Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Hello for some reason my pro heat will not wet the carpet at all thru the hand held or the floor attachtment
  • 39 Answers
SOURCE: bissel pro heat carpet shampooer 1699
Push the foot pad handle release on the left side lay the handle all the way back.Then lift the handle on the center bucket pull out and fill with hot tap water only no soap in the hole that fills up the plastic bladder.Flip the handle back down so that it locks the lid on. On the right side is a smaller soap tank just pull it up and unscrew the top and put your soap in it then replace.Set the dial right beside it to either water only ,or high traffic or ,regular.The soap dispenses automatically saving you from having to mix the solution.Turn both switches on and make a forward and back pass holding the trigger release the trigger go over the area just soaped until most of the water is sucked up. The little red circle on the left side is supposed to be turning if the water and soap are being sprayed out.Repeat and have fun
Posted on Jul 01, 2009
  • 36 Answers
SOURCE: I have a Bissell Pro Heat 2X carpet cleaner and
The reason for the brushes to stop when it is above any surface is there is a switch in the handle that stops the brushes so it dont burn your motor up it may have a faulty switch.
Posted on Jul 31, 2009
  • 25 Answers
SOURCE: Bissell pro heat will not extract water from the carpet
Try checking the top section of the machine (where the dial is located to switch it from floor to tool) and there is a little red plastic piece about 1 inch square on the inside of it. This is a lint filter that has a little door on it. Open the door or remove the entire thing to clean it out. It is probably completely blocked with hair, etc.. which is why you have no suction. Replace it after you clean it out and hopefully your problem will be solved!
Posted on Sep 18, 2009
  • 25 Answers
SOURCE: Bissell carpet cleaner not sucking up.
I have a Proheat 2X and had the same problem. I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying somethign else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Posted on Apr 24, 2010
heatman101
  • 43501 Answers
SOURCE: have water at the hand held but none out the bottom
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
jhklui
Posted on Sep 30, 2010
How do I get hand held vacumn to work without attaching it?
Sounds like the dirt container if full and overflowing.
Aug 31, 2014 | Vacuums
Can't get my bissel steam cleaner to sucktion
Check on board switch for tools only or vacuum, is switched to vacuum, as majority of vacuum suction power is diverted to hose/ hand held devices. See if vacuum hose has suction as well? The unit may be clogged with carpet fibresas well and the unit may have to be taken apart and cleaned thoroughly.
Apr 16, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Have water at the hand held but none out the bottom
heatman101
jhklui
Nov 16, 2009 | Bissell 1699 ProHeat Clear View Upright...
I have a Bissell Pro Heat 2X carpet cleaner and the brushes spin, then stop. I turn it off and when I re-start, the brushes do not spin until I push foreward. The it spins and stops again. Both belts are...
Jul 14, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
DC 17 Animal No suction on hand held hose
There is likely a blockage in the pipe. Try pushing something through taking care not to perforate the pipe.
Jun 21, 2009 | Dyson DC14 All floors Bagless Upright...
Bissel proheat 2x main suction problems
bissel pro heat x2 does not suction up the cleaning fluid
May 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Carpets soaking wet
turn dial in front on the water tank to floor not tools and thats should do it...go to bissell.com to read and print manual so you can double check everything
Feb 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Pro-Heat Facility Off
The solution `wich comes out of the hose is unheated ,you could clean the rug with the machine set to the tools mode and use the hand tools .
The solution wich sprays out to the floor is heated ,you cannot turn the heater of.
Jan 05, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
1,233 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
