My washing machine Kenmore model 11018522791 has a dual action adjutator and the top adjutator is not moving but the bottom is. Which part do I need to replace? Is it the adjutator dogs?
    Master:
    Sergeant:
  • 385 Answers
Yes it is the adgitor dogs.Hope this helps.
Posted on May 18, 2011
Washer won't agitate
Really depends on brand of washer and how it's designed. Some agitators are dual action and top moves independently from bottom like a ratchet. Plastic ears inside agitator could be stripped out. Could also be motor coupler that joins motor to transmission in some Whirlpool made washers.
Aug 26, 2017 | Washing Machines
My KENMORE Heavy Duty,Dual Action washing machine does it have a fuse inside? Washer does not start, it is now full of water and I cannot find the model # as it is too heavy to move. Thank you!
Check your lid switch. It is located in the little oval hole on the right side when you open the door. The model # is locted right in front of you when you open the door. Very common problem. Rate me if I helped you.
Aug 22, 2010 | Washing Machines
Have Kenmore Elite Catalyst Washer showing F3.
I have a top load Kenmore Gold Catalyst Cleaning Action washer that is stuck on permanent press mode. The digital display reads 8 min. and will not turn off or clear.When it is turned on the, the timer goes to 37 minutes and beeps repeatedly through all cycles. It will not clear even when I unplug it. How do I fix this annoying thing!!? Thoughts please.
Bill
May 22, 2010 | Kenmore Washing Machines
I have a top loading Kenmore Washing machine, Model 110, Heavy Duty, dual action. The machine is level but during the spin/unload cycle, the machine bounces around and makes noise. If I put two cases of...
There are pads on the tripod and skid plate that wear out and can be replaced. There is fluid in the tub ring that may have leaked out. The base (tripod) can be bent and cause vibration problems. The flooring material and support can cause this also. I would start with the floor and work up through and eliminate the causes to find the culprit.
Eric
Nov 19, 2009 | Kenmore 24032\24036 Top Load Washer
Dual action kenmore 70 series washer need to remove agitator
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It sounds as if your "Agitator Dogs" are damaged or broken. These are plastic pieces that allow the top agitator to turn only one way.
Please see the following for how to access and replace them if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=39649e541343127154c647348d1156d9
Basically,
1. Remove the fabric softener dispenser.
2. Using a short flat blade screwdriver, remove the cap.
3. You may see a 1/2" square plastic nut.
I've used a 1/2" extension for a socket set to remove the nut.
4. Pull the top agitator off and turn it over carefully.
You should see the agitator dogs (per the illustrations).
Replace them if necessary and re-mount the agitator, tighten the bolt carefully, put the cap and fabric softener dispenser back on and the top part of the agitator should only turn one way.
Nov 06, 2009 | Kenmore Washing Machines
Kenmore 92587400... The dual action or top portion is not spinning
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.92587400
I assume that you mean that the top agitator is not.
See the section of the Sears site for Agitator, Basket and Tub.
You'll see an item #5 "Clutch, Agitator". These are basically used to allow the top agitator to move only one way. If they are worn (which happens since they are plastic parts) the top agitator may not move either way.
There is also a part #6 "Agitator Auger" that screws into the main agitator shaft from the transmission. If this is loose, the top agitator may not move either.
Both of these are easy to check and repair.
Sep 28, 2009 | Kenmore Washing Machines
Bottom agitating, but top freely spins
You need to get an agitator repair kit. Remove the cap on the agitator. Some have a second inside plastic cover/cap. You will need a long extension and rachet and 1/2" socket to remove the hold down bolt. Remove and replace the parts with the kit parts. Replace the cover. 10 minute repair... online kit is about $13.00.
Aug 03, 2009 | Kenmore 24032\24036 Top Load Washer
Adutator not working well,and cliking noise while adjutating
pop up top off the agatator,pull the inside cap out,there are 4 dog ear gears in there that have to be replaced,your local appliance parts store has them for $mike
May 08, 2009 | Kenmore 15864/15862 Top Load Washer
Washer does spin but barely agitates
It sounds like the agitator dogs are worn.
To remove the agitator, pry off the agitator cap and remove the bolt that holds down the agitator. With the bolt out pull up on the top section of the agitator (auger) to remove it. Underneath the auger you should see 4 small white or beige plastic gears (dogs). . Replace those and it should be ok.
The part number is 80040
Let me know if you need more assistance.
Apr 08, 2009 | Kenmore Washing Machines
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
