice water dispenser cover on my whirlpool conquest
Remove the drip tray. Using all your fingers from both hands press down on the bottom of the cover, and at the same time pull away from the door. The top of the trim has tabs that set behind the dispenser housing. To replace the trim, set the upper tabs behind the housing and press in moving down both sides till you get to the bottom.
May 02, 2017 | Whirlpool Refrigerators
Ice sticing in ice dispenser chute
only use ice from the ice maker, some frost is normal, but , lower temp in freezer
May 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Nowater from dispenser new frig..
If it's new (under one year old) then it's Whirlpool's problem.
Call your selling dealer or Whirlpool factory service.
Should be a free call.
If over a year, post back.. Jack
Nov 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do I remove the trim around the ice maker/water dispenser on My whirlpool side by side refridgerator model # GD2SHAXLB02
The trim is snapped into place. Start at a corner and gently pry. one tab at a time.
Thanks for using FixYa - a 4 THUMB rating is appreciated for answering your FREE question.
Sep 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice dispensor flap does not stay shut
This is how most dispensers are accessed.
Check for screws around or on the under side of the dispenser trim that can be removed to get the trim off. Sometimes the drip tray in the base of the dispenser needs to be removed to access the screws. Sometimes the top panel (touchpad) of the dispenser is removed to access the dispenser components.
If there are no screws, use a putty knife with the end wrapped with tape so the paint on the door panel is not scratched.
Start at the bottom of the trim and CAREFULLY pry the trim away from the door panel.
There may be small slots in the panel on the under side that the putty knife can be inserted into.
With the trim off, the dispenser components can be serviced.
https://www.repairclinic.com/KitchenAid-Refrigerator-Parts
appliance parts, help & more
Apr 28, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice dispenser has black mold around area that ice comes out
shut down unit press for ice the door will open wipe with warm water
Apr 07, 2009 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Loose water dispenser lever on Whirlpool GD5RHAXNQ00 refrigerator
Something is likely broken in the dispenser.
Go here for Whirlpool Refrigerator Parts: http://www.repairclinic.com/Whirlpool-Refrigerator-Parts?z=100
www.RepairClinic.com
Feb 07, 2009 | Whirlpool GS6NBEXR Side by Side...
No ice
pour some water in the ice mold and see if it will kick out a batch if it does get a water valve. If ice is already in the mold then replace the ice mold thermostat. If this is a newer ice maker get a hairdryer and make the mold rotate around. This sometimes gets the newer ones back on track.
Dec 05, 2008 | Whirlpool GD5SHAX Side by Side...
Kenmore - Side by Side condensation in water/ice dispensor area
maker sure your flapper is closing all the way the trim plate will come off its snapped on once you get it strated it will come they are a bear use butter knife to pop it loose on cornor first hope this helps
Sep 13, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
116 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
