Question about Samsung B5722 Cell Phone
Touchscreen problem..for eg; on the main screen, whn i touch menu..phonebook appears whch is a button on immediate left and likewise.. plz help
    Sergeant:
  • 158 Answers
This is touchscreen problem, need to replace with a new one. You can buy it on ebay.com and get the service manual level 1,2 and change it.
Posted on May 18, 2011
How do I fix when I touch a key to put in information and it prints a different number or letter than the one touched
Here is a way to recalibrate the touchscreen without having to go through the menus:
If your Nuvi has the problem that when you press one key but another key is highlighted, then either your touchscreen is defective or it is miscalibrated.
For example, pressing the letter "A" on the QWERTY keypad, actually highlights the letter "S" or "Q" or "Z". On the non-QWERTY keypad, this may show up as "B".
Method #1: If you can get to the main menu, press the "wrench/tools" icon and then the "Display" icon. Now press the calibrate screen button and go through the entire procedure of pressing each dot as it appears on the screen until it says "Done".
Method # 2: Follow this procedure if you can't get to the main menu or any menu thereafter.
First, turn the unit OFF.
Nuvi 3xx & 6xx Series: Hold down the on/off power button and don't let go of it.
On the screen it will say "Pre-boot mode"..... keep holding the button down..... after some time you will eventually come to a screen with dots. If the screen says "Loading" and does not go to to the calibration screen with the dots, you will need to connect the Nuvi to a PC with a USB cable and rename the file "GUPDATE.GCD" within the Garmin directory to "GUPDATE.OLD". Once the file has been renamed, repeat the above procedure.
Once you reach the calibration screen, now you can let off of the on/off power button. Go through the entire procedure of pressing each dot as it appears on the screen until it says "Done".
Nuvi 2xx/2xxW Series: Turn the Nuvi off. Place your finger on the upper left-hand corner of the screen and then slide the on/off power switch to the left and hold until you see the calibration screen. Note: Some 2xxW models require the procedure below for the 7xx.
Nuvi 7xx Series: Turn the Nuvi off. Touch the screen anywhere and keep your finger there while moving the on/off switch to left (don't wait for Garmin logo to come up) and then quickly moving the switch the right (lock position). After a short while, you will reach the calibration screen. Go through the entire procedure of pressing each dot as it appears on the screen until it says "Done".
Nuvi 8xx Series: Turn the Nuvi off. Remove the battery from the Nuvi for at least 10 seconds. Press and hold your finger on screen, while putting the battery back in. The Nuvi will boot-up and you should see the text "Pre-boot Mode" appear on the screen. Continue pressing on the screen until pre-boot goes away and the progress bar appears. Now remove your finger. After a short while, you will reach the calibration screen. Go through the entire procedure of pressing each dot as it appears on the screen until it says "Done".
Nuvi 11xx, 12xx, 13xx, 14xx, 16xx, 24xx, 25xx Series: Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen.
Once completed the Nuvi will display Calibration Complete
This will recalibrate your touchscreen to the LCD display.
If this doesn't resolves your problem. then your touchscreen may be defective.
Oct 10, 2015 | Garmin Nuvi 1350LMT
Cm6040 unlock menu
Navigate the Administration menu
From the Home screen, touch Administration to open the menu structure. You might need to scroll to
the bottom of the Home screen to see this feature.
The Administration menu has several sub-menus, which are listed on the left side of the screen. Touch
the name of a menu to expand the structure. A plus sign (+) next to a menu name means that it contains
sub-menus. Continue opening the structure until you reach the option that you want to configure. To
return to the previous level, touch Back.
To exit the Administration menu, touch the Home button in the upper-left corner of the screen.
The device has built-in Help that explains each of the features that are available through the menus.
Help is available for many menus on the right-hand side of the touchscreen. Or, to open the global Help
system, touch the Help button in the upper-right corner of the screen.
The tables in the sections that follow indicate the overall structure of each menu under the Administration
menu
Aug 13, 2014 | HP Color LaserJet CM6040f MFP Q3939A...
When the main screen comes on and says touch your name with the pen it does not resond what do i do?
It sounds like the TouchScreen needs to be calibrated.
1. Hold down the Hint button while turning the Leapster on.
2. When the Leapster menu screen appears, press the A button.
3. Touch each of the crosshairs that appear with the stylus.
4. Restart the Leapster.
Hope this helps!
Feb 27, 2011 | Leapster 2
The touch screen wont function with touch of the fingers.
Touchscreen not working
Clean the screen with a microfiber polishing cloth.
Do not wear gloves while using the touchscreen.
Do not use the touchscreen with wet hands or immediately after applying hand
lotion.
Moisture affects touchscreen behavior in the same manner as it affects a
trackpad.
If you have a protective plastic sheet or film on the touchscreen, try
removing it, because it may be preventing the touchscreen from working properly.
The current application may be unresponsive; press and hold the Sleep/Wake button
on top of iPod touch for a few seconds until a red slider appears.
Then press and hold the Home button until the application quits.
If that doesn't work, turn the device off and turn it on again. Press and
hold the Sleep/Wake button on the top of the device for few seconds until a
red slider appears, and then slide the slider.
Then press and hold the Sleep/Wake button until the Apple logo appears.
If the device did not turn off, reset it. Press and hold the Sleep/Wake button
and the Home button at the same time for a least ten seconds, until the Apple
logo appears.
Please rate me
Dec 07, 2010 | Mach Speed T3000 MP3 Player
I bought a new Xperia X10 and i want to copy contacts from my old phone. I copied all my contacts from old phone to the Sim. My question is how can i copy the contacts from Sim to my new X10?
Yes indeed you can copy your sim contacts to your X10
Just insert the sim into your x10.
Turn on the handset
Open main menu by tapping bottom of screen. Or touch bottom of screen and drag finger upwards.
Find "phonebook" and tap that.
Now your phone book is open Press the Bottom LEFT button on your handset not the screen the actual button.
A menu will pop-up so tap the "More" option
Then tap "Import Contacts" from this menu
Then tap "Sim Card" from the new pop-up.
The rest should work for you.
I hope this helps and I hope you enjoy your new phone. :)
Jul 18, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Samsung,touch screen
My samsung star s5233W's touch screen not to access the menu .
I keep pressing the area where Menu, Phonebook and keypad are (area below) but It doesn't respond. it seems that the screen's calibration is off somehow but I cannot perform a calibration since I cannot press the Menu area. How can i fix this? Is there a hard reset button or technique? thanks!
Oct 12, 2009 | Samsung Star GT-S5233 Cell Phone
Bottom of touch screen (G900 handset) doesn't respond
use the myphoneexplorer free software to run the setup wizard in main menu>settings>general. use the L and R buttons on the software after you connect it via usb inphone mode to your computer to run the wizard and then calibrate the touchscreen... it solved the touchscreen problem for me..
Aug 03, 2009 | Sony Ericsson G900 Smartphone
I-mate jam screen
First of all you need to make a "Hard" restart (thats usually cleans up also the memory so perheps you'd better back it up)You can make it by taking out the battery and there I think you should have the restart button,then go into the menu and try to re-configure your screen touch, Hope that'll help
Apr 12, 2007 | i-mate JAM Pocket PC
Samsung B5722 Cell Phone Logo
105 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
