Question about JVC HD-52G786 52" Rear Projection HDTV
My 52 proj JVC does not show picture. i replace the bulb 3 months ago and the tv had a great pic. I get audio but no pic. what is the problem? Its not the bulb. i do get brightness and when you tap the top lightly, the pic will come and then go.
  • 325 Answers
Bulb ballast needs replaced.
Here is a replacement:
http://www.discount-merchant.com/ProductDetails.asp?ProductCode=1209752&Click=54985
This will fix your problem.
THank you!
Posted on May 18, 2011
JVC HD-52Z575 tv shows only a grey picture screen. I was watching a channel and tried to change channels and new channel won't come up, only grey screen.
JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV
www.amazon.com/JVC-HD-52Z575-HD...HDTV.../B...
Amazon.com, Inc.JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV ... The picture was artifacted and the color was good, but not great. ... From 5' some minor issues could be seen and the MPEG2 format did show its limitations, but at 10', it was a truly great experience! ... There is no true gray temperature, only high and low.
HOW TO FIX A JVC HD BIG SCREEN TV - YouTube
? 6:38
https://www.youtube.com/watch?v=r4v-xzUpQDM
Apr 11, 2012 - Uploaded by kyle dubb
Did your HD D.L.P. t.v. stop working? This movie clip will showyou step by step how to easily fix your big ...Missing: grey
JVC HD-52Z575 HD-ready rear-projection D-ILA monitor ...
Jan 10, 2016 | JVC Televison & Video
TV turns on, hear sound but no picture. Bulb isn't coming on. TV goes off after about 2-3 minutes. Bulb was just replaced 5 months ago.
Need the model number of the set and also if any lights on the TV come on or blink when the picture goes out or not.
Feb 09, 2013 | Televison & Video
I have a jvc ilha tv I replaced the bulb 5 months ago the last 5 weeks it has been really dark picture i replaced with a generic bulb and was fine at first any recommendations?
you need to get the original bulb from the company's authorised service dealer. these bulbs are of very specific type. & will work with same type only.
Sep 26, 2011 | JVC Televison & Video
Have a jvc hd rear proj, m#hd52g886 new lamp light on front keep flashing and no picture...Help
seagoblin28,
If you haven't replaced the lamp you should. If you have replaced the lamp you may just need to reset the unit. Go to my tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains where to get the lamp at the best price and how to replace it as well as links to additional problems.
Thanks for using Fix Ya and for the great rating.]
hardrocko
Feb 18, 2011 | JVC HD-52G886 52" Rear Projection HDTV
Tv turns on and off 3 times before picture appears
Ballast Board its what turns Lamp on Call Encompass or visit their website. 1-800-638-3328
Dec 14, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
Jvc 52z575 dark TV
The life estimate for a bulb is about 5000 hours, and if the bulb is dieing before that is very obvious you have another issue on the TV
That Could be a temperature problem, like a cooling system is failing (usually the is two fan around that) or a lot of dust in the cooling system. another one could be temp sensor also maybe failing and is not sensing high temperatures and is no turning off the TV
Also make sure you have enough ventilation in the back of the TV
Hope this give you a better idea of the problem
thanks
Apr 23, 2009 | JVC AV-48WP30 48" Rear Projection...
No picture
The lamps life span is 1 - 3yrs, Purchase your lamp directly from JVC.com $199 they back up there products. Good luck
Jan 27, 2009 | JVC HD-52G786 52" Rear Projection HDTV
SONY 60" KDF-60XS955 power goes off and on every 30 sec I have the same 30 sec on/off problem with a Sony KDF-E60A20 60 in. HDTV LCD Television.  However, the actual power does not go off completely, just...
its the bulb i have the same problem with that model the service tech said life spann on bulb is 2years he replaced it fixed you have to readjust all the pic settings because new bulb make pic too bright
Dec 27, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
RCA D52W19 52 in.
Replacing any or all of the crt's in a proj TV is a difficult challenge for any qualified technician. It's not something normally done in the home either - because of the adjustments and tear-down required. I'm assuming you have a crt that does not have the cooling chamber already on it. And therefore you'll need to attach the cooling chamber and fill it with EC (a clear fluid similar to anti-freeze) that keeps the crt from overheating. Then there comes the job of alignment. I would assume you don't have a pattern generator or some of the other equipment you'll need. I applaud your abilities thus far but here's where I'd STRONGLY recommend you get a reputable shop to do the install. If you would like some help finding one call NESDA (National Electronic Service Dealer's Assn.) and ask about member shops in your area...
Jun 01, 2007 | RCA D52W19 52" Rear Projection Television
JVC HD-52G786 52" Rear Projection HDTV Logo
71 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
