Question about General Electric WJRR4170GWW Top Load Washer
My washer GE model # WJRR417OG1WW, has not been a good purchase from the beginning, but it is now filling up with water fine, drains fine, the switch on the control panel goes through the cycle fine, but it will not agitate or spin out at all. I have checked the lid magnet, replaced the belt, and the light on the motor flashed 2 x's. What is if any is your suggestions? Please help, thank you!
    Habit-Forming:
  • 60 Answers
Make sure the pin in or on the Agitator is not broken or sheared
Posted on Aug 09, 2017
MNfisherman
  • 11896 Answers
SOURCE: have a wjrr417og1ww washing machine. it is about
Check to see if the motor is spinning the belt. If the motor is not spinning, check to make sure there are not loose or broken wires. you can use a mutli-tester or ohmmeter/voltmeter to check any relays and fuses. If all fuses and relays are good, check to see if there is power coming from power supply to motor. If there is power, the motor is bad, if there is not power, the power supply may be bad.
Posted on Jun 15, 2009
gbaker30
  • 4 Answers
if ther was a power surge or power went out machine needs to be reset unplug for 1 minute then replug unit in and open lid 6 times in 12 seconds it should reset . that is what i had to do with mine
Posted on Jun 26, 2009
SOURCE: doesnt agitate or spin.
Mine is 1 1/2 years old and this worked for me
unplug from power for at least 30 seconds
turn the dial to spin but don't pull out
plug back in to power and open and shut completely so switch is engaged solidly 11 times in 15 seconds.
pull out knob to turn on
This should clear a error code.
hope it helps!
Posted on Jul 30, 2009
nikeananth
  • 267 Answers
hi, reset the printer.
open th right door,without paper then close the door
it work
thank you
Posted on Sep 22, 2009
TheMobilian
  • 8220 Answers
SOURCE: BAD LID SWITCH
This MANUAL shows how. What you must do is remove the front panel. It is kinda tricky. Use a thin blade to release clips between the top and front panel then tip the front panel towards you and lift it out yer way. Then you can remove the screws holding down the top and get to the switch.
Posted on Jan 29, 2010
Water continuously drains and fills, and never gets particularly high
You will need to check you washer drain hose and make sure it is only inserted into your house drain pipe in the wall no deeper than 4-6 inches, alternately your house drain needs to be as high as the top of the washer lid. Be sure to secure your drain line from the washer to one of the water shut off fittings with a zip tie. You are most likely experiencing a siphon action because the washer hose is inserted too deep in the house drain. Pleazer Appliance...
Apr 17, 2014 | GE GTUP270EMWW Washer
Ge load size selector broken
You can buy this part, suggest you go online and purchase it. Contact this website: Appliance Parts Accessories Repair Help
May 19, 2017 | GE Profile WPRE6100G Top Load Washer
Water runs but doesn't fill tub and wont spin if put on spin cycl
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 09, 2010 | GE WBSE2090A Top Load Washer
My GE Profile top load washer won't hold water
Your drain line is too low or has a blocked air gap. Take the drain line out of the drain. Hold it up high and turn the washer on to fill. If it fills and begins agitation,repair the drain line problem.
Sep 08, 2009 | GE Washing Machines
GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Jul 15, 2009 | GE WDSR2080D Top Load Washer
GE wcxr1070a washing machine. fills with water
Check the water level switch and the plastic tubing to the switch.
Sometimes soap scum stops up the plastic hose and the water level switch does not close to send power to the timer.
If the plastic hose is good and the water level fills and stops replace the water level switch.
Mar 21, 2009 | GE WCXR1070A
GE Washer fills but will not run through cycle
Sounds like a bad motor. It's likely shutting off from it's internal thermal switch. Try unplugging the motor's molex connector and replugging it, it could also be a loose connection.
Good luck.
Feb 21, 2009 | GE Washing Machines
Fixn my GE washer spin cycle
It sounds like it could be the lid switch, check to make sure the lid switch is clicking when you close the lid.
Jun 27, 2008 | GE WHRE5260E Top Load Washer
GE top load washer won't drain or spin
there was something stuck in the water pump. we pulled it out and good to go.
Jun 14, 2008 | Washing Machines
Pos ge washer WCSR2080B
Sounds like u might be having trouble with the lid switch.. U need to also check you water pump out.. this model has a electric pump that may be plugged... dont take much to plug this pump up.. have you taken front panel off yet ? Post what ya find
Oct 16, 2007 | GE WDSR2080D Top Load Washer
General Electric WJRR4170GWW Top Load Washer Logo
88 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
