Question about Dell Inspiron 6400 Notebook
Dell inspiron 6400 rebooting
I have recently taken out the system board. After I turn it off it will reboot , not immediately but anytime up to 30 minutes afterwards. Strange
I have checked that the wires are back in the original places. There must be a short, or something.
Anyone come across this problem before?
What would I check?
  • Anonymous Aug 14, 2008
    Its not the software. When it boots up it works perfectly well.
    It is not the cooling. After reassembling the laptop, heatsink paste was applied and it runs at a cooler than average temp.
    The computer restarts approx 30 mins after its been shut down.
    I am going to open it up again and see if there is a short.
    Just thought someone may have come across this problem before - i had updated the BIOS recently as well.
  • Anonymous Sep 09, 2008
    Hi folks, happy for this blog. I am samuel. Have a problem with my dell inspiron 6400, which does not restarts after i shutdown until after a day or two. I also realize the fan on board processor does not move or work.
    Help me out on this one and I will be very grateful
  • 17 Answers
It is an issue with your software which is not able to find the os in hard drive please perform a operating system reinstall
  1. Ensure all of the Windows XP installation discs and information are present.
  2. Install the Windows XP disc.
  3. Press and hold <Ctrl>+<Alt>+<Del> at the same time to restart the computer.
  4. When the computer restarts and the Dell splash screen appears, press <F12>.
  5. In the Boot menu, use the <Up> and <Down> arrows to select either CD or DVD, and then press <Enter> to continue.
  6. If prompted, press any key to continue. If you do not press a key, the computer starts from the hard drive. In that case, wait until Windows has completed started up, and then begin again.
  7. At the Windows XP setup window, select To set up Windows XP now, press Enter, and then press <Enter>.
  8. Press <F8> to accept the terms and conditions specified in the license agreement.
    dell inspiron 6400 rebooting - new_note.jpg Note: By default, unpartitioned space is highlighted. If any other partitions appear that were not previously created by you, they may include a PC Restore partition or a Media Direct partition.
  9. In the Windows Setup Partition screen, press <Enter> to partition the hard drive. On this screen, review the listed partitions. Usually, the original operating system partition is labeled (OS) and is also the largest partition.
  10. Use the <Up> and <Down> arrows on your keyboard to highlight the OS partition and press <D> to delete the partition.
  11. When the Confirmation screen appears, review the warnings and press <Enter>to continue. You will now be returned to the previous screen.
  12. Use the <Up> and <Down> arrows to highlight the unpartitioned space and press <Enter> to set up Windows XP. The Windows XP Setup appears with the following information highlighted: Format the partition using the NTFS system.
  13. Press <Enter> to continue. On the next screen, a progress bar shows the format process. When the format is complete, the setup files are copied to the hard drive.
    The following message appears: Please wait while setup copies files to the Windows installation folders. This might take several minutes.
    Then follows Setup is copying files…. The status bar displays the percentage complete. When complete, the computer reboots and the set up wizard appears.
  14. When the Regional and Language Options window appears, change as needed, then click Next.
  15. When the Personalize Your Software window appears, enter a name and organization if wanted, then click Next.
  16. When the Product Key window appears, enter the product key, then click Next.
  17. When the Computer Name and Administrator Password window appears, enter a password if wanted, then click Next.
    When you enter the password, be sure the caps lock is off; passwords are case sensitive.
  18. When the Date and Time Setting window appears, change as needed, then click Next.Windows is installed, a progress bar indicates approximately how much of the task is complete.
  19. The computer reboots.
    The Windows XP operating system is fully installed.
Posted on Aug 14, 2008
    Sergeant:
  • 263 Answers
That kind of rebooting problem is usually a hardware conflict. Make sure all the boards and cable are plugged in right. Also, remove any addons like extra RAM chips while troubleshooting.
Otherwise, it could be a faulty part. MB, RAM, video card, etc.
Lastly, it could be a corrupted hard drive.
Good luck.
Ken
    Problem Solver:
  • 10 Answers
You took out the system board for what reason?
did you remove fan and heatsink and when you put it back together did you put thermal compound between processor and heat sink? sounds like machine may be overheating due to lack off thermal compound or dried up compound
SOURCE:
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
Hi, i have a dell inspiron 6400 and since yesterday when i turned it off it re-started itself on and enter directly in to the media direct express automatically. i´ve been starting it and pushing the...
turn off, as it starts to reboot tap f8 key continually and choose safe mode. from safe mode do a system restore to last restore point before problem began.
good luck
Oct 21, 2010 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 Vista : the wireless card turns off
is ur WIFI connected thru USB ?
then ur USB is losing power...
check if ur USB setting...
go to Device Manager/USB Serial Bus/USB root hub...
go to each ports one by one....right click on each check properties...check Power Mgt tab....
remove the Tick in the box that says "Allow computer to save power'....
close Device Manager/ Shutdown and restart....
Dec 25, 2009 | Dell Inspiron 6400 Notebook
Multiport communications port(COM4)
Unless it's affecting something directly you can just leave it be. It's probably just a simple driver issue.
If you do in fact want to "fix" the problem I'd start with just uninstalling the device in the device manager and then reboot the computer.
Did you recently re-install windows? When did you notice this problem?
Nov 28, 2009 | Dell Inspiron 6400 Notebook
Bios password for dell inspirion 6400
remove the laptop (large battery) then: remove the bios battery (small) from the motherboard wait ten minutes pluf in the laptop reboot then shutdown and reinsert the laptop battery. your code will be erased
May 21, 2009 | Dell Inspiron 6400 Notebook
Touchpad not working
Hello, my best solution would be to check ebay and order one there. If you are familiar with removing the power button bezel, do so and remove the keyboard as well. Then check the connection for the mouse. Its a small little ribbon cable coming from the mouse area.
Here is a direct link you can get these parts from:
http://computers.search.ebay.com/Dell-Inspiron-6400-touchpad_For-Laptops-Notebooks_W0QQcatrefZC6QQcoactionZcompareQQcoentrypageZsearchQQcopagenumZ1QQdfspZ32QQfromZR2QQftrtZ1QQftrvZ1QQsabfmtsZ1QQsacatZ158885QQssPageNameZRC0022QQ_trksidZp1638Q2em120
I hope you have a great day, Please rate my solution.
May 20, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400, asking for HDD password
Insert OS cd in drive and start reinstalling by selecting repair mode now once all files are loaded system will reboot when you see the Installing Devices progress bar, press SHIFT + F10
this will give you access to your account also you can reset all passwords
Now restart lappy and let the system boot normally without OS cd in drive
now you will come to old screen and previously configured desktop with all intact aplication and icons on desktop and it will no more ask you for password till you set a new one
Thanks and regards
Kindly rate this solution
Apr 04, 2009 | Dell Inspiron 6400 Notebook
Errorcode 2000:0221 / 4C00:041C
Have you tried rebooting and pressing f11 several times immediately up on reboot. This will give you the option to restore to Dell's System restore. If this does not work for you let me know. I have it had work for previous client's.
Mar 12, 2009 | Computers & Internet
Dell Inspiron 6400 Notebook Logo
1,463 people viewed this question
Ekse
Clive
Clive
Alun Cox
