Question about Coleman Sport & Outdoor - Others
12 DV wiring diagram for a 2002 Coleman Laramie Pop Up camper. Works on AC fine. Battery is fully charged. However when I open teh camper and fold up the sink and set it up, nothing is working even the Co2 detector. Need to know how many connections are inside the frame tubing as I expect a loose connection or a coroded scotch lock. Ground has ben checked all the way through.
  • 69 Answers
SOURCE: Laptop does not work with AC adaptor, does not charge. Mother board issue
You may be able to get a battery charger but its rare.
If you do wish to use the AC adapter, take care with positive and negative. Also the voltage of the battery is actually lower than the AC adapter in order to get charged. I don't know what is going to happen if you do choose to use AC adapter as battery. 75% chance that it will work.
Posted on Oct 08, 2008
  • 13433 Answers
SOURCE: how to tighten cable on pop up camper
the adjustment can be done by your dealer, contact them see how much it costs.
Posted on Oct 26, 2008
  • 148 Answers
SOURCE: Wood Lining to Folding camper is wet
the best solution is to remove the spongy wood and replace with marine plywood
one possible fix is to glue(liquid nails) 4x8 vinyl sheets(used for bathroom walls and ceilings) over the spongy wood you should also determine where the support ribs are located and use rust proof exterior ( like deck screws) and put a washer through the screw and screw through the vinyl and sponge wood into the rib/stud to secure the vinyl do this about every 10 inches on the supports
finally caulk the edges and seams and put a lattice type of slat(1inch wide by 3/8 thick by 8 ft long on all exposed seams
tools needed small gig saw variable speed drill
caulking gun
I
Posted on Jan 02, 2009
270rexton
  • 762 Answers
SOURCE: HTC TOUCH HD charging problem
Well hope so you didn't damaged the sensors! try this : use the phone until battery is empty and switches off. then put it on the charger for 4 hours. If no joy,try different battery to make sure that device is not damaged and get a new battery.
Posted on May 12, 2009
  • 220 Answers
SOURCE: bettary problem or adaptor problem?
ac/dc convertor board inside laptop faulty.
Posted on Jun 30, 2009
Ive got a question about a 22 ft companion travil trailer
Plug it back in to the house electrics .then search for the inverter on the trailer .
Oct 13, 2016 | Coleman 1997 Fleetwood Sunridge Power...
What powers the slide out ?
If you are referring to a camper, the 12 volt auto battery powers them. Fully charge the battery first. there is a switch inside the camper to power the motors be sure its turned on. A lot of campers seem to have a problem with poor wire connections and broken wires. clean all connections check for broken wires and check fuses. good luck.
Apr 06, 2016 | Cars & Trucks
I need owners manual for 1995 coleman popup camper.I is a colman seneca.I bought it used and there was no manual with it.
If your looking for Coleman owner manuals or brochures call Beckley's! We have the last copies of these brochures straight from the factory. Limited quantities available so call 800-598-4048!
Pop Up Owners Manuals
  1. 1974 - 2011 Coleman Folding Trailer Owners Manual
Nov 01, 2014 | Sport & Outdoor - Others
Why wont my rv thke a charge
i am asssuming that you are talking about your coach battery bank.are they 12 volt or 6 volt battery system. the arc is a short. check polarity. can you charge the batteries with an external battery charger? if so. then need to check converter output from your mian power panel. there are a few other things to check. need more specifics. and you need to have a volt meter handy.
Jun 21, 2014 | RVs
Hi.. 2002 vw golf 1.9 l diesel airconditioning stopped working its fully charged i had the battery and tray out and cleaned all grounds under the battery tray put it all back together and the ac worked...
Check the coolant sensors. One sensor, when coolant is overheated, cuts the ac off, this sensor may be stuck electrically open, only two wires going to it. Other sensor has four wires, two for temp gage and two for engine management.
Sep 11, 2017 | 2002 Volkswagen Golf
Interior lights, appliances work fine when plugged
Check for a faulty inline fuse or circuit breaker at harness attached at front of trailer. Follow positive wire back to trailer.
Jul 11, 2010 | Coleman 10' X 10' Sundome Tent 9160K101
I have a coleman cheyenne 2000 pop up camper and none of the lights will turn on to include the carbon monoxide alarm. All of the outlets work fine. We checked the fuzes and flipped the switch. We also...
when towing my camper it seems my running lights do not stay on andmy brake lights and turn signals do not work properly. I can giggle the harness wires and everything works.
Jul 08, 2010 | Camco Battery Fridge Refridgerator Alarm...
Sport & Outdoor - Others Logo
278 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
