Question about Cell Phones
How to reduce the base ring volume - Cell Phones
  • yadayada
    yadayada May 18, 2011
    Without the make and model number I have no idea. You have not given either.
  • 29 Answers
In tone settings you will find volume opion
Posted on May 18, 2011
I have an uniden exa 2980 and losy manual,how do I obtain a copy.also how do I turn up ring volumn?
Uniden has the manual for the EXAI2980 here: https://www.uniden.com/File%20Library/FooterNav/Product%20Information/Owners%20Manuals/exai2980om.pdf .
Do you need to adjust the ringer volume of the base, the handsets or both? To set the ringer volume of the base, start with the phone in standby mode (no calls being made or received) then press Menu 4 times (the right-hand button in the row above the volume up/down buttons). You should hear the current ring volume and see it displayed on the LCD screen. Press Set (the left-hand button in the row above the volume buttons). Press Skip/FF or Repeat/RR (the buttons on either side of the Play button below the LCD screen) until the desired ring volume level is displayed. Press Set to save the setting. Press Play/Stop to exit the menu system. See page 38 of the manual (page 40 of the PDF above) for the directions.
To adjust the handset ringer volume, press the handset volume up or down buttons with the phone in standby. The last chosen ringer tone and volume will be saved. See page 16 (page 18 of the PDF). Sometimes, the handset will not ring after losing the security code that pairs it to the base. Remove the handset from the base. Press and hold Page on the base (between Set and Menu). While the handset is sounding the paging tone, replace the handset in the base. Leave the handset in the base until the flashing stops (more than 5 seconds). See page 47 of the manual.
I hope this helps.
Feb 12, 2018 | Uniden Lands Phones
I have a new uniden cordless D3097 series phone and I can't figure out how to have the handset ringer on and the base ringer off. When I turn off the base, the handset stops ringing
The Silent button on the D3097 is a global Do Not Disturb button. To reduce the ringer volume, press the Volume Down button on each handset when the phone system is in standby (not in use). When you have pressed the Volume Down button to the point where the ringer is muted, you will see an icon of a bell with a line through it.
See pages 6-7 of the manual for the details. The manual is available here: http://www.101phones.com/content/pdf/uniden/D3097.pdf .
I hope this helps.
Sep 18, 2017 | Uniden Lands Phones
When answering mode is on I do not want to hear the ringing(4x) tones before going to answering.I've switched off the 'call screen' option. still I hear the ringing although not recording at least.
Just set the ringing volume to off.
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level. Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according to their individual settings
May 29, 2015 | Uniden DECT 6.0 Cordless Phone ID
How to take off silent mode? I never programmed it to do this...
See if this helps
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
to their individual settings.
Oct 17, 2014 | Uniden DECT 6.0 Cordless Telephone...
Somehow the ringer got turned off. Can't figure
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
When i put my silence tone, the ring call is silent, by the messege tone is still ringing. How to set it up properly. Tq for your kindness to guide me what i should do.
Aslim, go to your profiles, select silent, before you select *activate*, select *personalise* in the ringing tone panel, select *no tone*, in the ringing volume panel, reduce the volume to nothing. In the message volume panel, reduce the volume to nothing also. Then select *save*. Then you can activate silent. This should help.
Apr 07, 2011 | Cell Phones
How do i set ring volume on a binatone veva 1200
If the serial number under the base starts with "VT" under the base unit:
Press OK, press the arrow down to HS Settings, press OK, press the arrow down to Ring Setup, press OK, press the arrow down to RING Volume, press OK then use the arrow keys to set desired volume, then press OK. You may want to change the volume on the base too, in that case, the same instructions but instead of "HS Settings" go to "BS Settings".
If the serial starts with a "B":
Press Menu, press the arrow down twice to HS Ringer, press OK, press OK again, use the arrow keys up/down to select required volume then press OK.
Nov 24, 2010 | Cell Phones
Can't hear phone ringing
Adjusting the Ringer Volume (From the Uniden manual)
  1. With the phone in standby, press ArrowUp or Arrow Down on the handset or VOLUME + or VOLUME - on the base. The handset or base sounds the ringer at that level.
  2. Use Arrow Up on the handset or VOLUME + on the base to make the ringer volume louder.
  3. Use Arrow Down on the handset or VOLUME - on the base to make it softer or turn it completely off.
  4. When you hear the ringer volume level you want to use, stop pressing keys.
  5. The handset or base will use the new ringer volume starting with the next incoming call.
  6. If you set the ringer volume to Off, the handset or base won’t ring.
  7. Other handsets or base will ring according to their individual settings.
Jan 03, 2010 | Uniden DECT 6.0 Cordless Telephone...
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Dec 21, 2008 | Panasonic KX-TG2357 Cordless Phone
GE 28851 base handset #1, will not save ringer tone or volumn I selected. Brand New.
As it turns out, the primary base handset did save the newer selected ring tone and volume level setting.
However, the base maintains its own ring tone and volume level setting from factory.
Therefore, the base will present its own settings along with the handset setting during an incoming call.
So, one has to lower the volume of the base (in non-talk mode). The base should display in window: LO.
Then, only the ring tone and volume level selected for handset will be presented during an incomiong call.
How did I do????
Ken
Jul 09, 2008 | Uniden Cordless Phone
Cell Phones Logo
14 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
