Question about Sony PlayStation Portable (PSP) Console
Please help i restored my psp to default settings for the first time. now everything is okay except with the x and o button. they switched functions! the o button became the "select" button while x button became the "back" button. what am i going to do?i just want them back to what they were before. please help me.thanks!
  • 135 Answers
Just go to Recovery Mode on your PSP (just turn it off by holding the reset button for 10 sec, then hold the R button and turn it on while holding it) then go to REGISTRY HACKS, then you will see there the option "BUTTON ASSIGN". just press over it x or o, then you'll be back to "x is enter"...
Posted on Aug 15, 2008
My problem is not solved
how many times that i press the o there is happen...help please..
Dec 15, 2012 | Sony PlayStation Portable (PSP) Console
My son psp beep when you put a game in and the umd does not come up can you help please
f you are experiencing issues when using a Universal Media Disc (UMD™) on the PSP system, try these troubleshooting options:
  • Issues with PlayStation®Store content Click here for help with content purchased from the PlayStation Store.
  • Restore Default Settings Restore Default settings will default the PSP system to its original settings. A setting change may be the reason the PSP system is having difficulties. Click here to learn how to restore default settings on the PSPgo / PSP system.
  • Confirm UMD is properly inserted
    Make sure the UMD is properly inserted with the label facing the back of the PSP system. Try removing the UMD and reinserting it.
    Please note, it is normal for the PSP system to make noises while it is reading from a UMD.
    For PSP-1001, slide the latch to open the UMD door. For the PSP-2001 and PSP-3001, simply lift the door open.
  • Try playing the UMD on a different PSP system If possible, try playing the UMD on a different PSP system. If the disc still does not function properly, it might need to be replaced. If the disc does function properly, the PSP system may need service, see PSP Service for details.
  • Try playing a different UMD on the PSP system If possible, try playing a different UMD on the PSP system. If another UMD plays, the original UMD may be the problem. If none of the UMD's play, the problem may be isolated to the PSP system.
  • Check for moisture Do not let the PSP system or any PSP® accessories come in contact with liquid. Also check for moisture condensation in the PSP system. If moisture condensation occurs, remove the disc from the PSP and do not use the PSP until the condensation has evaporated, which can take an hour or two. In general, if any part of the PSP gets wet, discontinue use until it is completely dry.
  • Check the regional code Check the regional code on the UMD™ Video. The only regional codes that the North American PSP® is tested to work properly with are "ALL" and "1.
Tried these steps and still need help?
If you have tried the troubleshooting information above, but continue to experience problems, please contact our Consumer Services department to have your PSP system serviced.
Jun 28, 2011 | Sony PlayStation Portable (PSP) Console
I forgot my password for my psp now i cant use it what can i do?
Hello gracielarobl
You will need to restore the default settings. To do this, follow the following instructions:
STEP 1
From the XMB home menu, go to Settings > System Settings > Restore Default Settings
STEP 2
The message "Do you want to restore default settings?" should appear. Select "Yes", and press the "X" button.
STEP 3
You will then see a message, "All settings will be returned to default settings. Are you sure you want to continue?". Select "Yes" and press the "X" button.
STEP 4
All settings are now restored and the system password is reset to "0000".
STEP 5
Press the "X" button to re-start the system.
STEP 6
Re-enter system settings as appropriate.
N.B. The Restore Default Settings feature will erase any previously saved settings and restore all the settings to default.
Hope this helps. Please don't hesitate to contact me should you require any further assistance.
ajblaj
May 03, 2010 | Sony PSP-3000 Black Console
My psp slim screen is shaking!
turn of your psp
1.turn on the psp by holding the (R trigger) you will be in the recovery menu
2.scroll down to CPU SPEED and change the xmb to default and game to default
this should work
Mar 29, 2010 | Sony PlayStation Portable (PSP) Console
I put in a new analog stick but my psp still dosent work right every thing wants to run left when i play games is there something else i need to change
Check your settings and restore them back to factory settings. Settings > Restore default Settings and okay it.
Regards
Nov 06, 2009 | Sony PlayStation Portable (PSP) Console
My psps keyboard shows up for one sec then goes away quickly before i can even type anything
Sorry about this please follow the steps i have outlined... put on your psp and go to System Setting > Restore Default Setting and press the O button. You can now restore to the default settings and go back trying to use the keyboard on your psp.
This should work for you.
Cheers
Apr 13, 2009 | Sony PlayStation Portable (PSP) Slim...
HELLLLPPPPP
First Remove the UMD from PSP if any
1. Switch ON the PSP 2. Press and Hold the Left arrow button until the Sound of "click" Stops. 3. Press and Hold the Up arrow button until the Sound of "click" stops. 4. Press the Down arrow button 4 times (so u will be in System Settings) 5. Press the Enter Button i.e X 6. Press the down arrow button 9 times so u will in "Restore Default Settings" 7. Press Enter button i.e X once 8. Press the Left arrow button once and then press X button once 9. Press the Left arrow button once and the press X button again 10. Press the X button
See whether u r PSP restart and solves the problem
Oct 19, 2008 | Sony PlayStation Portable (PSP) Console
Password
hey. well i just deleted everything on my PSP for you to figure out how to fix your problem, because i know how much of a pain that is =]. in order to get rid of the password, you must first go to the "Settings" icon all the way on the left. than scroll through that menu until you find the "System Settings" button. Than scroll through that menu until you find the "Restore Default Settings" button. If you click on that, your password will disappear and you can type in a new one. After you reset the PSP, you will have to type in the date, timezone, time, and PSP name all over again. Well Good luck =] glad i could help.
Jul 27, 2008 | Sony PlayStation Portable (PSP) Console
How do I reboot or restart psp to original or factory settings
From the XMB menu, go to [Settings] > [System Settings] > [Restore Default Settings]. Once you select Restore Default Settings, you will see a list of settings that will be restored. Scroll through them and press the X button to restore the settings.
Dec 20, 2007 | Sony PlayStation Portable (PSP) Console
My psp will not let my type it kicks me out
Nov 30, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
