Canon IP5200R printer. Green & red led`s flash 20 times, pause & repeat. print head will not come out of park position on righthand side. Fault occurred while printing a photo error 6500 displayed
  • trevjackson May 19, 2011
    I tried the reset before I contacted fixya. The next suggestion in the service manual was the logic board but this is not guaranteed to fix the problem as far as I can see. As this will be an expensive item I don`t think it will be worth trying although I like the printer & there is no similar replacement. I have stripped the unit with difficulty as there doesn`t seem to be any good instructions on the web. The one fault I have found is that the surplus ink tube was blocked. I doubt this will cure the problem but have yet to re-assemble the chassis into the case. Have you any tips for this?
  • trevjackson May 23, 2011
    How much is a logic board, will this definately fix the problem or would i be better replacing it? I do like this printer & would like to keep it.
  • 1,961 Answers
Hello!
Error 6500 or green and red flashes 20 times, mean hardware error. Particularly, the Logic Board Assembly
There are two possible fix: first is to reset the printer's waste ink counter and the second is to replace the Logic Board Assembly (part # QM2-2733)
Reset the Waste Ink Counter:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a
function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
For technical help:
  • For toll-free technical support, please call 1 (800) OK-CANON (1-800-652-2666) during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. ET, excluding holidays).
  • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
Hope this helps!
Posted on May 18, 2011
SOURCE:
How do I change the print cartridges?
  • Open the printer cover and prop it up with the support brace located on the right-hand side of the cover.
  • Remove the black FINE ink cartridge from its container and locate the protective tape. Gently remove the protective tape used to cover the print head nozzles and electrical contacts.
  • Insert the black FINE ink cartridge into the printer slot labeled "B." It will rest on a slight angle. Push the cartridge up and back until it clicks into place.
  • Repeat the process for the color FINE ink cartridge, placing it in the slot labeled "C."
  • Raise the printer cover slightly to loosen the support brace. Fold the brace inward and replace the cover to its closed position.
  • A green LED light will flash on top of the printer. In about a minute, the LED stops flashing and displays "1." Once the "1" appears, you're ready to print.
  • Mar 10, 2015 | Canon PIXMA MP210 Photo All-In-One Printer
    Print head stuck on the right hand side and lamp is flashing alternate green and orange
    Found this today (and it worked):
    canon waste tank reset for canon i70
    Below is a procedure that in most cases should resolve a Canon i70 waste tank issue
    1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button.
    (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
    (Do not release the Power button.)
    3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
    (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
    During initialization, the LED blinks in green.
    4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
    After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
    *** 4 times Green Waste ink counter resetting Both the main and borderless print waste ink counters are cleared.
    Canon i70 InkJet Photo Printer
    Feb 21, 2011 | Cannon i70 Printer
    My Canon Pixma IP400 is not working and the orange light is flashing 5 times
    How to reset waste ink / blinking printer canon ip4200
    With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
    While holding the Power button, release theresume/Cancel button. (DO NOT release the Power
    button.)
    When the Power LED lights in green, press the Resume/Cancel button the specified number of
    time(s) setting).
    After pressing the Resume/Cancel button the required number of times -you must press the On/Off button to perform the task. For Example Pressing Resume/Cancel 1 time, then press On/Off - does a Service Test Print
    Time(s) LED indication Function Remarks 0 times Green (Power) Power off When the print head is not installed, the carriage returns and locks in the home position capped.
    1 time Orange (Alarm) Service test print .
    2 times Green (Power) EEPROM information print
    3 times Orange (Alarm) EEPROM initialization
    4 times Green (Power) Waste ink counter resetting
    5 times Orange (Alarm) Destination settings After entering the destination settings mode, press the Resume/Cancel button the specified number of time(s) to select the destination. For detail, see "Destination settings procedures" below.
