Question about Lexmark Office Equipment & Supplies
I have an x642e all in one and the following message has appeared on the screen - 900.00 service R.I.P Software what shall i do? what doe3s it mean?
  • 2 more comments
  • greenroom Aug 14, 2008
    The message on the screen reads
    900.00 service
    R.I.P Software
    and nothing works
    thanks
    marie
    please help me my lexmark x642e all in one printer has the following message on the screen -
    900.00 service
    R.I.P software
    it does not work either. what does it mean / what shall i do?
    thanks
    what does it mean if the engine board has gone out? and thanks for all the help
    Thanks very much. the problem is outside the printer so now i just need to work out how to solve it. thanks for all your help
    Master:
  • 623 Answers
See this site
http://support.microsoft.com/default.aspx?scid=KB;EN-US;q177078&
Posted on Aug 14, 2008
    Brigadier General:
  • 6,966 Answers
To my knowledge, this error message indicates a possible fault with the "Engine Board" If you are considering a repair, possible source for parts would be http://www.partsnowllc.com/ . You of course could have the service performed by Lexmark.
Incidentally, there are some reports that flashing/re-installing the RIP software would reset the error without the need for board replacement. Perhaps you may want to consider this option. The RIP Software for your model may be found at the ftp.lexmark.com or try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Lexmark Master
  • 6,487 Answers
Check this link it has the explanation and step by step way to resolve this concern
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:556:0:0&framed=&docid=ENUS22164&relevance=1
Hope that helps.........
  • 1,800 Answers
The 900 error occurs only when the printer is receiving information from a network or computer, contact your software/network support. If the error occurs when the printer is idle or not connected to the network or PC, there may be a printer hardware or connection problem. Sometimes a bad connection with an Internal Network Adapter/Network Card can cause the problem. The first thing to check is the base printer. To check the base printer:
  1. Turn off the printer and disconnect every cable, except for the power cord.
  2. Turn on the printer and see if the error returns.
  3. If the error does not return, try to print a test page from the Test Menu.
    1. Press Menu > to enter Menus.
      Optra S series and Optra K series printers: Continue to press Menu > until you see TESTS MENU.
      Optra T and Lexmark T and W series printers: Continue to press Menu > until you see UTILITIES MENU.
    2. Press Select to view the menu items. TESTS/UTILITIES MENU is now on the first line of the display.
    3. Press the Menu > button until Print Menus appears on the second line.
    4. Press Select.
    5. If the display tells you to change paper, press Select or the GO button to print.
  4. If the test page prints correctly, the printer's hardware is most likely working correctly. The source of the problem is probably outside the base printer.
  5. If the 900 error occurs again before, during, or after the printing of the test page, remove all options (internal network adapters, optional feeders, second drawer options, finisher options, additional memory, etc.) from the printer.
  6. Then turn on the printer and try to print the test page. If it still posts the 900 error, the printer may need to be serviced.
  7. If the error does not return, then the problem may be with one of the options.
IMPORTANT: If you receive an Invalid Engine Code error message when you power the printer back on, there is a problem with the printer. An Invalid Engine Code condition will cause a 900 RIP Software Error message to appear if you try to use the printer. The Invalid Engine Code error means either that your printer has lost its stored operating code for the engine board or that the printer's engine board has gone out.
    Genius:
  • 1,689 Answers
Lexmark has a paper in their Knowledge Base on 900 errors:
Go through the suggested steps to try to narrow the problem down.
But if it needs a firmware update:
http://support.lexmark.com/printerfirmware/
Use code: Isfap129 to download the package C530dn.
Hope this helps! -NotAsUsual
  • marlon john madrid
    marlon john madrid Aug 14, 2008
    check on the knowledge base article we posted
    Guru:
  • 1,894 Answers
What is the exact error message?
am not able to understand the exact message.
please tell us clear.
and when is this error message shown?
Lexmark x642e error message 954.95
Seems you have a bad interface card.Try replacing it.
Nov 05, 2011 | Lexmark X642e All-In-One Laser Printer
I WORKING ON A LEXMARK X642E WHICH CAN NOT SEND OR RECIEVE FAXES. WHEN TRY TO GO INTO FAX SETUP MENU IT SAY MODEM FIALED TO INITIALIZE!!
It possible that this is a bad modem, try turning off printer and unplug fax. If you are getting same error message, you need to get a replacement of the modem card.
For further assistance please contact Lexmark Technical Support.
Jun 29, 2011 | Lexmark X642e All-In-One Laser Printer
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Dec 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
    Rear door paper jam
    Here are some articles on rear door paper jam on Lexmark X646e printer. Just click on these links: http://bit.ly/blkK1m ("202 Paper Jam" Message on a Lexmark X642e, X642e or X644e Multifunction Printer) and this link: http://bit.ly/awNDER (A 202.xx (x = any number) Paper Jam Message Is Appearing on a Lexmark X64x Series Printer). These are some guidelines on how to resolve the rear door paper jam on your printer. If you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
    Jul 22, 2010 | Lexmark X646e All-In-One Laser Printer
    The following message appears:unexpected end tag: expected ''font'' ,actual ''b'' what it means what shall i do?
    I too am getting this message although Skype still appears to be working OK. Any suggestions please?
    Apr 27, 2010 | Logitech QuickCam Messenger Web Camera
    How to install Lexmark X642e printer
    Read the manual and follow the instruction provided by your Printer Lexmark.
    Just read it.
    Nov 23, 2009 | Lexmark X642e All-In-One Laser Printer
    900.80 Service RIP Software
    install your printer driver again....
    May 20, 2009 | Lexmark X642e All-In-One Laser Printer
    Can't start up computer
    Problem is that the machine is not communicating with the CD-ROM. You can solve it by following these steps:
    When the message appears, type: Shift+F10 to enter a command session.
    Type: regedit.exe at the prompt.
    Highlight the HKEY_LOCAL_MACHINE entry.
    Go to the File menu and choose Load Hive.
    Then, load %Windir%\System32\Config\System.sav
    Give it a short name that you will remember, like "Test".
    Then, find this key:
    HKEY_LOCAL_MACHINE\Test\ControlSet1\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
    Delete UPPERFILTERS and LOWERFILTERS keys.
    Do the same for ControlSet2 and any other numbered ControlSet keys you see.
    Apr 25, 2009 | Dell Latitude L400 Notebook
    Lexmark x642e MPF Reset maintenance counter
    Hi~
    You can reset the maintenance count by going to the Configuration Menu.
    Step 1: Turn off your X64x printer
    Step 2: Hold the 2 and 6 buttons while the printer is off
    Step 3: Turn on the printer but don't release the buttons yet. Keep holding those buttons for about 10 secs
    Step 4: On your Operator Panel, you should see "Configuration Menu"
    Step 5: Scroll down and look for "Reset Maint Count" and select it.
    Step 6: Exit Config Menu and powercycle your printer (turn it off then back on)
    Hope this is helpful... =)
    <<ichtuscheeky>>
    Jan 30, 2009 | Lexmark X642e All-In-One Laser Printer
    309 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
