When turning on computer two of the three lock lights blink and then the computer turns off.
  • 17 Answers
The situation is actually called No Post, this usally happen if any part of the computer is not able to get power or not able to complete the power on process, when you switch on the computer the power flows in to all the parts of the computer, if any part is not responding to the power you will face no post issues which you currently have, please chat with us so we can walk you through the troubleshooting steps as one time solution can not fix the problem
Posted on Aug 14, 2008
SOURCE:
What would cause the power light to blink red and the tv will not turn on
three times red light blink mean DC Alert which is related to system in internally & some time sound ic problum
Jul 12, 2014 | Sony KDL Televison & Video
Blinking auto lock Whirlpool
What does it say in fine print right under control lock? "Press & Hold"? Page 16 of the user manual shows it as "air dry" with two lights, twelve and three o'clock positions. It says hold it for four seconds and the light turns off.
Aug 20, 2012 | Whirlpool GU1200XTLS Stainless Steel...
MY HP 60 235DX WILL NOT TURN ON. I TOOK BATTERY OUT AND HELD DOWN POWER BUTTON, PLUGGED IT BACK IN AND IT STILL WILL NOT WORK. NO POWER LIGHT WHEN THE POWER CORD IS PLUGGED IN. BUT WHEN I DO PLUG IN...
fan turns? hear it and feel it.blow.? in must.
cd drive ejects? (button)
no text ever on the screen? this is first. all else more complex.
do the flash light trick?
http://www.pcdied.com/monitors.html#flashlighttest
no beeps
no flashing caps lock key (codes) if yes, what code.
step one is get BIOS and its screens working
even using and external VGA monitor will help.
and the magic Fn+F4 key to turn that on.
hp is down this morning...(support pages)
the G60 series uses a CCFL lamp, that blows out (easy)
or its inverter.
if external monitor works, and flashlight trick works
CCFL back lamps are dead.
Aug 23, 2017 | HP G60-235DX Notebook
I have a problem with the remote control that is not working, I have taken it local technicians but nothing . My TV is in child lock so I need a remote for the tall big telefunken TV
Hi what you can do is to buy a universal remote control for this TV to remove the child lock. You can get that online or on any electronic shops in your area. Once done here is the instructions on how to remove the child lock using remote.
Look at the "Power" indicator light on the front of the television to check if it is blinking. When blinking, the child lock is enabled. You can also check by pressing the "Power" button on the television.
Point the remote control at the television and press one of the buttons on the number keypad. The "Power" indicator light will stop blinking, indicating the child lock is turned off.
Lock the television again by pressing and holding the "Power" button on the remote control until the indicator light starts blinking. It takes approximately three seconds before the light turns on. Thanks
Feb 01, 2011 | Televison & Video
IT TURN OFF ITSELF RIGHT AFTER TURN ON GREEN
If the Lamp red light is blinking then replace lamp, replacement procedure is written in user manual and its easy.
If standby/ power red light is blinking then please count its blinking and post here. It is an error code that has info about problem in specific section of tv.
You will see 3 seconds long pause between blinks so count pause to pause.
May 11, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Headlights, interior lights are out and service 4x4 light is on
try disconnecting the battery for 10 minutes. Then if you have a remote lock, lock and unlock three times in a row as this will often reset the computer. Or, borrow a code reader from one of the parts stores and see what codes are stored. Once you have the code, go online and Google it.
Jan 09, 2018 | 2002 Dodge Dakota Club Cab
I have a hp 1150 printer after initiallizing all 3 lights r on. What might b the problem.
I went to the HP web site. If the three lights are blinking in turn, the printer is still trying to initialize or clear a previous job. If all of the lights are on but not blinking, you should turn off the printer and then turn it back on. If that doesn't help, turn it off and unplug it for 5 minutes before plugging it back in and turning it on. If the printer still gives an error, contact HP. If the three lights are blinking simultaneously, you have a memory error. However, the DIMMs are not replaceable on the HP 1150, if I understand correctly.
I hope this helps. (Please note: on many USB printers, it is useful to unplug the USB cable from both the printer and the computer, as well as unplugging the power cable when attempting to clear an error.)
Jul 27, 2009 | HP LaserJet 1150 Printer
I spilled soda on my dell latitude D620. I let it dry and now when I turn the computer on three green lights blink and nothing happens. The three lights include the caps and num lock. What should I do?
Take it in to a computer repair store. They'll clean out the parts you're never supposed to touch...for a fee.
Please exercise caution in the future. Love your machine.
Jul 09, 2009 | Dell Latitude D600 Notebook
BLINKING Num Lock, Caps Lock & Scroll Lock
Put the RAM back in or check the RAM in securely
Apr 13, 2009 | E-Machines AAFQ50400000K0 Keyboard
Rca model d52w19
blinking light indcate a processor shutdown.. the processor has detected a problem in safety circuits and shut down the set. common problem are flyback and horizotal ouptut transistor. the processor has a error log file. technicians can plug a specail computer and read those to determine problem
Oct 28, 2007 | RCA D52W19 52" Rear Projection Television
Open Questions:
Computers & Internet Logo
56 people viewed this question
Ekse
Marvin
Marvin
