Question about HP LaserJet 4700 Printer
How do I cancel ALL print jobs on the HP 4700? There are a great many of them.
IF you have a windows operating system please got to printers and faxes(xp) or devices and printers, right click on your printer and choose 'cancel all documents'
or go to run>type 'servies.msc'>find 'print spooler' and restart it.
Posted on May 18, 2011
Laserjet 4700 49.4cf2
Clear the print queue and power cycle the printer. One of the jobs your are trying to print is bad.
Jul 10, 2014 | HP LaserJet 4700 Printer
HO C4200 DOCUMENT STUCK IN QUE CAN'T DELETE
First You Need to Open the Print Queue, follow the below steps on how to open a Print queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double click on the appropriate printer to open up the Print queue,Check whether you have any pending or the queued jobs, try to cancel the jobs by following the below steps.
To cancel one or more print jobs, follow these steps.
1. Click Start, and then click Run.
2. In the Open box, type control printers, and then click OK.
3. Right-click the icon for your printer, and then click Open.
• To cancel individual print jobs, right-click the print job that you want to cancel, and then click Cancel.
• To cancel all print jobs, click Cancel All Documents on the Printer menu.
If you are using an HP printer and a windows vista operating system then you are lucky to automaticlly fix the issue with the HP Print Diagnostic UtilityClick Here For How to cancel printing or to delete a print job that is stuck in the print queue in Windows XP.
Alternatively You can check the below steps.
Delete Pending Jobs
How To Restart Spooler restart In Windows Vista
Click the Start button.
Click Control Panel.
Click System and Maintenance.
NOTE: This step is not required when using Classic view in Windows Vista.
Click Administrative Tools.
Double-click Services.
On the User Account Control window, click Continue.
Click Print Spooler.
Click Stop to stop the Print Spooler.
Click Start to restart the Print Spooler. Then click Restart
Click OK
Hope this helps!
Thanks!! - See more at: http://hpanswers.blogspot.com/2008/10/cancel-and-delete-stuck-print-jobs-in.html#sthash.QD3KNI9q.dpuf
Jul 01, 2014 | HP LaserJet 4200 Printer
Hp 4700 49.3066 service error
49.xx errors are mostly caused by invalid print commands, corrupt
data, or invalid operations. Basically the printer "does not understand" the print job.
- restart the printer to clear the print job from the printer's memory.
-if the error returns disconnect the network/USB cables from the unit and cycle power again.
If the error comes back without the network/USB connected perform a cold reset on the device and go the next step.
- Once the unit is at Ready reconnect the network/USB cable.
If the unit gets the 49.xx error or begins to print a job then gets the error disconnect the cables again and power cycle the printer. This time when you plug the network/USB cable in watch the control panel for any signs of the unit receiving a print job. When the printer says "Processing" press the cancel button on the printer. This should clear the "bad" print job.
I strongly recommend updating to the latest driver for the device Drivers Software . If you had an issue with a PDF file use the Post Script (PS) driver.
Good Luck
Jan 24, 2012 | HP LaserJet 4700 Printer
Cancelled a job and it stays in queue
Cancel all the documents in the print queue, (just do it whether they are actually deleted or not), press "cancel" on button the printer and restart your system and also the printer. If possible, please leave the printer switched off for few minutes and don't forget to use the "Power" button to turn if off or on. This will help your printer to restart new print job, all the jobs on the print queue will be deleted/cleared. Good luck, Thanks for using FixYa.
Jun 08, 2010 | HP DeskJet 5550 InkJet Printer
Unable to delete pending jobs
1. Go to Control panel - Printers .
2. Right-click the icon for your printer, and then click
Open.
3. To cancel individual print jobs, right-click the print job
4. To cancel all print jobs, click Cancel All Documents on
the Printer menu.
Alternatively if this doesnt work you have to restart the spooler service
1.Go to Control Panel - Click Administrative Tools.
2.Double-click Services.
3. Stop the service called Print Spooler.
4. Click Start to restart the Print Spooler. Then click OK.
Hope this helps.
Mar 12, 2010 | HP LaserJet P4015N Printer
Can't cancel a HP PSC 750 Printer print job.
Right click on MyComputer and click Manage. Then go to Services and Applications and then Services. Find the Print Spooler services in the list and right click to stop it. When it is stopped try to cancel the document again. Then start the print spooler service again.
Regards,
nicolasiac
Feb 12, 2010 | HP PSC 750 All-In-One InkJet Printer
My printer hp deskjet 3550 not working properly
my printer did not take the printing job. I wnt to cancel the job but it is not cancell lsat one job is still pending. If acctionally take the print firt two line is printing the rest of the matter is pending and that job is not able to cancel . I have hp diagnostic utility but it is also not working to release the printing que. kindly do needful to solve this problem
Jun 21, 2009 | HP DeskJet 3550 InkJet Printer
HP LaserJet 4700N has a service error code message of 49.FF05. What does it mean?
1 Press CANCEL JOB to clear the
print job from the printer memory.
2 Turn the printer off and then back
on.
3 Try printing a job from a different
software application. If the job
prints, go back to the first
application and try printing a
different file. If the message
appears only with a certain
software application or print job,
contact the software vendor for
assistance.
4 If the message persists with
different software applications
and print jobs, disconnect all
cables to the printer that connect
it to the network or PC.
5 Turn the printer off.
6 Remove all memory DIMMs or
third-party DIMMs from the
printer. (Do not remove the
firmware DIMM in slot J1.)
7 Remove all EIO devices from the
printer.
8 Turn the printer on.
9 If the error no longer exists, install
each DIMM and EIO device one (memory)
at a time, making sure to turn the
printer off and back on as you
install each device.
10 Replace a DIMM or EIO device if
you determine that it causes the
error.
11 Remember to reconnect all
cables that connect the printer to
the network or computer.
12 If the error persists, replace the
firmware DIMM.
13 Replace the formatter and
calibrate the printer. See
“Calibrate Now” on page
Jun 10, 2009 | HP LaserJet 4700 Printer
HP LaserJet 4700 Printer Logo
403 people viewed this question
Ben Johnson