    6 times Green (Power) Print head deep cleaning (Cleaning of both black and color)
    7 times Orange (Alarm) Reserved
    8 times Green (Power) CD / DVD check pattern
    9 times Orange (Alarm) CD / DVD print position
    correction (horizontal: X direction)
    10 times Green (Power) CD / DVD print position
    correction (vertical: Y direction)
    11 to 13 times Orange, Green, Orange(Alarm,
    Power,Alarm) Return to the menu selection
    14 times Green (Power) Left margin correction Not used in servicing.
    15 times Orange (Alarm) Return to the menu selection.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Dec 23, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
    My canon pixma ip4200 flashes orane 5 times
    While holding the Power button, release the resume/Cancel button. (DO NOT release the Power
    button.)
    time(s) setting).
    Thanks, Joe
    Dec 23, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
    Five flashes pause then a further 5 flashes
    This error mean "non installed or defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number is QY6-0057.
    Nov 25, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
    Canon i550 LED error sequence: 7 orange +1 green flash
    According to Canon 7 orange flashes indicates a print head fault. Solution they recommend is to take it to one of their service agents. Problem is that replacement print heads are not cheap and it is usually more economical to replace the printer. You could try taking the print head to a cartridge refiller and have it professionally cleaned (cost you nothing or next to nothing) and see if that solves the problem.
    Sep 19, 2009 | Canon BubbleJet i550 InkJet Printer
    Canon Pixma 210 series has an error code 6000, won't print or scan
    Hope this helps
    With thanks to a canon tech
    Ok Well again I will repeat this answer with a titch more detail.
    The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
    Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
    I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
    Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
    1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
    2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
    3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
    4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
    The number of the Reset
    button pressing
    LED Function Remarks
    0 time Green Power off
    1 time Orange Service pattern print
    2 times Green EEPROM print
    3 times Orange EEPROM reset
    5) Unplug cable power. (for MP145 / MP150)
    6) Turn Off Power. (for MP160)
    Error Code :
    E2-2 = No paper (ASF)
    E3-3 = Paper jam
    E4 = No ink
    E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
    E8 = Waste ink absorber full, or platen waste ink absorber full
    E9 = The connected digital camera / video camera does not support Camera Direct Printing
    E14 = The Ink cartridges whose destination are wrong
    E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
    E16 -E19 = Failed to scan head alignment sheet
    E22 = Carriage error
    E23 = Paper feed error
    E24 = Purge unit error
    E25 = ASF(cam) sensor error
    E26 = Internal temperature rise error
    E27 = Waste ink absorber full or platen waste ink absorber full
    E28 = Ink cartridge temperature rise error -
    E29 = EEPROM error
    E33 = Paper feed position error
    E35 15 = USB Host VBUD overcurrent error - USB
    E37 17 = Abnormal motor driver error
    E40 20 = Other hardware error
    E42 22 = Scanner error
    May 22, 2009 | Canon PIXMA MP150 All-In-One InkJet...
    Canon i560 won't print
    The green light snable, no flashes.But test-print page is empty. All cartridges are full. Print head was reinstalled.
    Sep 14, 2008 | Canon BubbleJet i560 InkJet Printer
    Printer Problem
    This was not the sollution for my pinter..
    My Magneta is half full and my error led is also blinking 15 times
    I found this service manual for the IP4200 but this methode also doen not solve my error led..
    Is their someone who has the sollution for this strange error?
    selectable.)
    button.)
    Power
    in
    time(s)
    setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
    >>>>>>>>THIS ONE
    4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
    in servicing.
    Time(s) LED indication Destination CD / DVD print
    0 times Green (Power) No change of the destination
    1 time Orange (Alarm) Japan Supported
    2 times Green (Power) Korea Not supported
    3 times Orange (Alarm) US Not supported
    4 times Green (Power) Europe Supported
    5 times Orange (Alarm) Australia Supported
    Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
    364 people viewed this question
    k24674
    Marvin
    Marvin
