Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
How to name cruzer 4GB Stick? - SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
    Guru:
  • 485 Answers
Renaming the USB device is very simple.
-Plug in the USB device into your computer
-Go to Computer or MyComputer and you should now see the USB drive listed their under a drive letter like F: or G
-Right click and select Rename
-Name is whatever you like!
Regards,
G33k
Posted on May 18, 2011
When i plug my 4g cruzer micro usb memory stick nothing happens the cpmuter dosnt read that it is plugged in
Try a different USB device on each of the USB ports on your computer.
Hopefully, all your USB ports are working correctly.
Try a different USB port on your computer.
Hopefully, the SanDisk will be detected on one of the ports.
Try a USB port on a different computer.
If the SanDisk still is not detected, then spend $10 to buy a new 4GB flash-drive.
May 22, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I have a 32GB sandisk cruzer stick. I've used what is called diskpart in Windows 7 to select and format the stick in fat32. I'll take it to a Windows XP box and try to drop a substantial size file to...
Sorry but you wont be able to put a file larger than 4gb due to file format limitation since you used fat32. only NTFS supports files larger than 4gb. if you want to use it with large files you need to format again using NTFS. hope that helps!
Mar 23, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
4GB pen stick cannot write when used space over 2GB
You formatted your pendrive with a FAT32 Filesystem instead of using NTFS.
Do the following. Backup the data currently on the drive, Right click on the drive, choose Format and under Filesystem, choose NTFS ... click ok... you will not be able to use all 4Gb of space on the drive.
Good Luck
Feb 08, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk Micro 4GB Cruzer usb flash drive has malfunctioned and all the computers that I've used it on will not recognize it. Help now!
you can try run check hard drive changes,
and let the O/S pick it up, if not pick from the list of hardware devices, choose
usb mass storage, click on it and look for the maker name, pick your model.
if this those not work, run the driver from the cd that came with the USB device.
if not you will have to go for a update from O/S provider.
May 21, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to install new U3 launchpad on my SanDisk Cruzer Micro 4GB ??? thx
I am sorry but once the default software is removed from the stick there is no way to reinstall it. SanDisk dose not offer that software for download on there site and dose ware if it is removed that it can not be reinstalled. I am sorry.
I hope this helped.
Thank you,
Norse
May 18, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How can I erase the Sandisk Cruzer Micro 4GB USB menory stick? I deleted everything on there but it still says that I only have a few MB's left even after emptying the trash. I work on a Mac using OSX. I...
Try to format the stick.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "flags".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 06, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How can i use an usb memory stick (4GB) on an iMac running Apple OS Snow Leopard? I would have to format one to use it on a Panasonic BlueRay Disk Player!
plug it into your computer and go to my computer then click on the usb memmory stick and drag stuff over to it like files etc. :D
Sep 13, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My computer won't recognize my cruzer micro 8gb stick. I don't want to reformat, because I have at least 1000 pictures, plus Quickbooks, Legacy and other data on it. Anyone have any ideas?
some older pcs wont recognise sticks and sd cards larger than 4gb. it will probabaly be down to the version and service pack of windows you are using.
Aug 21, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Corrupted files on cruzer micro 4gb
Due to the U3 technology, i.e. the files you deleted which were on the drive when you got them, you may have caused the drive to malfunction because the U3 software was not uninstalled, but rather deleted.
Please attempt to reinstall the U3 software on the Sandisk website, named "U3 Launchpad Installer"
which can be found at this link: http://www.sandisk.com/Retail/DriverDownloads.aspx
If you are still having problems, either reinstalling the software or with corrupt files, please report any errors exactly as you see them.
Dec 04, 2008 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
SanDisk 4GB cruzer URGENT problem! Please, please help! :)
it may have overheated and became stuck. Stick it in a plastic bag and put it in the freezer for 1/2 hour then try it. Do not leave it out without power for long or moisture will condense on it.
Nov 28, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
95 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
