Question about HP DeskJet F380 All-In-One Printer
Hi i ran out of paper while printing. ive put more paper but is telling me i need to so something else and when i go to print it still says out of paper. what do i need to press??
  • robertamoffe May 18, 2011
    what is the ok button look like?
    re above. ive pressed every button on the side but still nothing woking and saying out of paper?? sorry dont have a clue what i am doing!!
  • 823 Answers
Press the "ok" or "enter" key on the printers keyboard to reset the printer. Then it will try again and recognize that it has paper in it.
Posted on May 18, 2011
Is there a sensor that tells the print head to
no sensor but what you need to do is to go into the properties of the printer in the printer icon in the control panel. In there will be a way to put the printer thru a realignment and once that is done the print should come out properly.
Jan 23, 2010 | HP Photosmart 8750 InkJet Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
Hi, it just stopped printing 1/2 way through a job - and has the red alarm button and yellow data button on - ive taken paper out - ive check toner etc .... im running out of ideas ive tried switching off...
1. is it possible to print a test page (Press and hold down the control panel button while turning on the unit and hold it until the drum led comes on. Release the button and press it again. if a test print prints, then you need to contact brother about the specifics of your problem, if it does not print, then you have a main board issue.
this is based on the error you are telling me.
thanks adi
Dec 12, 2009 | Brother HL 1430 Laser Printer
Color ink for ip1000 does not flow..??
Now put out u color cartridge and take one tissue paper or toilet paper then put ink color head to paper(soft pressure).after that see u paper are inside show three color appear in paper????(red,yellow and blue).if all have means you cartridge ok if only same or no any coming out means u color ink problem need to replaced new unit.
if got all color out better u open u printer body and check are all cable u plug in back is correct or wrong position??.second u can try go to printer preferences go to find print out in color or in gray-color and change their setting to print out in color
Sep 01, 2009 | Canon PIXMA iP1600 Printer
My Epson DX4000 Printer keeps getting paper jams and wont print
still printing but the paper goes no further?. It may be the paper is locked by paper feeder mecahnics, Open case, check it, and may be there is something "material" broke.
May 24, 2009 | Epson Stylus Pro 3800 InkJet Printer
HP Deskjet 3550 keeps printing in pink
HP Deskjet 3550 MODEL NUMBER:VCVRA-0202
Feb 05, 2009 | HP DeskJet 3550 InkJet Printer
Epson Stylus 580rx won't identify vellum paper
Ran into the same problem. The problem is that the printer's paper sensor sees through the vellum and therefore doesn't think any paper moved into the print position. To use vellum, fold up 1/4" edge on a standard peice of print paper and place the leading edge of the vellum under the flap. Place the paper and vellum into the printer and print. The printer will pull in the paper and the vellum together. Make the paper fold tight and straight to prevent jamming. You will need to feed one sheet at a time. Also the Epson inks take a long time to dry on vellum. I let mine dry overnight.
Jan 05, 2009 | Epson Stylus RX580 InkJet Photo Printer
Laser printer does not print
Hi there it may just be that the paper tray springs are not pushing the paper higher enough not making contact with the paper detect sensor arm. Or the sensor arm is broken and will need replacing. Check the tray springs also check the sensor arm you will see it if you remove the cassette and look inside there will be a black plastic lever hanging down when you put paper in this lever should go up as the paper acts as a barrier thus telling the machine that there is paper in it.
Thanks J
Jan 28, 2008 | Brother DCP-7020 All-In-One Laser Printer
PRINTING BLANK SHEETS
You need to put the test page that was printed into the scanner part of the printer and then press the scan/blue button. This is so the printer can calibrate the new ink. When you have done that the next time you turn on the printer a blank page will not be printed. When you next change ink you will have to repeat the above procedure.
Sep 01, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
83 people viewed this question
Seeker5211
Seeker5211
