Question about Xerox DocuColor 12 Color Copier
System fault copies can not be made - Xerox DocuColor 12 Color Copier
  • 79 Answers
May i know the exact system fault code?
Posted on Aug 16, 2008
What does the service code p1111 mean?
Copied directly from a Jaguar forum:
P1111 is not a fault code. It is a special designator Jaguar uses meaning system ready, drive cycles completed after the last fault event. P1000, on the other hand, means system not ready, or drive cycles not completed after the last recorded fault event.
Some OBD II Basics - All P0xxx codes are generic and uniform across all manufacturers and mean the same on every car. All P1xxx codes are manufacturer specific codes. You cannot use a generic code chart to analyze P1xxx codes for a Jaguar.
Next time your car displays an engine fault light, try reading the codes then. If you have a CEL illuminated and the only code read is P1000 or P1111, then you probably have a fault that generic code readers cannot see. Could be a chassis code, for example.
One last thing - Neither P1000, nor P1111 can be erased.
Hope this helps you.
May 20, 2011 | Jaguar X-Type Cars & Trucks
I am using compaq notebook 510 which comes with free DOS i have copy of vista ultimate with 30 days validity. i have to convert this into full version ,i would tried many cracks which shows cracks...
no its not the fault of notebook.............its the problem of cracks...
use original copy...............i would prefer you windows 7 as its much better then vista
Nov 12, 2009 | Microsoft Windows Vista Ultimate Edition
System fault 10:368! How I can make it working again?
change the control thermster of press roll (closer to the middle of the roll)
Oct 21, 2008 | Xerox DocuColor 12 Printer
Will not make a copy
If it won't copy, it is unlikely to handle faxes either since those functions use the same scanner. If your received faxes are coming out blank, then it is a problem with the ink system; if you can get faxes printed but not copy a document, the scanner may be at fault.
Have someone send you a fax to check this function (printing) and then try sending one back to check the scanner.
If either one fails, then hyou know where the problem lays.
Jul 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
System fault
Refer to the link i posted and put in you question in the box and that should give you a correct information as its the manufacturer.
May 13, 2008 | Xerox DocuColor 12 Printer
Fault caised by bad contact and raw disk - unformatted can't found FAT system
It appears there's a dault with the data/memory card.
You will need to upgrade the XMenu:
How to upgrade the XMenu:
>>>> Warning! All data on the MK5 will lose after you start the upgrade! Please backup it first!! <<<<
1. Use MK5 USB Linker connect PC , and enter USB data exchange mode , PC will detect one removable disk (MK5) have inserted
2. Copy "MK5_Menu_V1.39_AUTO_Upgrade.nds" to MK5
3. Restart NDS, enter MK5 menu, choose "MK5_Menu_V1.39_AUTO_Upgrade.nds" and run it,and restart NDS.
4. When NDS power on, hold L+R+A+B+DOWN to fast format whole MK5, or you can use A+B+START+SELECT+UP to make a low-level format ,then copy all data (include folder) from this uncompressed file.
5. Now new system is ready ,restart NDS and enjoy it!
May 12, 2008 | Nintendo DS Lite Console
Xerox DocuColor 12 Color Copier Logo
44 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
