Question about Hitachi WH18DL 18 Volt Lithium Ion Cordless Impact Driver
HITACHI WH18DL WH18 impact driver, i've just bought one but the instruction manual does not explain what the "s-p" switch is or does that is located on the side just above the trigger, can you help please?
greenspan
  • 1734 Answers
SOURCE: Hitachi RZPM18Y instruction manual lost
Just ask here, they are specialized in finding english manuals for chinese import items. They helped me a lot with my SciPhone mobile.
Posted on Aug 19, 2009
Mike258
  • 1498 Answers
SOURCE: Hitachi Cordless Impact Driver gearing problem
The speed shift slider switch wasn't lined up correctly when the unit was reassembled.
Unfortunately, you going to need to repeat the disassemble/reassemble process once more.
I've been there. It doesn't take much to be out of alignment. Set everything to the lowest setting (clutch, speed) and take your time.
Best regards
Mike
Posted on Apr 22, 2010
  • 142 Answers
SOURCE: I have a Hitachi 12V Cordless Impact Driver that won't spin at the chuck housing. Not sure what the problem is?
Make sure it's all the way in gear. It sounds like it's not all the way in first or second gear. Yes it sounds dumb, but it's one of the most common problems we see in our shop.
Posted on May 01, 2012
kdh1961
  • 312 Answers
SOURCE: Hitachi c10fsh doesnt start
brushes in the motor
Posted on Aug 20, 2012
SD Tech
  • 14553 Answers
SOURCE: I have a hitachi LCD rear proj tv, model 50vs69a. The picture is very dark ESP when watching a movie at night. I've tried all adjustments suggested in users manual with no success. Help!
Other than cleaning the three lens inside and the mirror it may be the age of the set.
Posted on Sep 04, 2012
EB1214S battery won't charge
On your there are pins make sure they are making tight contact it could be that your charger is not charging the batteries to it's full extent
Nov 04, 2012 | Hitachi Gst Hitachi WH12DAF2 - 12V Impact...
Why just suddenly wouldn't worki
When that happened to one of my drills, it turned out that the connection up inside the handle where the battery connects to the drill needed to be cleaned. I also had to use a screw driver to slightly bend the connectors inward (away from the side) on the inside so the battery would make a better connection. If that doesn't solve the problem, they there is most likely a loose connection in the switch or wires leading to the motor. I have never had the brushes go out on a battery operated drill so I would start with checking the battery connection first..
Aug 02, 2012 | Hitachi WH18DL 18 Volt Lithium Ion...
Singer confidence quilter beeps 8 times won't sew
http://www.singerco.com/uploads/download/549_7469_efs.pdf
http://www.singerco.com/uploads/download/683_7469_efs.pdf
here are 2 links for a free manual, you can choose which one you need
try changing the needle
if you just bought the machine,, you may have to take it back & get
another one
Jun 08, 2012 | Singer 7422
Apr 26, 2012 | Hitachi 12V Cordless Impact Driver
Two brand new Hitachi BSL1815X Lithium Batteries won't recharge (UC18YGSL charger and DS 18DSAL drill)
These batteries have big problems that Hitachi doesn't address very well. Unlike NiCad batteries, Lith-Ion ones must be periodically used and recharged to retain their battery functions, i.e. if they have been sitting on the shelf at a store for an extended period of time, chances are they will be dead when bought and will not accept a charge. If they go dead i.e. no little red light on the charger when you plug the battery unit in...it's basically junk.
If you can return them or exercise the warranty do so. If / when you get new ones DO NOT completely discharge them like you would NiCads. Lith-Ion batteries do not have the "battery memory" issues that NiCads have which means you don't lose running time if you don't fully discharge the battery unit prior to recharge. Completely discharging before recharge will ultimately kill them. Use the 1815X till almost dead and then charge it. It is also recommended Lith-Ion batteries not be stored fully charged i.e. charge the 1815X fully, drive a couple bolts or screws, remove the battery unit and then put it away. Do not leave battery unit plugged into the tool when you put the tool away. This will discharge and kill the battery unit.
There are non-Hitachi substitute batteries now on the market. I'm guessing the same precautions apply but I don't own one of the replacements so I don't truly know.
The actual batteries in the Hitachi BSL 1815X are Sanyo UR18650SAX lithium ion batteries. Lithium Ion cells aren't all that easy to get commercially because of handling & safety requirements. Not certain if you can take apart the 1815X and swap out the bad Sanyo cells.
Jan 07, 2011 | Hitachi Koki Usa WH18DL Lithium Ion...
Hitachi WH18DL 18 Volt Lithium Ion Cordless Impact Driver Logo
Top Hitachi Tools & Hardware - Others Experts
John Trevino
Joe Garcia
Joe Garcia
bwbconstruct
Level 1 Expert
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
