Question about Mantis 2-Cycle Tiller
Hard to start. Will not keep running. - Mantis 2-Cycle Tiller
Outboard starts but won't keep running
If you keep sqeezing the fuel bulb, will it keep running? If it runs then fuel pump problem. Also check for a clogged fuel filter.
Jan 04, 2015 | Boating
Hard start wont keep running
Use a bottle of yellow HEET dry gas to remove any moisture problem in the fuel.
Clean / replace air filter.
Top off ATF to MAX level.
Use starting fluid to aid starting.
Jan 18, 2014 | 2000 Ford Excursion
Burning anti freeze through the motor
Yeah,you have a blown head gasket,have a tow truck take to shop.
Mar 23, 2013 | 2001 Lincoln Continental
Hard starting, rough idle when cold, then smooth running when warm
Need year/make/model/mileage of vehicle to provide a more specific set of troubleshooting steps.
When was the last tune up? Hard starts when cold are usually caused by fouled spark plugs, worn plug wires, or weak ignition coils. Fuel systems are not as effected by temperature changes as the ignition components.
Nov 28, 2012 | Cars & Trucks
Ryobi 30cc trimmer won't run. Difficult to start, hard to keep ru
chnge the plug for the best you can get then depending on the mix petrol oil mix u could cahnge that ie if its 50:1 go down to 40:1 or visa versa if that doesnt work bin it and get a sthil or an ehco
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Hard to start and won't keep running. Fuel on spark plug.
your carburetor needs to be cleaned. after that it should run good. its just not pumping enough fuel to it.
Apr 06, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I ran my 98 bonneville out of gas. Now it is hard
try disconnecting the battery overnight. otherwise..you need a scan tool to read the codes and reset the computer
Jul 15, 2009 | 1998 Pontiac Bonneville
Mantis 2-Cycle Tiller Logo
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
