Question about Danby DDR4588EE Dehumidifier
Danby dehumidifier ddr4588ee ices up. Humidifier located in basement with temp around 60degrees. Unit is 1 1/2 years old.
    Brigadier General:
  • 4,736 Answers
According to your Owners Manual, the coils may start to frost at 60 degrees and the defrost sensor should turn ON and cycle periodically. However, the air temperature at the floor level in a basement, is colder than the air temperature by 5 to 8 degrees. So this may be causing the problem. In addition, if the air intake filter is dirty or clogged, the unit has to strain to keep up and will not function as it should.
If the unit is totally iced up, turn the unit Off and unplug it from the wall outlet. Allow is to thaw completely before attempting to clean the filter. You may want to put some old towels under it while it thaws. Once it's thawed, move it to a bathroom that has a shower. Plug it it in and set the humidity level at 45%. Turn the shower ON at a Medium hot temperature (enough to generate steam) and as you exit the batroom, close the door. DO NOT operate the bathroom's exhaust fan. Allow the unit to operate for 15 to 20 minutes, before returning to the bathroom. Then turn the shower OFF and check the unit for any frost and the amount of water collected in the bucket. If there is no frost on the unit and there's water in the bucket the unit is operating properly.
When you move it back to the basement, place it up off the floor on something sturdy, that can hold the weight and not be bothered by the vibration of the unit, when it's running. (ie a work bench, a counter top, etc.) Operate the unit as you normally do and monitor it for frost or icing up. And, whether or not the defrost sensor is cycling as it should. If you get no frost or just minor frost, it was the air temperature at the floor level, that was causing the problem.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Posted on May 18, 2011
The dehumidifier is getting cold condensation on the top outside of the unit and no water in the bucket. Model BGD-510A. I cleaned the filter and the coils and still have this problem.
Kathryn, if you are operating it in a basement application, the problem is that air temperature at floor level, is colder than at shoulder level. Dehumidifiers struggle to work at temperatures between 40 & 65 degrees F (Unless they are Low Temp model designed for basement applications). And will ice up at times. Raising the unit up off the floor onto a sturdy table, counter top, etc that can handle the weight of the unit, plus a full bucket of water, will usually resolve the problem.
If it's not a basement application, try lowering the humidity extraction level to 35%. In you have an analog unit, turn the control knob to Maximum.
I hope this helps you and thanks for choosing FixYa.
Aug 10, 2011 | Dehumidifiers
I need to replace the water tank for my Danby model DDR4588EE. Any suggestions where I can get it?
Contact Danby at 800-496-6049 for parts not covered under warranty.
Hope this helps you and thanks for choosing FixYa.
Jul 25, 2011 | Danby DDR4588EE Dehumidifier
Hi my Danby DDR4588EE Dehumidifier's buttons aren't working
Hi! I'm assuming that the unit is plugged in and the outlet the unit is plugged into is working (if not, is there a tripped circuit breaker, in your home's circuit breaker panel?). Also, that you have turned ON The Master ON/OFF Switch and the Water Collection Bucket is installed properly and the Float Valve inside the bucket is in the Down position
If you answered NO to any of the above, turn the the Master ON/OFF Switch to OFF and unplug the unit, before checking those things first. Because, 9 times out of 10, one of thee above is the culprit.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 18, 2011 | Danby DDR4588EE Dehumidifier
Icing up recently.everyday it ices up. the temp. in the basement is about 55 degrees. never had a problem for over a year untill now. it supposed to have an auto-defrost, but it doesnt seem to work.
The air intake filter may be clogged. Cleaning it, may solve the problem, once the unit thaws out. In addition, low refrigerant gas can also cause the unit to ice up. While waiting for the unit to thaw completely, turn the Master On/Off Switch to OFF and unplug the unit. In addition to thawing this unplugged time, may give the unit a chance to reset itself.
Hope this helped you solve the problem.
Mar 22, 2011 | Danby DDR3009EE Dehumidifier
Frosting up in front after it been on for awhile
Here is a tip that I wrote that will help you understand why and what you can do with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Feb 05, 2011 | Danby DDR4588EE Dehumidifier
I need a manual for Danby dehumidifier DDR4588EE
You can get the manual on the link below.
http://www.danby.ca/cms/uploads/products/en_manual/DDR3008_EOM.pdf
Good Luck and please rate 4 thumbs up for the free answer
Jun 20, 2010 | Danby DDR4588EE Dehumidifier
Have a wind chaser wdh running in my basement and it keeps icing
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 29, 2009 | Windchaser WDH928 Dehumidifier
Danby DDR4588EE Dehumidifier Logo
290 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Gil Shultz
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
