Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
Remote I have tried to get my remote for the above software to work with winlrc and girder or even any other remote thing out there not working. The remote only works with the bundled software. Is there a way out of m,y situation. And anyone who needs drivers mail me kollector79@yahoo.com
  • Anonymous Sep 14, 2008
    Just the same I have an saa7130x card and cant get plugin for girder, winlirc, I have even tried PC remote....my remote cable is wired to a port on the tv card
Where do I plug in the square end of the remote cable and how do I use it with the remote
Posted on Aug 27, 2008
Will not work even with new batteries
https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=8095517
This is a link to encompassparts.com if you log in as a guest this remote is available for $ 20.30.
Does the tv work when trying a universal remote. Cable company remote uses 0812 as a code for many of their remote controls.
If you can verify the remote is the trouble order on line above. Or check E-bay for a used one.
Jul 12, 2011 | Samsung BN59-00849A Remote Control
I followed the instructions (Brookstone giant remote and Samsung TV) above for manual programming and it worked.... that is it went on. But the volume control doesn't respond and I can't change the...
sometimes there is more than one code that will work for your tv even though its not the right one. Try all the samsung codes even if you found one that worked, try the rest.
Samsung - 043, 048, 054, 057, 062, 073, 074, 075, 078, 080, 089, 092, 097, 104, 112, 117, 118, 125, 131, 139.
Feb 09, 2011 | Brookstone 538744 Remote Control
Harmony 550 remote - buttons not working
Hey!
Unfortunately most things you need to do would require access to the Harmony Remote Software. However, the only advise I would have is for you to remove the batteries and try putting them back in.
Sorry I couldnt be more helpful...
-Kennedy
Dec 25, 2009 | Logitech Harmony 550 Remote Control
I just got a dish installed and cannot program the remote control
What you can try:
- Check the DirecTV code set for the following brands:
Funai, Symphonic, Sylvania, Aventura, Durabrand, ESA, Magnavox, INSIGNIA, and Misakai
Your set and the above-named are all built by Funai.
Even if you find one that works, it probably will not give you full functionality as would the original TV remote, which you can probably find at http:\\www.remotes.com
Before you buy any 'universal' remote, please don't expect it to absolutely work with your set; there is no such thing as a 'universal' remote.
If you find one that interests you, take the time to look up the mfr.'s website and check the code lists for your set.
Sep 04, 2009 | Emerson EWC1303 13 in. TV/VCR Combo
My remote suddenly stopped working.
If you're seeing on the LCD of the DVD player something like "DVD1" every time you press a button on the remote, try this: Change the command mode of the remote to match the player. Do that by holding down the Enter key on the remote and pressing the respective number. In my example above, hold Enter and press button 1 to set the command mode of the remote to DVD1. I had this problem and even unplugging the player didn't help, but the above worked for me.
Jul 16, 2009 | Sony RDR-VXD655 Recorder
The remote control will no longer work even when I put new batter
Sometimes the IR receiver bug in the tv goes out.
To clarify. The remote RM1 for TV 1 will not work on TV1, but the remote RM1 works on TV2.
If this is the case, answer is above.
Best Regards,
Charles
Jan 09, 2009 | TruTech PLV16190 Television
Intermittently Working Correctly with DirecTv
Update your Harmony remote control software on your PC to the latest. Go into the TV device settings. The software should recognize if there is an update to your TV's IR commands. Try the same things with the DVR.
It's also possible the TV and/or DVR are locking up due to IR commands that are being sent too quickly. The remote has a setting for the delay between commands sent to the same device as well as the delay between commands sent to different devices. Try adjusting these settings:
  1. In the Harmony remote software on your PC, click the "Devices" tab.
  2. For the "TV" device, click the "Settings" button.
  3. Click the dot next to "Adjust the delays" and click Next.
  4. Adjust the "Inter-key" and "Inter-device" delays to something higher and click Next.
  5. Follow the steps to save the changes.
  6. Repeat steps 2-5 for your DVR device as well.
-=Zzed=-
Feb 19, 2008 | Logitech Harmony 880 LCD Remote Control
Logitech Harmony Remote
Check the batteries are OK Uninstall it's software, reboot and reinstall it. See if there's a return to default option in the software. You may have mucked things up when you tried changing the configuration. Sorry I can't give more advice I don't know the hardware at all. BMW
May 15, 2006 | Logitech Harmony 628 LCD Remote Control
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
95 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
