Question about Jamo Audio Players & Recorders
My Jamo DVD player keeps ejecting the discs. - Jamo Audio Players & Recorders
hardrocko
  • 1476 Answers
SOURCE: dvd won,t eject
This is going to require opening the unit and taking the DVD unit covers off. If you feel confident and are good with tools and have a good memory (to remember how it all goes back together), you should be able to get the DVDs out. Just remember to be careful inside the unit, go slow and don't force anything. After the DVDs are out and you have the unit back together properly it should be OK if no damage was done to the laser assembly. Good luck.
Posted on Jun 26, 2006
SOURCE: Insignia DVD Player
Try hitting the "Lock" button on the remote. That solved the problem for us.
Posted on Jan 28, 2007
  • 4102 Answers
SOURCE: dvd player will not read disk
have you tried getting a lense cleaner as they sometimes get alot of dust and will stop signal from disk to the laser if this dont solve the prolbem then you are looking at replacing the laser unit itself if the cleaning dont work and you think you are capable of taking the casing off make sure you switch it off first this should send the laser to the center of the laser tray if you take the case off and it is not in the center it might just be that it has got jammed now sometimes gently pushing it back to the middle will get it working again if it is already in the middle then it could be that the laser needs replacing but if not in middle push gently dont gerk it it should be quite stiff to push any way when you push back to middle try a disk with the casing off but please make sure you dont touch anything whislt it is plugged in if nothing works then it probably is the laser but before you do anything as soon as you get the case off switch it on and put a dvd in and make sure the disk is spinning if not laser unit is nakered and need replacing let me know how you get on hope this is some help to you
Posted on Nov 26, 2007
SOURCE: dvd recorder doesn't eject disc
HOLD STOP BUTTON AND OPEN CLOSE BUTTON AT SAME TIME FOR 3 SECONDS REPEAT TILL DOOR OPENS
Posted on Feb 19, 2008
SOURCE: It keeps ejecting the disc and saying disc error
Now what this joker isn't telling you is that the 'hack' below actually resets the player to factory defaults. It just worked for me perfectly.
Now you might have to go back into setup and readjust some of your settings. (i.e. freq response)
1. press SETUP on the remote
2. Go to "TV Aspect" and move the cursor to "16:9"
3. Press in order: 1, 3, 9, 7, 1, 3, 9 on the remote, then press ENTER
Posted on Apr 13, 2009
No disc error dvd
You need to try cleaning the lens of the player. If that doesn't correct it you might have lens damage.
Jul 28, 2013 | Harmon Kardon Harman Kardon Bds 400 2.1...
DVD NOT RECEIVING DVD DISCS
Hello
The loading mechanism has the trouble. The inserted CD or DVD does not engage into the laser assembly unit properly. It may be due some fault with its loading motor or loading belt. Check these.
Mar 02, 2012 | Jamo DMR 60 DVD Player/Receiver
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
Does any universal remote work for the jamo dvd player?
There are no official (or unofficial) universal remote codes for Jamo DVD players or any Jamo product.
The actual universal (and one-for-all) remotes are available, but there aren't any preset codes for this brand or model unit.
Mar 29, 2011 | Jamo DMR 60 DVD Player/Receiver
The DVD player is in constant eject mode - discs will not stay in to play. It has worked perfectly for years. Tonight I was watching a disc, finished, ejected it and put in another and the player just...
Two possible scenarios: First the optical pick up assembly that read the disc has malfunctioned or the eject button is faulty. Either way it is just cheaper to replace the DVD player with a standalone dvd player connected to one the tv input(s). Too expensive to repair just the dvd player if it is tv/dvd combo. The cost for labor and parts is more expensive these days to repair tvs or dvd player. For around $30 you can just replace...much more cost effective.
Aug 15, 2009 | Sylvania 6620LDF 20 in. EDTV-Ready LCD...
Jamo DMR61 rejacts the disc for no reason and it doesent load the disc.
Clean the head,if it not load the disc you need to change the head unit.
Aug 14, 2009 | Jamo DMR 60 DVD Player/Receiver
Jamo, DMR 61 keeps rejecting DVD and CD; player not reading disks
The dvd mech assy is defective and needs to be replaced.
Mar 30, 2009 | Jamo DMR 60 DVD Player/Receiver
Jamo DMR60- sound doesn't match dvd
I have the same problem. I have been in contact with Jamo Denmakr and Norway. They are aware of the problem. There are two issues/answers:
1 If the DVD your're playing has scratches reading error accumulate and then audio sync problems occur. (My meaning is lo quality DVD drive). You might overcome this by reburning the divx file to a new disc to avoid read errors.
2 The DVD drive itself is defective and should be replaced. Warranty should cover this of course. I do receive my DMR-61 this week after DVD drive change. I hope this will fix it...but I don't believe so. Crossing my fingers.
Henning
Jan 02, 2008 | Jamo DMR 60 DVD Player/Receiver
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
Top Jamo Audio Players & Recorders Experts
Electro Med Services...
Tom Chichester
 Grubhead
Grubhead
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
