Question about Seville Classics MSC10166 Tower Fan
The fan has been working fine. One day i unplugged it to move to another room, plugged it in and it didn't turn on. The outlet is good and the fan is one or two years old.
  • 1 more comment
  • shubhaK Aug 22, 2008
    Ditto --
    It was running fine. I moved it to another room and it stopped working. Can you suggest a solution ? - Thanks.
  • Anonymous Sep 08, 2008
    I bought a Model: 10187B on 6/28/2008 at Costco. all of a sudden it won't run on the medium speed. It only oscilates, but there is no air movement. The high and the low speed run well. Does any body have experienced the same thing?
    Louis A. Wunderlich
  • YFU68 Apr 21, 2009
    I have the same problem where all the mechanism seems to work (light), but the fan is not working in any way. Please give me a place where I can have this fan fix please? My email address is: yfu68@yahoo.com. Incidentally, where do I find the model number in he fan?
    Thanks.
    Dorothy
Possible Solution :
Taken From :
http://www.fixya.com/support/t193631-am_trying_fix_oscillating_tower_fan
"Most fan motors for fan over running have an internal overload. once it trips, it will not reset. it is a solid state device. it looks like a flat device or a small bullet device. if you've figured out how to take the fan apart, you could just remove the device and connect the two wires together and the fan will run. you won't have any protection on the motor however. the windings run warm, but if the bearings run dry the motor will slow down and the windings will get hot. this is the reason for the overlaod device - protection. its your call what you want to have."
Posted on Aug 22, 2008
  • 3 Answers
When I open the fan I found one capacitor disconnected from the board, I only resoldered the cap and it works very good.
Posted on Feb 05, 2009
My seville classics tower fan no longer oscillates - how can that be fixed?
Throw it away and buy a new one for 20 box at Wal-Mart. It's as simple as that cause to fix it, it'll take a new machine which cost twice the price. I think they made it to last one summer max. Friendly yours
Jul 01, 2014 | Seville Classics MSC10166 Tower Fan
Why blades are not rotating or throwing air?
some of these have a expansion pin that holds the fan blade assembly onto the shaft, this may have fallen out or ? broke,,,
May 13, 2014 | Seville Classics MSC10166 Tower Fan
My fan makes a loud squealing noise upon starting
open the tower if you can and check if some obstruction of wire is there or not. caution turn of the pwr before doing that . if no obstruction then the fan has to be replaced. open the fan carefully take it to best buy or wallmart and get it replaced.
it is possible for the older computer that the fan goes bad or moves faster than its normal speed . its a common problem with all brands of computer.
May 07, 2010 | Seville Classics MSC10166 Tower Fan
How do you clean it? It shoots out dust!!
You need to change the air filter, make sure you clean out the air filter chamber before installing a new one. it should be fine then, Good Luck
Feb 07, 2010 | Seville Classics MSC10166 Tower Fan
Fan vibrates either in stationary or rotating position
Vibrations are a cause of friction. I can only assume that the motor or the fan veins are being interferred with. If you feel comfortable you can take the case off and look or take it to a repairshop and have them look it over.
Aug 20, 2009 | Seville Classics MSC10166 Tower Fan
The fan fuse 1.5A/250V is keep blown up as soon as
Unplug the fan.
Open it up carefully.
Look at the the wiring for damage or shorts.
Check that the fan impeller is free to turn.
If all of the above is OK then possibly the motor has gone? If so then it will probably be cheeper to buy a new one.
Jul 02, 2009 | Seville Classics MSC10166 Tower Fan
Dust inside the fan
you can remove the topcover and can be cleaned using the brush and or vaccum cleaner/ even blower
Jun 01, 2009 | Seville Classics MSC10166 Tower Fan
To take apart: see solution #1 (not a complete disassemble but helps)
Aug 15, 2008 | Seville Classics MSC10166 Tower Fan
Seville classics model 10166
bottom stand was broken. how to get new bottom part.
Dec 06, 2007 | Seville Classics MSC10166 Tower Fan
Seville Classics MSC10166 Tower Fan Logo
2,871 people viewed this question
Top Seville Classics Dryers Experts
Are you a Seville Classics Dryer Expert? Answer questions, earn points and help others
